Closed Thread
Old 01-30-2006, 05:36 PM   #1
badblackwrx
Member#: 102565
2002 MBP JDM V7 6SPD
2.5 HYBRID + BREMBOS
Default dual exhaust wrx sound clip
Here is my dual exhuast sound clip. It was taken at midnight mayhem at las vegas motor speedway. We are going to redo the clip considering how dark it was (you can barely see the dual tips on the pavement shadow) and the stadium had music blaring at the same time. Anyways, I also made some passes while I was there. The slip below was my race against a mopar stage 1, 2.4 turbo, 5 speed pt cruiser (Basically a heavier neon srt-4). My mods are K&N drop in filter, perrin uppipe, custom catback, 18" koneg spec w/225 40 18 kumho ecsta asx, tein s-tech springs and cobb stage 2 brake upgrade. Bosal down and cobb accesport to follow when I get the cash. As you can tell I demolished him off the line, but once he hooked his fronts he started to gain on me .
badblackwrx is offline
Old 01-30-2006, 06:05 PM   #2
disaster999
Member#: 73197
SWEET SOUND! i love it!
but i think you could of done better with your 1/4 mile time with those mods...dont a stock wrx have the same time?
disaster999 is offline
Old 01-30-2006, 06:17 PM   #3
scrmblr2
Member#: 24631
2005 STI
Default it is all in the 60'
Based on your timeslip, you should be able to drop almost .25 to .5 sec from your 60' time. just dont drop the clutch, or burn it up by slipping it too much.
scrmblr2 is offline
Old 01-30-2006, 06:19 PM   #4
badblackwrx
Member#: 102565
I love the sound this thing makes. The same night, a completely stock 05 wrx was making passes in the 14.90-15.00 at 90 mph. But I am not the best drag racer in the world. When my car was two months old I took it to the drags in st george utah and ran a 15.31 @ 90.12 mph. Minus the altitude and my mods, plus the extra rotating mass of my wheels. I think it sounds reasonable. A pro driver would definately make a faster time.
Old 01-30-2006, 06:21 PM   #5
timmah
Member#: 54203
2011 WRX
he's still running the stock downpipe and no EM.
timmah is offline
Old 01-30-2006, 07:51 PM   #6
jandree22
Member#: 100800
That exhaust is bangin! Good lord is that ever sweet.
Here's my question, other than the WRX reving quicker, would the same exhaust taken off the WRX and put on a 2.5i sound the same or very similar? I'm guessing the throaty aggressive growl is due to the boxer configuration much more so than whether or not a turbo is involved?
jandree22 is offline
Old 01-30-2006, 09:04 PM   #7
badblackwrx
Member#: 102565
Thanks, My exhaust is unique to my wrx and seems to have a bit more "growl" than manufactured exhaust systems, but something similar should sound about the same regardless of displacement or turbo.
Old 01-30-2006, 09:25 PM   #8
jandree22
Member#: 100800
Can't argue with that... your exhaust is one of the best I've ever heard. On any car.
Old 01-30-2006, 09:42 PM   #9
REX8
Member#: 24038
Any way to get rid of that rattle? Besides that, sounds nice....
REX8 is offline
Old 01-30-2006, 09:53 PM   #10
04Interceptor
Member#: 78657
yah swwtlkjlskjg
04Interceptor is offline
Old 01-30-2006, 10:16 PM   #11
badblackwrx
Member#: 102565
The rattle is actually the camera. We are going to do a better clip this saturday.
Old 01-30-2006, 10:35 PM   #12
USF97J4x4
Member#: 83035
Ill take the sound of my spt over that anyday, but it does sound nice. Plus points for uniqueness
USF97J4x4 is offline
Old 01-31-2006, 12:55 AM   #13
SiC Stoner
Member#: 99068
05 Wrx
I would like to see your times after you go stage 1...... and then stage 2...
SiC Stoner is offline
Old 01-31-2006, 02:50 AM   #14
badblackwrx
Member#: 102565
That very well may be possible, because I plan on the accessport first, then I'll probably take it to the track. Then I'll get the downpipe and go stage 2 and go to the track. Now if that darn money tree will start producing...
Old 01-31-2006, 04:49 AM   #15
dj_booduh
Member#: 70861
2005 Scoobie WRX
I thought that wrx's ran low 14's stock. If were running in the 15 second rnge then it seems that my 05 isn't much faster than a freaking intergra? Say it ain't so
dj_booduh is offline
Old 01-31-2006, 09:24 AM   #16
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Silly.. don't you know that the PT Cruiser is t3h 2nD f4st4R!
Calamity Jesus is offline
Old 01-31-2006, 11:56 AM   #17
badblackwrx
Member#: 102565
Your car is a lot faster than an integra, but what you are comparing is the difference in sea level and driving skill. At sea level with a professional driver your times should be similar to the numbers below. If I converted my times to sea level they would be 14.415 @ 95.57, even with my 18s. Trap speed indicates horsepower and time indicates the quality of launch and driver skill.
2002 Subaru Impreza WRX Sport Wagon
Drivetrain layout Front engine, awd
Engine type Turbocharged F-4, alum block/heads, LEV, DOHC, 4 valves/cyl
Displacement, ci/cc 121.7 / 1994
Max horsepower @ rpm 227 @ 6500
Max torque @ rpm 217 @ 5000
Transmission 5-speed manual
Suspension, front; rear MacPherson struts, anti-roll bar/Chapman struts, dual-link, anti-roll bar
Brakes, f;r 11.4-in vented disc; 10.3-in solid disc, ABS
Wheels 16x6.5-in cast alum (std)17x7.0-in cast alum (opt)
Tires 205/55R16 Bridgestone Potenza RE92 (std) 215/45R17 Bridgestone Potenza RE011 (opt)
Curb weight, lb 3165
Seating capacity 5
Cargo capacity, cu ft 27.9 / 61.1 (up/folded)
Fuel capacity, gal 15.9
Test Data
(std 16-in tires / opt 17-in tires)
0-60 mph, sec 5.8 / 5.9
1/4 mile, sec @ mph 14.44 @ 93.41 / 14.62 @ 92.31
Braking, 60-0 mph, ft 125 / 125
600-ft slalom, mph 63.0 / 65.0
On my first run of the night I ran a 14.815 @ 92.66 against a bone stock 2004 acura rsx-s 6-speed. He ran a 16.581 @85.73, but he was having trouble launching. Last time I checked the rsx-s is faster than an integra.
Old 02-22-2006, 01:34 PM   #18
BigMikeLV
Member#: 99301
2010 2006 B9 Tribeca
BigMikeLV is offline
Old 02-22-2006, 01:38 PM   #19
subarukid19
Member#: 101386
02 WRX
Very nice, love the sound.
subarukid19 is offline
Old 02-22-2006, 01:40 PM   #20
GottaREX
Member#: 43963
2014 Subaru Impreza
Gun Metallic Gray
Well if you had a single exhaust = less weight than a dual exhaust. Dual Exhaust is really pointless to have on a WRX unless you're just goin for looks. Also loose the 18in heavy Konigs and put your stock WRX rims, you might get into the high 13s .
GottaREX is offline
Old 07-06-2006, 04:07 AM   #21
dunnzter428
Member#: 119409
06 wrx tr
steel gray
Seating capacity 5
Test Data
my best time was 14.4 in my 06 wrx bone stock...
dunnzter428 is offline
Old 07-06-2006, 05:10 AM   #22
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
And you are in Ca. right? So whats the big deal?
Ohh, and why did you bump a thread that had no activity for 5 months to say that?
D fresh is offline
Old 07-06-2006, 09:13 AM   #23
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ancient thread, wrong forum, bye.
Mulder is offline
Closed Thread
Custom 05 Legacy GT exhaust and sound clips Endlesshine Legacy Forum 0 08-10-2004 11:31 AM
TurboXS RFL for WRX sound clips? sc00by Newbies & FAQs 5 09-17-2003 02:36 AM
HKS Hiper exhaust Video/Sound Clip inside Archangel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-05-2003 12:54 PM
BPM TT Full Exhaust for WRX - Sound Clip / Comments? mike_2002WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-24-2001 09:35 PM
