Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 01-28-2006, 07:18 PM   #1
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Default Zeitronix WB O2 Install
Got it installed last night, and just wanted to say that the install was pretty easy, and everything's working well. Definitely the best bang for your buck WB.
One question I did have, do you have to use their boost sensor, or can you tie into the factory boost sensor?
here's pics
http://www.main.experiencetherave.co...ges/zeitronix/
Here's a run I did and logged.
http://www.main.experiencetherave.co...nix/wblog1.xls
One last thing. I emailed Zeitronix and asked for the equation for the WB. I'm going to log the voltages with my perfect power, and when I dump everything to Excel, I can use the equation, and convert the voltages to AFR's.
Here's the equation:
AFR = -0.3481V^6 + 3.4583V ^5 -12.813V^4 +22.269V^3-18.043V^2 + 7.4273V + 8.8711
Here's an excel spreadsheet that compares the look up data provided with the unit, and the equation. Once you get above a certain point the equation get's funky and turns negative. The display of the Zeitronix logger doesn't go above 21 AFR, so I just stopped at that spot.
http://www.main.experiencetherave.co..._afr_graph.xls
Josh
Legacy777 is offline   Reply With Quote
Old 01-28-2006, 09:01 PM   #2
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Cool, bang for the buck you say, where did you get it, and what $$$
DP
DonkeyPunch is offline   Reply With Quote
Old 01-28-2006, 10:57 PM   #3
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
If you want/need to log boost and/or EGT then get the Zeitronix. Definitely a great deal. However, if all you want is AFR then buy the Innovate LC-1 Wideband. The LC-1 is only $199.
t
WolfPlayer is offline   Reply With Quote
Old 01-29-2006, 12:38 AM   #4
Legacy777
Member#: 4800
DP
http://www.zeitronix.com/Products/zt2/zt2.htm
Old 01-29-2006, 12:39 AM   #5
Legacy777
Member#: 4800
t
I wanted the Zeitronix because it had a simulated narrow band output for the ECU. That's another reason I went with it.
Old 01-29-2006, 07:33 PM   #6
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Check the MegaSquirt/MegaTune bundle which has an A/D lookup table for the Zeitronix's non-linear wideband output (8 bit resolution). I don't know if another 3.5bar boost sensor would work since their controller is calibrated to that (and it will only go down 25.5inHg Vacuum) - I wouldn't bother with logging their simulated narrowband output since it's almost like a switch right around 14.7 - on my Link, just a tad off I get readings of 0.09V on the lean side and 0.91V on the rich side. If the PerfectPower can take up to 3-4V just use the wideband output
kgb is offline   Reply With Quote
Old 01-30-2006, 09:38 PM   #7
Legacy777
Member#: 4800
I'll take a look at the megasquirt.
I had planned to use the perfect power to modify the MAF signal for fueling. But I still need the narrow band for the stock ECU. The perfect power 6 won't accept a wideband input. It's a shame too. I have the wideband output hooked up to the engine temp sensor on the perfect power. The voltage is displayed on the screen, however it's not displayed in the data log. If it was, I could just use the equation and come up with AFR's
I'm finding the PP 6 to be a little on the limited side as to what it really can do. That in combination with the fact I'm getting intermittant stumbling/hesitation (and I'm not the only one) I'm probably going to be looking for an alternative EM that works with the OBD1 ECU's.
WB o2 install Kastley85891 Open Source Reflashes 21 06-19-2009 02:13 PM
MD FS: zeitronix wideband o2 w/ lcd screen, boost and egt sensor AirWaveGT Private 'For Sale' Classifieds 4 11-06-2005 05:54 PM
Brand New Zeitronix Wideband O2 w/ LCD MajorAgee Private 'For Sale' Classifieds 7 10-13-2004 11:28 PM
stepping down a WB o2 to 0-1v? Midwayman Engine Management & Tuning 2 07-24-2003 08:21 PM
LINK WB O2 option coming soon teiva-boy Engine Management & Tuning 12 12-21-2002 04:14 AM
