Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 12-04-2005, 06:50 PM   #1
hilfiger4you
Member#: 93015
02 wrx
black
Default What is the best way to get rid of brake dust
Hi, I am trying to sell my bbs wheels and I want to clean to brake dust off before I ship them. Anyone have any ideas with the best way of cleaning. During car washes when I used the eagle one brake cleaner, it wasnt that easy to get it off. Any suggestions?
thanks
hilfiger4you is offline   Reply With Quote
Old 12-04-2005, 07:01 PM   #2
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
thanks
I usually spray meguairs wheel cleaner..spray off and take soap and water
and clean them up.
enewtabie is offline   Reply With Quote
Old 12-04-2005, 07:14 PM   #3
Silver_Bell_WRX
Member#: 7677
2005 WRX
One other way to get off some of the heavy deposits is to spray WD-40 on it let it sit for a min or 2 and then wipe way with a rag or sponge and water.
Silver_Bell_WRX is offline   Reply With Quote
Old 12-05-2005, 09:56 AM   #4
hilfiger4you
Member#: 93015
02 wrx
black
Do you all think the Simple Green engine degreaser will work for the rims?
Old 12-05-2005, 11:56 AM   #5
th1rd3y3
Member#: 83054
'11 SWP
STI
There are actually some Mr. Clean magic erasers made for wheels that work pretty well.
th1rd3y3 is offline   Reply With Quote
Old 12-05-2005, 12:53 PM   #6
subieworx
Member#: 47769
Sandblasting. That will definitely get the brake dust off.
subieworx is offline   Reply With Quote
Old 12-05-2005, 12:54 PM   #7
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
I wouldn't use that. I pulled paint off my alternator when I cleaned my engine.
Old 12-05-2005, 01:11 PM   #8
roofis
Member#: 33371
if you use wheel wax to wax up your wheels (after they're spotlessly cleaned of course), brake dust should wash off pretty easily the next time around.
this comes recommended by the Meguiars crew from this past Oktoberfest...it's a Bimmer thing.
never tried it myself cause my daily driver RS wheels aren't worth that kind of effort. when my track wheels come then i'll give it a shot. i've not found simple green to be strong enough to get off brake dust and even normal grit at times.
roofis is offline   Reply With Quote
Old 12-05-2005, 01:38 PM   #9
Pete Holt
Member#: 12
2013 G37S 6spd sedan
Moonlight White
I tried putting wax on the rims (after they were clean) on one side of the car to see if it would make a difference. No noticible difference. All of the above mentioned wheel cleaners seem to work pretty well. Try using a sponge intended for cleaning bugs off the front of your car. This would be one of the sponges that has a mesh cover on it. These always seem to work really well for me.
Pete Holt is offline   Reply With Quote
Old 12-05-2005, 01:39 PM   #10
subieworx
Member#: 47769
I do this every winter when I pull off my summer wheels. It does work well.....although my wheels are mostly black so I wouldn't really notice anyway.
Old 12-05-2005, 01:56 PM   #11
jweiss
Member#: 31636
2005 STi & '82 911
CGM & rosewood
I use regular old Simple Green on my Fikses (not engine degreaser).
jweiss is offline   Reply With Quote
Old 12-05-2005, 02:19 PM   #12
2006STI
Member#: 96540
2006 STI
Crystal Metallic
i use the michelin 3 step wheel cleaner and it works very good. in the kit step 2 is like a top coat that make brake dust easier to remove on next wash. i also use step 2 on my brembo caliper.
2006STI is offline   Reply With Quote
Old 12-05-2005, 03:01 PM   #13
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Hehe. Last time I really cleaned my rims, I used a dishwasher sponge. I don't know what kind of pads are in there right now (haven't replaced pads yet, bought car used) but they are dusty. and it's always caked on pretty strong
bl_easy is offline   Reply With Quote
Old 12-06-2005, 04:12 PM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Old 01-28-2006, 12:46 PM   #15
hwy61
Member#: 87950
2005 STI
Gone....Somewhere in MS
Haven't used the Michelin stuff but none of the above will clean the really tough brake dust. I've used electric drill and pad with cleaner wax, WD 40, a host of wheel cleaners, cleaning pads, dremel with various buffing compounds, etc. It only comes off when you basically grind it off and into the paint. Best trick, if you want em clean, keep em clean regularly, really reglarly. I think hot brake dust from track racing contributed to mine really sticking. The only other thing I can think of is something that will dissolve the brake dust compound, whatever it is, without eating up the wheel. Any ideas???????
Yeah, sandblasting would probably get it. Hwy61
hwy61 is offline   Reply With Quote
Old 01-29-2006, 07:49 PM   #16
80884
Member#: 56783
2004 sti
Aspen white
If degreaser doesn't cut it then try this...BUT ONLY IF YOU OR SOMEONE KNOWS WHAT THEY ARE DOING....I got mine pretty clean using degreaser and a brush, but they had some sticky sheit on them from when i bought the car idk what it is but it's a bitch to get off and if you don't get it off your wheels will be a bitch to clean for the life of them....here is what I did...
1. spray with degreaser, let on wheel for no more than 1 minute, rinse wheel.
2. spray degreaser on brush, scrub wheel sections at a time rinsing after each section.
Still not clean?
3. get some paint thinner or laquer thinner and a good rag, also something to get this stuff of after about 5 sec of it being on the wheel. wipe wheel with rag wet with thinner, imeadiatly wipe dry or rinse, both if you like your clearcoat
4. after the wheel is spotless, check to make sure you didn't eat the clear coat off of the wheel, if you didn't then cool proceed to step 6. If you did, on to 5.
5. have someone reclearcoat the wheels
6. Buy this stuff and put it on the wheel before using it again. Anti-brake dust ha ha This stuff is amazing and can be used on most of the outside of the car, even windows. After using it on the wheels a simple spray from the hose removes the dust, if i let the dust build up for a while i may have to wash the wheels like the rest of the car and then back to clean. 300 times easier to clean than when i bought the car.
Again DO NOT do this if you don't know how to use the thinner so that it doesn't destroy the paint on the wheel. Ok i'll just say use at your own risk, if it messes up the wheel it is user error cuz mine were fine after i did it.
80884 is offline   Reply With Quote
Old 01-29-2006, 09:01 PM   #17
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I bought those out of curiousity, they fell apart on one wipe. maybe i used it wrong...
moogoob is offline   Reply With Quote
Old 01-30-2006, 08:07 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
how about a can of brake cleaner?
the non-chlorinated stuff is basically tolulene, xylene, acetone. try it on an inside section of the rim to make sure it won't eat up too much of the finish. since it's basically aromatic hydrocarbons it evaporates very rapidly. spray it on a rag and i will guarantee it will cut the brake dust.
Old 01-30-2006, 03:20 PM   #19
Alpha two
Member#: 106224
SHINiEE
Pay the neighbor kids to do it. Then next time by some cleaer running pads. I put Axis pads on with my silver ssr's. What a gooey mess.
Alpha two is offline   Reply With Quote
Old 01-30-2006, 04:21 PM   #20
wwiifanatic
Member#: 104421
I normally just clean brakedust off with soap/water.
For a "degreaser" I've used Hondabrite Motorcycle Cleaner which works wonders on the motor, but I haven't tried it on wheels. You can get it at any Honda motorcycle dealer....kinda expensive at $13 a bottle.
wwiifanatic is offline   Reply With Quote
Old 01-30-2006, 07:07 PM   #21
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
...and the brakes too
nhmtns is offline   Reply With Quote
Old 01-30-2006, 07:48 PM   #22
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
You don't need to go to that extreme.
A pressure washer will do.
bemani is offline   Reply With Quote
Old 01-31-2006, 11:44 AM   #23
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
poorboys spray and rinse......., clay bar, and poorboys wheel sealant x2 or zaino z2 pro x2 or rejex x2
bren wrx is offline   Reply With Quote
What is the CORRECT way to get rid of wastegate flutter? XWRATED Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-25-2006 09:03 AM
What is the best way to get rid of love handles? waitandbleed92 Off-Topic 34 10-15-2004 07:51 PM
What is the best thing to get rid of spyware and adware? HalfBaked Off-Topic 44 06-25-2004 11:45 PM
So what is the best way to get rid of those damned Cats without triggering CEL? IncubusDude Newbies & FAQs 9 04-18-2002 02:11 PM
best way to get rid of brake sqeak? nitrohuffer Legacy Forum 2 07-09-2001 08:16 PM
