#1 |
Member#: 105925
Vehicle:2009 Infiniti G37x 2003 CBR 600RR |
Hey guys/gals,
I'm in the process of purchasing chopchop's 2004 WRB WRX. I'm already looking for things to add to it. Apparently he has it lowered on espelir springs already. I'm thinkin about rims. What's the ideal specs for: 16"? (5x100, offset? width? tire size? etc.) 17"? (5x100, offset? width? tire size? etc.) 18"? (5x100, offset? width? tire size? etc.) And how about body kits? And performance? DP and EM... good enough?
#2 |
Member#: 75882
Vehicle:2004 wrx white |
18 looks better, but 17 is lighter
bodykit u want just lips or full bumper get catback, intake and bov for sure |
#3 | |
Member#: 36109
W. Canada
#4 | |
Member#: 96793
W. Canada
Vehicle:02 ProTuned TD04 Now with more clunks! |
#5 |
Member#: 105925
I'm not gonna bother with intake or BOV right now. Besides, don't intakes sometimes cause MAF problems? Any negative consequences with BOV?
Performancewise, I'm pretty set on DP and EM... and if I can find a very quiet exhaust, then catback as well. |
#6 | |
Member#: 769
VIC
Vehicle:04 SoBaLo EsTea-ai ZERO/SPORTS/99 GM6/05 BP6 |
#7 |
Member#: 75882
why not intake and bov? intake can improve a lot..
bov just for the sound...i don't think there r a lot of ppl buy turbo cars and don't put bov |
#8 | |
Member#: 96793
W. Canada
#9 | |
Member#: 96793
W. Canada
I switched to an STi axleback to get a bit more growl. Even then, it's extremely quiet - more of a different note than an increase in volume. |
#10 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
^^^^ An intake and atmospheric BOV will make your car run like poo. This is a topic discussed to death, search. I'm sure the OP knows this already.
#11 |
Member#: 56738
VIC
Vehicle:07 Sti Black |
In my opinion, intake and bov's are just for sounds.
I got a K&N intake and loves the sound. I don't feel any gain from the intake though. So far, I've heard that COBB and K&N Short Ram provides the same MAF reading as stock? I'm not too sure though. And I think BOV's are ok if you have a catless setup. If you're doing a downpipe, might as well get your hands on a Uppipe too. ![]() |
#12 |
Member#: 75882
oh..i have a blizt short arm intake..and works very well..no any problem...
i know hks one or some cold air intakes have some problems.. for me, i alwayz think intake and exhaust r the basic aftermarket stuffs for cars.. |
#13 | |
Member#: 5851
VIC
Vehicle:09 Forester XT + NA Miata |
For wheels: 16" - generally for WRX sedans you can safely run a 45-53 offset but I would recommend between a 48 and 53. A 7-8 inch wheel depending on what tire size you want to run. I think for 16's a good 16x7 inch wheel (like raceface was selling) with a 225/50R16 would be great. 17" pretty well same as above. 48-51 offset and 7-8 inch rim. 215-235/45R17 tires. 18" - Get's a little mroe trick as your sidewall is becoming quite low. I just got some 18's myself and they are under 16lbs. I will be putting a 255/35R18 tire on it but would not neccessarily recommend it. Maybe a 225/40 or 235/40 or 245/35 would be my recomended sizes. If you ARE going to 18 I would find a light wheel because they can get attrociously heavy and you are paying a lot for rubber. 7.5-8.5 inch wheel would be good. 48 offset. I would do an up-pipe BEFORE doing a DP. There is a pre-cat in your up-pipe that is beneficial to get rid of (and not advisable to run with a catless DP). A good combination we have done is catless up-pipe, HF Cat or catless DP and EM. For more info on our stuff www.rocketrally.com As said above DO NOT get a BOV or Intake without getting it mapped and even then do it as a later mod. |
#14 |
Member#: 55630
VIC
Vehicle:04 STi Stage 2 PSM |
Tora, what wheels did you get? 16lbs?! Thats really light for 18s! And wouldn't you rub with 255?
Ryan, just buy my Work wheels ![]() |
#15 | |
Member#: 36109
W. Canada
maybe on NA cars... not the wrx |
#16 | |
Member#: 74792
VIC
#17 |
Member#: 105925
What kinda gains are typically experienced by any one of UP, DP, CBE, EM, etc.?
#18 | |
Member#: 96793
W. Canada
But with a 'typical' Cobb Stage 2 setup (TBE, UP, Accessport) you can expect about 285 HP at the crank. Go to www.cobbtuning.com if you're curious... |
#19 | |
Member#: 61255
VIC
Vehicle:2002 WRX dirty silver |
#20 | |
Member#: 74792
VIC
<--- Is enjoying his APS intake. RR tune ftw ![]() |
#21 |
Member#: 75882
anyone can tell me if run with aftermarket intake on a wrx..what is problem, i haven't seen that topic :-(
#22 |
Member#: 61255
VIC
They can cause the engine to run really lean and detonate, which will destroy internals over time. Listen for the sound of marbles in a tin car when you're on the throttle.
#23 |
Member#: 75882
thx...i really don't know get aftermarket intake will cause that problems...
r all the aftermarkets have that problems, i only know hks one will gets that problem.. that is too bad :-( |
#24 | |
Member#: 62327
VIC
Vehicle:2005 WRB STI [S600BY] |
I ran my STI with K&N typhoon, and my EGT gauge never peaked above 850c. MY Plx wideband shows the same AFR graph as the stock. I might just be lucky. But either way its off the car. |
#25 |
Member#: 5851
VIC
ChopChop, they are SSR Comp's.
| Thread Tools | |
| Display Modes | |
| Any filmmakers here? Looking for documentary advice. | DoctorNick | Off-Topic | 0 | 06-26-2007 05:36 PM |
| Looking for some advice.... | bouncingsoul23 | Factory 2.0L Turbo Powertrain | 3 | 12-16-2004 04:43 PM |
| Hi... looking for some advice.. | Meezepeez | Newbies & FAQs | 13 | 11-12-2004 01:23 PM |
| Now Taking bets. How long will my 4AT last??? Also looking for some advice... | jared nelson | Transmission (AT/MT) & Driveline | 1 | 11-15-2003 07:13 AM |
| Hey Folks, looking for some advice? | Templar | South East Region Forum | 15 | 06-12-2003 08:21 PM |
