Old 01-30-2006, 02:32 PM   #1
pedru
Member#: 84354
2003 impreza WRX
blue mica
Question Block short 2.5 in a wrx 2004
HiĦĦ
I'm from spain.
Sorry for my language,i dont speak english very well.
I want to put a short block 2.5 in my car.
I have reading this forum,but i dont understand many things.
If someone talk spanish,can to talk with me([email protected])
Really i want to know all that i need to do,for to can put,this block in my car.
I have a Helix complete exhaust 3",Turbo td04(stock) and apexis.
I need a gaskets of the 2.5 or a gaskets of the 2.0????
About the compresion?? i dont understand nothing.
Best regards and many thanks for all.
pedru is offline   Reply With Quote
Old 01-30-2006, 06:41 PM   #2
norexyet
Member#: 39149
11 elantra
yea i said elantra
The shortblock swap is pretty straightfoward, you keep your wrx ecu. You can use thicker headgaskets to keep compression where you want. Id suggest going with cometic ones. Id shop for a bigger turbo, injectors, and engine management as the 2.5l will own your stock turbo.
norexyet is offline   Reply With Quote
Old 01-30-2006, 09:11 PM   #3
ejh25
Member#: 65267
Puedo hablar un poquito. Hay mucha gente aqui se pueden hablar espanol mucho mejor de yo si no puedo explicar parte de tus preguntas.
Para tener lo mismo compresion, se puede usar el 2.5 block con pistons differentes o un gasket de cabeza (?) mas ancho de OEM.
Habla con Bigvalley auto en Puerto Rico: www.bigvalleyauto.com. Ellos usan blocks de Crawford Performance.
ejh25 is offline   Reply With Quote
Old 01-31-2006, 08:11 AM   #4
pedru
Member#: 84354
2003 impreza WRX
blue mica
muchas gracias
Somebody know if the gearbox of wrx,are god for this block.
What is the press max of boost,that i can to put for dont break the gearbox???
I want to buy the block short 2.5 of rennickmotorsport,and the head gaskets and the head studs of gruppe-s.It is good for to can mount the block??
Old 01-31-2006, 10:36 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
http://forums.nasioc.com/forums/showthread.php?t=915612
local friend and he is on stock transmission
99 legacy 2.5 in 04 wrx? spinplay01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-12-2009 12:36 PM
V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads? saab-on-the-cobb Subaru Conversions 6 09-18-2006 07:03 PM
2.5 block with 2.5 heads((help)) awdhondakiller Subaru Conversions 1 07-03-2006 03:22 PM
2.5 STI block v 2.5 na blacktalon606 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 04-20-2006 11:54 AM
Has someone changed a block 2.0 for a 2.5 in a wrx? pedru Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 01-30-2006 05:33 PM
