Old 01-28-2006, 08:30 PM   #1
Absubtle
Member#: 85862
OMGHi2U Ver 6 swap into 98 RS, issues?
As said so, JDM STi Version 6 swap (swap includes engine and trans) into a 98 RS. I am not, so concerned about wiring, but how about the gear ratios? From final drive ratio of the new Ver.6 5-speed to the factory RS diff? I am just needing a baseline whether to look for a rear diff swap or not. The engine/trans swap is happening, just need to know what else I need to account for.
Sure I have searched, I have searched every possiblity of any version of a Ver 6 swap into 98 RS. I know someone is gonna post a thread and flame for not searching hard enough. But this search engine SUCKS!
Help, sure that would be nice. Knowledge, that may buy you a free night of drinking
Absubtle
PA
Absubtle is offline   Reply With Quote
Old 01-28-2006, 08:38 PM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Should be a 4.44
Ver.III is offline   Reply With Quote
Old 01-28-2006, 09:00 PM   #3
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Yes rear diff needs to be changed out.
Do you have the engine/trans yet? wiring harness? ecu?
You need to ask specifics
Scoobie Steve is offline   Reply With Quote
Old 01-28-2006, 09:28 PM   #4
Absubtle
Member#: 85862
It's a customer supplied engine.. so I am debating the issues of perhaps needing to change the rear diff. I dont have the swap engine/trans yet... so I am just preparing.
I was informed that it was a complete harness.. so we'll see.
Yeah, I thank you guys for trying, but, as you and I , both know, it will depend on what tranny shows up.
There are SO MANY absolutes of ratios, etc. I'd rather just start w/ what I KNOW I am working w/.
I bought a 02 WRX ej20 transmission for a customer, and according to sites, showing transmissions part numbers, this was NOT the correct final drive, etc.. But it ended up being correct. The trans number matched the JDM trans sites perfectly.. but the final drive in the 5-speed worked just fine. So you have to use common, mechanical sense.
Absubtle
PA
Old 01-29-2006, 01:45 AM   #5
blackbart
Member#: 57892
1994 Turbo Wagon
Varies with mood
Where is the JDM website that has the tranny spec?
blackbart is offline   Reply With Quote
Old 01-29-2006, 06:03 AM   #6
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
google search your transmission code (jdm). youll pop with catherine ken.
swapstar is offline   Reply With Quote
Old 01-29-2006, 12:23 PM   #7
blackbart
Member#: 57892
1994 Turbo Wagon
Varies with mood
That was the first thing I did when I got the tranny, got no results. I did find a chart for the JDM 5MT's while searching but mine is a 4EAT, TZ102YBAAA C5, I searched both with and without the "C5".
Old 01-29-2006, 01:59 PM   #8
Absubtle
Member#: 85862
http://www.northursalia.com/techdocs...rannychart.pdf.
But this site is down right now... So check back later. This is one-of-the-most extensive charts I have ever seen w/ transmission numbers and gear ratios.
Absubtle
PA
PS-OK IT'S WORKING NOW!!!!
Old 01-29-2006, 04:03 PM   #9
Absubtle
Member#: 85862
After searching for most of the day (seems like), I am coming to the conclusion that a 98 RS 2.5l will have a final drive of 4.11 and most likely the Ver. 6 STi 5-speed will be a final drive of 4.44.
SO I guess I need to source an Outback rear diff, Forester XT or get a new ring & pinion.
I went to my Alldata account to converm the 98 RS gear ratios
Absubtle
PA
PS- Or an Automatic 98 RS... that maybe easier. It's listed as 4.44.
Old 01-29-2006, 05:03 PM   #10
blackbart
Member#: 57892
1994 Turbo Wagon
Varies with mood
Absubtle
PA
WOW, that is a great site! But the tranny chart is the same one I found on the Rallispec site, I got the specs for my JDM manual but not for my JDM auto.
Old 01-29-2006, 05:19 PM   #11
Absubtle
Member#: 85862
Just PM'd ya... Yeah I realized, AFTER, I sent it that this for manual 5-6 speeds.. Sorry for the false hope. But I will help ya search for them. What year do you think your tranmission is from?
Absubtle
PA
STi swap into 98 RS coupe rs_racer253 Subaru Conversions 1 11-26-2006 12:09 PM
Ver 7 swap into GC8....have some CEL issues..need help!! VtecGSR95 Subaru Conversions 6 09-28-2006 10:34 PM
any shops or anyone in san antonio for STi ver.3 swap into 00 RS suberstar 2.5 Subaru Conversions 0 01-24-2006 10:34 AM
STi ver.3 swap into 00 RS? suberstar 2.5 Subaru Conversions 12 07-06-2005 05:56 PM
Parts for my sti into 98 rs swap. austenf740 Subaru Conversions 15 04-04-2005 11:52 PM
Message Board Statistics All times are GMT -4. The time now is 02:55 AM.
