#1 |
Member#: 38459
Vehicle:98 OBS White |
Is there any way to swap the bumper from a bugeye to my 98 OBS? Is this physically impossible?
I am just trying to do something that I haven't really seen. If not, does anyone know where I can get a STI version 4 front bumper? slip
#2 |
Member#: 18941
NWIC
Vehicle:2005 Lotus Elise Orange |
Physically impossible. The GC bumper is flat all the way across, while the bugeye bumper has a circular cutout bit where the headlight is...
![]() ![]() The V.4 bumper skin isn't very expensive from the dealer at all. But you will need to get a JDM or RS bumper beam (although the JDM beam isn't very safe, nor is hacking up your stock beam) |
#3 |
Member#: 29355
NWIC
Vehicle:2003 GD6 Hate chall but i'mma maintain |
V4 skins are sold by US dealers? hot damn!(/skeptical sarcasm)
and you can make it fit, just like any bumper, but you'll have to get a body shop that's capable of cutting, glassing, and bolting everything together so it looks right... then you'll need to paint it... and all that custom work really is only going to last as long as the craftsmanship allows... which more often than not is not long. my all-time biggest regret was ditching my cracked and bent stock front bumper for a replica fiberglass front bumper- it's a hassle, looks worse and worse everytime it gets hit and i would honestly rather be driving around in my busted stock bumper than the custom fitted replica. while some of these woes would be different with an OEM piece custom fitted, it would be way more work than it's worth. source a v4 or v5 bumper (or a V6 but i'd recommend a V5 because they're plentiful stateside) and put that on, instead of the bugeye. you'd have to cut the contours of the bugeye, fiberglass in the proper fitting top section from your stock bumper, and then cut, trim, and bend the rest of the bugeye bumper to fit your beam and fenders. it would not be easy, it would be costly, and honestly i don't think it would look very good. |
#4 |
Member#: 18941
NWIC
Also have to take into account total widths, I'm not sure how the two cars compare (also, wagon/sedan bumpers are different for bugeyes)
And yes, US dealers can get you V.4 bumper skins, I think they're something like $70-90 or so? I don't quite remember. And from what I found searching on here, looks like it *may* fit on your OBS bumper beam, but don't quote me on that, cause I'm not sure. |
| Thread Tools | |
| Display Modes | |
| 98 RS-T Engine/Trans/Suspension Swap w/ 98 OBS | RS25Tuner | Subaru Conversions | 4 | 10-04-2004 03:27 PM |
| ('93-'01) clutch info on 98 OBS? | geepondy | Impreza Forum | 8 | 02-06-2004 12:34 PM |
| ('93-'01) Safety Question on 98 OBS | Jejunum | Impreza Forum | 4 | 09-09-2003 12:29 PM |
| s-afc 'blue wire mod' on 98 OBS...i think i messed up...help! | IMPREZAmike | Normally Aspirated Powertrain | 3 | 07-23-2001 05:13 PM |
