Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 01-28-2006, 08:36 PM   #1
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
Default Need to replace all rotors & pads -- need suggestions
Hey all,
Time to replace all the brake pads and rotors, get it over with. Just had the 30K mile tuneup, so brake fluid is fresh.
From what I'm reading, crossdrilled rotors are a bad idea for regular (yet aggressive) city driving and slotted rotors just cost more money & reduce the heat absorbing mass.
Someone here said they got these rotors and pads & they worked well. Can't beat the price either; $200 for four rotors & pads!
I've seen regular Brembo's for like $50 each, not including shipping.
I've also PMed a number of vendors for deals, so we'll see on that.
Also, should I replace the brake lines too? 205K miles, not sure if its ever been done since the car is used.
Anything else? Thanks guys
GTWagon_Phreak is offline   Reply With Quote
Old 01-29-2006, 12:18 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'd do the plain Brembos, they're a good deal and from what I've experienced are better than the Subaru OEM. I run them on my car and have never had any issues.
I would also replace the brake lines. 200k+ miles is quite a bit for what are probably the original rubber lines. Can't hurt to do some SS braided lines, but they're not really necessary. I've never priced the OEM lines, if they're cheaper than the SS lines you could just go with those.
As for pads, well, that's one of those things that is debated over and over. Carbotech Bobcats, Hawk HPS, Hawk HP+, Axxiss Ultimates, etc etc. You could read until you're blue in the face over in the Brakes & Suspension forum. I've always run Mintex 1155s on my car, but they're kind of hard to come by now. And they apparently don't make them for the H6 rear calipers I'm running now, so my next set of pads will be Ferodo 2500s (which I've never run before).
Pat Olsen
'97 Legacy 2.5GT sedan
Old 01-29-2006, 03:37 AM   #3
Member#: 25324
2016 WRX
Dark Gray Metallic
I wouldn't waste money on special rotors or pads unless you drive the car in such a way that you actually experience brake fade or "warped" rotors.
I always used to "warp" mine, so I finally ponied up for some cryo-treated rotors from frozen rotors dot com and Hawk HP Plus pads. They have been rock solid for a couple years now. But, that only makes sense if you have that problem.
cowapult is offline   Reply With Quote
Do I need to replace all 4 tires? (Sort of urgent I guess) formula91 Tire & Wheel 9 12-17-2007 05:11 AM
Need to replace all 4?? mars636 Tire & Wheel 3 09-08-2006 10:33 PM
WTB Replacement Brembo Rotor & Pads 02 4pot upgraded brks nyaconis Private 'Wanted' Classifieds 0 06-16-2006 10:39 PM
Need to replace front rotors/pads on 2002 OBS - Need Advice! mekkon Brakes, Steering & Suspension 6 04-24-2006 06:16 PM
1 blown tire, do I need to replace all 4? Capt Crunch Tire & Wheel 17 06-06-2004 05:23 PM
