Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 01-29-2006, 02:10 PM   #1
simprezl25
Member#: 71647
2002 Bug iD
Default would it bolt up to a 97 2.2l?
hi i was wondering if a 2002 2.5rs tranny will bolt up to a 97 2.2l? i know subarus are really interchangeable and i tried to search if this conversion on the trannys is possible. but no luck,
thanx inadvance.
simprezl25 is offline   Reply With Quote
Old 01-29-2006, 06:09 PM   #2
jamesfacts
Member#: 51282
98 RS
black & blue from parking
No.
Wrong final drive, and the 2.2 is cable clutch, while the 02 is hydro. Swap over a diff and the clutch stuff and you're in business.
jamesfacts is offline   Reply With Quote
Old 01-29-2006, 08:01 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
You're wrong.
You don't have to swap over to a hydraulic clutch as long as you continue to use the push type clutch in your car.
scoobyimprza is offline   Reply With Quote
Old 01-30-2006, 12:56 AM   #4
simprezl25
Member#: 71647
2002 Bug iD
Originally Posted by americanyouth
No.
swap over a diff?? i do have the clutch stuff like the slave cylinder and the cable and spring right???
my situation is that this guy is trying to buy it from me and he has a 2.2
and i dnt want to screw him over. im giving him the tranny, clutch flywheel, clutch bearing, clutch slave cylinder, the spring, and the clutch hose. everything that i took of to do my wrx tranny swap.
so i am wondering if my trany will go on. what is up with that final drive??
Old 01-30-2006, 12:57 AM   #5
simprezl25
Member#: 71647
2002 Bug iD
Originally Posted by scoobyimprza
You're wrong.
so your saying ti will fit into a 2.2 engine?? and i dont have to give him the clutch stuff?? i will anyways but im confused wheather it will fit or not.
Old 01-30-2006, 07:42 AM   #6
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
sang,
your RS gearbox has a hydrolicaly actualated clutch. the 2.2L gearbox has a cable actuallated clutch
he will have to change your gearbox to cable actullation.
easily done, just needs to swap the cable parts over to your gearbox. my friend has done it before.
he COULD change his pedal box to hydrolic, that would require him getting a clutch master cylinder and a pedal box assembly for a hydro clutch.
not hard.
all ej motors and ej gearboxes are friends.
swapstar is offline   Reply With Quote
Old 01-30-2006, 09:03 AM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Is the 2002 RS transmission a pull type? He'll just need the clutch, flywheel, and pressure plate. He'll need to find a non-hydraulic clutch fork though.
I KNOW he doesn't need to swap out to a hydraulic clutch because I put a 2001 RS transmission in my 93 Impreza and retained the cable style clutch.
Brent
Old 01-30-2006, 09:07 AM   #8
simprezl25
Member#: 71647
2002 Bug iD
Brent
i think it is a push type. the wrx is a pull. so what i am already giving him, which is what you wrote will be fine?
Old 01-30-2006, 09:09 AM   #9
simprezl25
Member#: 71647
2002 Bug iD
Originally Posted by swapstar
sang,
not hard.
hey ho ming hows it going, but your saying that he can swap over the cable parts he needs from his tranny he has already? and it will work fine?
Old 01-30-2006, 11:44 AM   #10
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Yeah, you're right. I got my push and pull mixed up.
Note to self: don't post after just waking up.
Old 01-30-2006, 01:21 PM   #11
jamesfacts
Member#: 51282
98 RS
You're wrong.
No I'm not. You have to either switch to hydro pedals OR switch out the hydro clutch slave cylinder.
Old 01-30-2006, 02:50 PM   #12
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Dude, I'm using an RS transmission with a cable clutch.
Old 01-30-2006, 03:31 PM   #13
jamesfacts
Member#: 51282
98 RS
And a RS hydro slave cylinder? You're missing my point.
Will this bolt up to my 2002 2.5rs? Silver02rs Normally Aspirated Powertrain 8 03-18-2010 11:25 PM
does an 06 sti axleback bolt up to an 05 2.5rs? DZnutz Normally Aspirated Powertrain 10 10-23-2006 11:30 PM
would it bolt up to a 97 2.2l? simprezl25 Brakes, Steering & Suspension 0 01-29-2006 02:09 PM
Will a 2.5rs catback bolt up to a 2.2L ? TurboCharged97L Normally Aspirated Powertrain 4 10-13-2004 04:53 AM
USDM STi Uppipe - Will it bolt up to WRX? Jimbo Factory 2.0L Turbo Powertrain 34 11-04-2003 02:36 AM
