Old 01-28-2006, 07:39 PM   #1
pedru
Member#: 84354
2003 impreza WRX
blue mica
Default Has someone changed a block 2.0 for a 2.5 in a wrx?
Hi¡¡
I want to know if somebody has changued a EJ25 in his WRX(EJ20)2001-2006.
HP??
Press of boost??
Problems in the assembly??
I have in my car Complete Helix exhaust,HKS bov,and Apexi's(SAFCII,AVC-R)
Best regards and sorry for the language
pedru is offline   Reply With Quote
Old 01-28-2006, 08:32 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
We've done more than 50 cars. It's a totally straight forward swap, you'll want to run a thicker head gasket to keep your compression numbers in line, and of course you'll need a retune. The WRX's that we swap make about the same power as the STI on the VF34, about 270whp / 280 ft/bs properly setup. If you're local or would like to send your car over, drop me a PM.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 01-30-2006, 08:08 AM   #3
pedru
Member#: 84354
2003 impreza WRX
blue mica
Hi Gary¡¡
I'm from spain,very dificult to send my car
You say,that a wrx with short block 2.5 with ihi vf34,has 270-280 hp?
my car now with helix exhaust, turbo of house(td04)and apexi's 1.2bar,it has 280hp.
Do you say me that if i change the block,I'll have the same HP????
I dont understand??
CAn you send me graphics,the cars with short blocks,with exhaust and 1.2 bar of press,with td04.
Best regards.
I have talked with MAx,for the price of the short block 2.5.
Old 01-30-2006, 08:36 AM   #4
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
he's talking WHEEL horsepower numbers
overdose is offline   Reply With Quote
Old 01-30-2006, 09:13 AM   #5
ejh25
Member#: 65267
Run a search in this forum, the 2.0 forum, and the conversions forum. You should have plenty to read.
ejh25 is offline   Reply With Quote
Old 01-30-2006, 02:08 PM   #6
pedru
Member#: 84354
2003 impreza WRX
blue mica
thanks
Old 01-30-2006, 04:00 PM   #7
TexRex2002
Member#: 36303
06 Evo IX
nope, has never been attempted...
ok ok, jeez...
TexRex2002 is offline   Reply With Quote
Old 01-30-2006, 04:12 PM   #8
the_colombian
Member#: 84912
2003 2.5L bugeye now
with 6 spd 20g!
pedru, I have this swap myself.
Because you arent upgrading the cams, its kinda hard to make more power than with the 2L, but you will make a lot more torque and power will come on a lot sooner making your powerband more usuable. I am very happy with it.
the_colombian is offline   Reply With Quote
Old 01-30-2006, 05:33 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi Pedru,
A stock WRX (02-05) comes out of the box on our dyno at about 155-160whp. The standard WRX properly setup with a VF34 will make right around 260whp and 230 ft/lbs of torque, a 100whp gain. With the STI shortblock you will make about 10whp more, and about 40ft/lbs more torque with a MUCH stronger low-end and midrange. That said, the_columbian is 100% correct, the WRX heads and VF34 turbo then become the limiting factor in top end power. Most customers will want to do cam upgrades as well as use the 2.5 to spool a larger turbo for more power.
Hope this helps, you can always e-mail me at [email protected] if you have any questions. Thanks,
Gary
Gruppe-S
STI cams in 2.0 heads on 2.0 block? OUScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-06-2010 10:05 PM
Cobb AccessPORT 2.0 for the 2.5L motors Robson TXIC Private Classifieds 3 02-24-2009 12:00 PM
Who is using AP 2.0 for a 2.5l hybrid? Acostafan AccessPort 2 06-18-2007 03:14 PM
Can you swap a 2.0 for a 2.5 in a 02? luckystryke311 Newbies & FAQs 11 12-22-2006 09:47 AM
question about swapping a 2.0 for a 2.0 BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-25-2005 02:39 AM
