Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 01-30-2006, 06:05 PM   #1
flwrx
Member#: 35944
'03 6MT WRX
MBP
Default H6 swap into bugeye info needed
Im looking for more information on the H6 swap. I know perrin is running one, but cant seem to find any more info on it. You can source these motors complete for only 2k, so it seems like building the internals and boosting it would yield great results for the money.
If anyone has any info or links that would help my research, Id appreciate it.
flwrx is offline   Reply With Quote
Old 01-30-2006, 06:14 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
call PDXTuning we can build you one what type of info are you looking for, we are doing 3 of them 2 in bugeyes, one in my legacy.
ask your questions and I can answer them for you.
Ben
Old 01-30-2006, 08:12 PM   #3
Nick W
Member#: 30601
2003 WRX RW
Default h6 swap
Hello,
I have been curious about this swap, are there custom motor mounts or is it a new sub frame. what kind of cost is there to the swap? ball park of course
Nicholas
Nick W is offline   Reply With Quote
Old 01-30-2006, 08:39 PM   #4
flwrx
Member#: 35944
'03 6MT WRX
MBP
Ben
thanks but im poor; gotta build it myself
I guess I just wanna know the basics. What kind of fabrication if any is needed to get it in the engine bay? What would I use for motor mounts? Would I need to swap in H6 wiring harness, and I assume Id need to run a standalone? Does PDX or Perrin make any turbo H6 exhaust bits or would I have to do custom? What kind of space b/w engine and firewall is there? Can you share any engine bay pics of one installed?
and basic noob questions about the motor itself.....compression ratio, semi-closed deck, can they handle any boost in stock form? Whats the strength of pistons, rods, crank and does anyone make aftermarket parts for it?
I have a feeling if Im gonna do it I need to do it now.....before it becomes too popular and the price for H6 motors rises substantially.
Thanks
Old 01-31-2006, 07:22 AM   #5
Slack
Member#: 17548
If you're poor, don't even consider this swap. Period! EJ205 and EJ257 swaps are easier and less expensive.
There are no fabrications needed to mount the 3.0L H6 into your engine bay.
My H6 came with motor mounts, but if not you should be able to order them from your local dealership (use 2005 Tribeca or H6 Outback for parts look-up).
Can't help you on the wiring harness, but you will need to run a stand-alone ECU. I've explored the options and Hydra is what I'm using.
I would go custom if you have a trusted exhaust shop or if you are experienced with welding and/or exhaust work.
I don't have a WRX, but my engine bay isn't much different. Search for my name in this forum for my thread. It has many pics to give you a general idea.
Do research and lots of it before you consider going ahead with an EZ30 project. I repeat that it will not be cheap. You will want to replace the internals on the EZ30 to lower compression which adds to the expenses.
Thanks
Slack is offline   Reply With Quote
Old 01-31-2006, 11:36 AM   #6
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
meh .. they have sold 17k tribeccas since may .. its only gonna get cheeper
the imobilizer makes he stock ecu basicly useless thus the need for the hydra
Old 01-31-2006, 12:52 PM   #7
flwrx
Member#: 35944
'03 6MT WRX
MBP
thanks for the info man. pretty much all the answers I expected.
I do however, think there is a possibility of the cost of H6's increasing with the popularity of the swap. I recall 6-speeds, JDM or US, being not so outrageous in cost back in 2004. Now we've had those transmissions in the US for 3 years and the price has gone up not down. Kingpin is already selling H6's for $3000.
Old 01-31-2006, 01:14 PM   #8
kheff46
Member#: 66739
2002 WRX wagon
same space as 4 banger to firewall(read room for turbo). get the stock ecu and harness plug it in, and drive it(thinks its an H6 leggy). any suby motor mounts work. and stock wrx rear exhaust with custom front to mate right.
linaracing.com has their build(very basic) for rally, and i've contemplated it seriously. car-part.com has H6's for cheaper than i've found elsewhere. check local junkyards for parts, and save tons$$$
kheff46 is offline   Reply With Quote
Old 01-31-2006, 03:27 PM   #9
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
ignore this post almost everything in it is wrong
its longer fan clearance to the radiator is very close
the stock ecu will work with the ez30 but not the ez30r (read slack's build up)
Old 01-31-2006, 03:38 PM   #10
kheff46
Member#: 66739
2002 WRX wagon
jaxx- it has been done this way whether you like it or not!
correct- same space to firewall as ej20/22/25 etc.
correct-any impreza exhaust will work with minor sections added. it's an impreza!
correct-an H6 with an H6 ecu runs whether you install it in a grocery cart, or on my bicycle! c'mon are we gonna go thru this? just like a brake system rhd/lhd dosen't matter. if the system works, it works whether on your granny's walker, or whatever!
ez30 is different than the R, i know this and have known for a year or so. the fan thing is why i gave a link exposing the EASILY TACKLED PROBLEMS INVOLVED!
Old 01-31-2006, 04:45 PM   #11
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yay pissing match
anyway
firewall clearance is not an issue its dictated by the transmission
flexalight fans work in the front
for that matter a honda exhaust will work but its going to require lots of welding.. its not gonna bolt up- nor is any thing else
ez30r ecus have a rfid immobilizer
if you had read slacks post he ordered all the parts (not cheep) to make a ez30r ecu work but ran into needing the key# added to the ecu rom.. the dealer couldn't or wouldn't do it
if you look at the fsm for the bp/bl legacy the number of connectors/harness under the dash it is astonishing its at least 2x the number of connections of the 1.8L harness
for example bp/bls don't have a speed sensor in the transmission (like every other subau) the ecu it gets its speed signal via can bus from the ABS module
basicly the 05+ is a whole differnt class of complexity
not saying it can't be done just that its not el-quicko-swapo (probbaly the hardest subaru swap ever done)
i am all about breaking new ground and learning things along the way but i would rather warn people about it ahead of time so they don't fall into the same holes that i did ..
it all $$$/time but at some point its simply cheeper/easeier to "go buy a z06"
Old 01-31-2006, 05:04 PM   #12
kheff46
Member#: 66739
2002 WRX wagon
flwrx- he's talking about THE most expensive way to do the H6 swap also. using the newest version possible(read too much$$). please do yourself a favor and research all threads containing H6's and any ej swap requiring wiring. you'll find easier ways to do things than listening to 100 people with 99 different theories!
again linaracing.com has the cheap way(cheapest?? not sure) to go at it. please do some diggin it's in there!
and if someone wanted a Z06 why not just buy one and park it 80% of the year and bitch about not driving it(like all Z06 owners i know!(5)). and it's not that nice of a car, drove 3 of the 5 i see daily. too much $$ just to replace exhaust pieces(read junk car) that are poorly re-designed to utter ineffiency and in a severe realm of ****box uniqueness! best bang for the buck except an sti swap in a gc of course!
oh, shake, shake zip! courtesy flush? nah!
Old 02-01-2006, 03:29 PM   #13
rsk135
Member#: 65578
wow!
I'm going to throw 2 things out there.
First if you just want an H6 (assume ez30r) swap the cheapest most complete way would to be to source a salvage Tribeca or Outback. Like Jaxx said 17k tribecas sold and I've seen several wrecked so far. This still isn't "cheap".
Second, turboing any H6 is all pretty much custom work and is not cheap at all. Not for the faint of heart, heck, PHATsuby has all of PDXtuning's resources at his disposal and he'll probably admit its not easy.
Why do you want to do this?
rsk135 is offline   Reply With Quote
Old 02-01-2006, 05:44 PM   #14
Slack
Member#: 17548
I originally planned on doing a turbo engine swap, but when I was researching different swaps I came upon the EZ30. Gruppe-S had one for a lower price than you can get it now and I put that idea into the mix. At first it seemed like I could do it for less (laughable now) and would be unique by offering a completely different power delivery. I bought one of the first H6's from Gruppe-S and carefully gathered parts until I had a complete setup (I thought) and shortly thereafter I removed my EJ22 and started the swap. That was last May and my car has been down ever since.
I am still quite eager to get the car running soon. It will be a beast, though I will be avoiding any turbos for a few years. Despite exceeding my original budget threefold, it will be worth the effort I've put into it.
Mick
Old 02-01-2006, 06:16 PM   #15
DaBoxerman
Member#: 79019
I just seen an H6 engine at a junk yard (in an old Subaru XT) Would one of these motors work for the swap? Or are there a few major differences in those of the old days, and these of today?
DaBoxerman is offline   Reply With Quote
Old 02-02-2006, 02:22 AM   #16
PHATsuby
Member#: 13617
2001 Legacy GT back
the XT's are 2.7 liter carbuerated motors, so they are a bit different
the EZ30R is not a cheap swap, xeleventy billion if you want to turbo. See my thread in the legacy forum.
I would personally do a EZ30R even if it was just NA with a stand alone, so you could tune some more out of it with the avcs and avls, motors are going for what 1700, hydra is the same, plus exhaust. assuming complete motor, you are looking at 4k likely doing the work yourself thats without tranny.
Basically, even having discounted parts, turbo is insanely expensive and I am doing all the fab work myself. What rsk135 means to say is pdxtuning has me at their disposal LOL.
Ben
Old 02-02-2006, 09:00 AM   #17
rsk135
Member#: 65578
Yeah, sorry Ben. Credit where credit is due.
I still want to know why flwrx wants to do this. I've often thought of a old N/A ez30 swap in my forester. Mostly for the fun and uniqueness of it. But I know I wouldn't spend xeleventy billion dollars to turbo it.
As for old school h6 swaps here's a 2.7 in a brat. Check out the reclined radiator.
http://www.subarubrat.com/mybrat.htm
Old 02-02-2006, 11:40 AM   #18
MrH00nel2
Member#: 80474
2002 Z06
1200whp
what engine management would be used for the H6 if you want to go high HP
can the hydra work?
MrH00nel2 is offline   Reply With Quote
Old 02-02-2006, 11:48 AM   #19
cronic
Member#: 9749
can the hydra work?
Yes, that is what we will be running..
Dave-
cronic is offline   Reply With Quote
Old 02-05-2006, 10:25 PM   #20
adhowe70
Member#: 3363
1982 Reynard
Blue, Red, and White
So, here's a question...
Could you make an EZ30R run on an EZ30 ECU at all? Obviousy the EZ30R ECU requires immobilizer crap, so its worthless. Buuuut, could someone swap the Hydra out and swap an EZ30 ECU in for emissions testing? Specifically, the OBD-II I/M checks.
Theoretically speaking, of course.
adhowe70 is offline   Reply With Quote
Old 02-05-2006, 10:34 PM   #21
TheLegacy
Member#: 47615
2007 BMW 335XI
Saphire Black
its expensive custom project esp if you turbo it but
for anyone interested in turboing this motor, it pulls out some good torque and power for not running such high boost vs a 2.5 or a jdm 2.0
thought about it but not worth it
TheLegacy is offline   Reply With Quote
Old 02-06-2006, 12:10 AM   #22
pennswoodsed
Member#: 86205
1997 obs ,T?
Greyish ,greenish
Smile carb?
[quote=PHATsuby]the XT's are 2.7 liter carbuerated motors, so they are a bit different
No,mpfi thanks
pennswoodsed is offline   Reply With Quote
Old 02-06-2006, 12:33 AM   #23
PHATsuby
Member#: 13617
2001 Legacy GT back
well I stand corrected, thanks for the info.
Ben
Old 02-06-2006, 08:20 AM   #24
Slack
Member#: 17548
I highly doubt it, but you're more than welcome to try!
Mick
Old 02-06-2006, 10:23 AM   #25
adhowe70
Member#: 3363
1982 Reynard
That wasn't the answer I wanted. But it was the answer I expected.
STI Swap into bugeye TS - Checklist SilverJS Subaru Conversions 0 10-12-2009 11:33 PM
EJ207 v7 swap into 06 wrx - need assistance DigitalPunk Subaru Conversions 16 12-05-2008 06:22 PM
JDM ej20g swap into 2000 RS need help keithla4 Newbies & FAQs 2 06-05-2008 10:53 AM
WTB Full 05-07 center console for swap into bugeye, STI steering wheel Hando567 Private 'Wanted' Classifieds 3 03-12-2008 01:38 PM
'05 STi Cluster swap into '05 WRX - need actual install instructions WRblueX_Guy Electrical & Lighting 13 03-24-2007 01:29 AM
Message Board Statistics All times are GMT -4. The time now is 06:13 AM.
