Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-28-2006, 10:39 PM   #1
dubluv17
Member#: 26298
MBP
Default Low boost after wastegate porting
k...so i had to send my sz49 into deadbolt to get the wastegate ported because i was spiking in higher gears and it wasn't keeping the boost down...i just got the turbo back last night and put it in and now i'm only getting ~8 lbs of boost...my map is tuned for 15.5 lbs of boost...so here is my question...did the porting of the wastegate and larger flapper make it so that it opens easier and therefore makes less boost? that is really all that i can think of at this point...i don't have the software to tune the boost map myself so that's out of the question...if anyone has any ideas please let me know...thanks
Brooks
dubluv17 is offline   Reply With Quote
Old 01-28-2006, 10:53 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...vac lines on wrong.... mebbe...there is a restrictor in the line that is just off the compressor nipple...if the lines are backwards, ya likely get ~8psi
Old 01-28-2006, 10:57 PM   #3
dubluv17
Member#: 26298
MBP
well this is actually my freind's car...it's using the factory boost control solenoid...which end is the restrictor supposed to be on? i don't think we switched them up from before...i totally forgot about that restrictor, but that could be it...hmm i hate when i forget about stupid stuff like that...it's just been so long since i dealt with that...well i'll tell him to give that a shot and we'll go from there...thanks for the reminder!
Brooks
Old 01-29-2006, 12:32 AM   #4
antimullet
Member#: 44193
2008 WRX STi
It needs to be on the compressor side.
Also, if that don't work you can (As a bandaid until tuning) put a turn or turn and a half on your wastegate actuator arm. This will preload it and keep it from blowing open.
If its not your restrictor pill, then you need to tighten that actuator anyway cause the wg is blowing open cause of the portjob. And to do it right you should retune the duty cycle of the WG thru the ECU.
I've never been able to hold a solid 20psi on my green (for long anyway)cause of the internal gate. I'm giving away between 10-30 whp depending on tune and pump or C16 on the topend cause of it.
That is why those who know will tell you an external gate is superior.
antimullet is offline   Reply With Quote
Old 01-29-2006, 04:14 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....d00000000d.......ya may just need a little more spring on the WG, either a 'helper spring' or a different WG actuator with a heavier spring
less boost after wastegate port? silver-sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-31-2007 04:55 PM
Low Idle + Low boost after Stage 2.5 install WRexxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-16-2005 02:21 PM
Low Boost after EBC Uninstall/Boost & EGT Install FPO45 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-28-2005 12:09 AM
Boost Creep after Wastegate Porting rainmanjam Engine Management & Tuning 5 10-03-2004 02:56 PM
Hesitation and Low Boost After ECU Reflash bobski Warranty Issues & SOA Problems 11 03-27-2002 03:18 PM
