Old 01-30-2006, 12:15 AM   #1
craver
Member#: 77905
2005 WRX
WR BLUE
Default 05 sti steering rack can fit 05 wrx?
Sorry guys nt sure if this is a repost. Just wondering wha the difference other than lock to lock . I like to know if this is interchange in betwwen this 2 model or do i need to hack n modify to do to install it? Thank
craver is offline   Reply With Quote
Old 01-30-2006, 12:21 AM   #2
Member#: 67
1999 Outlasting
the competition.
I stand corrected!
i just checked the 06 TR we have here and it has the same hard mount style as the 05 STi
sorry for the confusion
Tom
Old 01-30-2006, 12:26 AM   #3
craver
Member#: 77905
2005 WRX
WR BLUE
Nt doubting yr expertise but i do come across some mention 04 sti cant bolt on 05 wrx ??
Old 01-30-2006, 12:35 AM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I know somebody who did it!
send a PM to "Carnot" for more info on how he fitted a 2004STi steering rack to his WRX wagon.
nhluhr is offline   Reply With Quote
Old 01-30-2006, 12:45 AM   #5
craver
Member#: 77905
2005 WRX
WR BLUE
Thank bro PM him .
Old 01-30-2006, 09:08 AM   #6
REX8
Member#: 24038
Originally Posted by [email protected]
i'm pretty sure it will not fit. the 05-06 STi has a different mounting setup than the WRX. the 04 STi rack will fit.
Tom
04 STi and 02-04 WRX's have the "old" setup.
05 WRX's got the new improved setup, same as the 05 STi.
So....if you have an 02-04, you need an 04 rack (for an easy swap) and if you have an 05 wrx, you can use an 05 STi rack.
Old 01-30-2006, 09:14 AM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
^ that's my understanding too. In 05 both the WRX and STi got the "revised" style rack (and a new crossmember asa well).
You might also search the thread Fred started- he is pretty sure the 05's already have the quicker rack (I'm not 100% convinced yet, but worth reading).
Old 01-30-2006, 09:36 AM   #8
craver
Member#: 77905
2005 WRX
WR BLUE
now i really confused
So meaning 05 sti rack to 05 wrx no problem bolt on ??? 04 sti cant do it on 05 wrx ??
Hi there BIGSKYWRX which fred u talking about can u shoot me the thread pls thank .
Old 01-30-2006, 09:54 AM   #9
BIGSKYWRX
Member#: 7958
09 GH B+
No real confusion In 05 Subaru redesigned the steering racks for the WRX and STi (maybe RS too?)- new cross members as well- this is the reason the steering rack bushings are different on the 02-04's vs 05+'s.
There is some debate whether the 05 WRX got the quicker rack (15:1)- there is no debate it got the "new style" rack
More on the ratio debate
http://forums.nasioc.com/forums/showthread.php?t=923591
Old 01-30-2006, 02:08 PM   #10
Carnot
Member#: 34596
'05 WRX Wagon PSM
'03 WRX Sedan PSM (Hers)
Just to clear up potential confusion, the '04 rack went into my old '03 wagon without any issues. An '04 rack definitely would not fit into my '05 wagon.
-Bryce
Carnot is offline   Reply With Quote
Old 01-30-2006, 02:31 PM   #11
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I was under the impression that the 05STi was the only one to receive the new mounting style. Thanks for clearing that up, y'all!
Old 01-30-2006, 02:58 PM   #12
BIGSKYWRX
Member#: 7958
09 GH B+
We got theat cleared up, but still don't ahve the ratio pegged for the 05 WRX- I've got a email into John Mergen- see what he says
Old 01-30-2006, 06:58 PM   #13
REX8
Member#: 24038
-Bryce
Question for you...was it an 04 Sti rack? And if so, did it feel as quick as your stock 05 wagon rack?
Old 01-30-2006, 07:35 PM   #14
Fred
Member#: 3560
06 STi, 02 WRXes
94 Open Light 2.5RS
Make sure you read the last post by Fred in the "debate thread" before you go any further.
If you have a 2.7 turn lock-to-lock rack, and you swap the 05 STi rack into its place all you'll do to your car is increase its turning radius.
Fred is offline   Reply With Quote
Old 01-31-2006, 10:20 AM   #15
Carnot
Member#: 34596
'05 WRX Wagon PSM
Yes, it was an '04 STi rack that was installed in the '03. I couldn't really tell a difference when I first got the '05. I thought it was because there was a period of about 3 months between when my '03 was incapacitated and when I bought the new one. From the conclusions in the other thread however, I guess the reason is that the ratios are almost identical. Sweet.
-Bryce
Old 08-15-2006, 02:37 AM   #16
xS2k
Member#: 85112
Any way to modify the 05 steering rack to make it fit the older 93-01 impreza?
Would the 04 rack be bolt-on for GC8?
xS2k is offline   Reply With Quote
Old 08-15-2006, 10:19 AM   #17
BIGSKYWRX
Member#: 7958
09 GH B+
I'm guessing if you had a 05+ crosss member it would bolt up, w/o it I don't think so.
I believe a few guys have bolted up the STi rack- there is one for sale (or was anyways) that a guy had in his GC- I think he had to swap a gear- otherwise it was a straight up bolt up.
Old 08-15-2006, 06:51 PM   #18
Angry Toaster
I'm not angry
Member#: 62555
1993 FD3S
E92 / CBR600RR
Yeah, I had it for sale. It's gone now. The "fine" splined GD pinion shaft in the STi rack has to be swapped out with it's older GC counterpart. Otherwise the only way to get one to work is to use a GD steerting column.
I'm actually installing an '06 STi rack/crossmember into my Forester tonight. Good times.
Angry Toaster is offline   Reply With Quote
Old 08-15-2006, 07:59 PM   #19
BIGSKYWRX
Member#: 7958
09 GH B+
^ your on the cutting edge!
Old 08-15-2006, 08:26 PM   #20
silentbob343
Member#: 57307
Thanks for the info Angry Toaster. Next question, how hard would it be to use a GD steering column in the GC? Would you say swapping the splined shaft is the easier solution than swapping the entire column?
silentbob343 is offline   Reply With Quote
Old 08-16-2006, 03:41 AM   #21
Angry Toaster
I'm not angry
Member#: 62555
1993 FD3S
E92 / CBR600RR
I think using the GD steering column is the way to go. They bolt right into a GC... the only problem being the key mechanism. The way around that is swap out the mechanism from the GC column to the GD column.
Well, the '06 STi crossmember and steering rack are in my '01 Forester... along with a GD steering column. I'm beat.
Old 08-16-2006, 03:49 AM   #22
silentbob343
Member#: 57307
Very cool and great info, you are an asset to the community
Old 10-01-2006, 06:56 PM   #23
limeylight
Member#: 5428
97 Legacy Outback
so maybe this would work on my 97 Legacy?
limeylight is offline   Reply With Quote
Old 10-12-2007, 11:55 PM   #24
DirtstyleWRX
Member#: 18212
Angry Toaster, can you elaborate on the process of installing your 06 sti rack/crossmember into your forester? I also have an 06 sti rack/crossmember in hand and am planning to install it in my 02 wrx. I was hoping to gain some insight before jumping into it.
DirtstyleWRX is offline   Reply With Quote
Old 10-16-2007, 05:27 PM   #25
DirtstyleWRX
Member#: 18212
Thanks for the PM Angry Toaster, I plan on installing my steering rack confidently this weekend
Will an 05 sti steering rack fit in a 2001 Outback carpfish Brakes, Steering & Suspension 6 12-16-2009 04:02 PM
Complete 05 WRX front brakes, 05 STi Steering rack, LSD, and MORE!!! xS2k Suspension/Brakes/Handling 22 09-03-2006 06:17 PM
Convert a 05 STi Steering rack over to a 04 rack hard or easy? 2-quick4u Brakes, Steering & Suspension 1 02-12-2006 07:54 AM
quick question. only a 04 sti steering rack will fit into a 02-03 wrx?05 sti wont? garie Transmission (AT/MT) & Driveline 2 02-04-2006 04:41 AM
05 STi steering rack in 04 WRX jebjkey Brakes, Steering & Suspension 4 07-17-2005 11:17 PM
