Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 01-30-2006, 09:12 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Ver. 6 STI RA gearsets in stock! ACT and Exedy Clutch combos!
For the first time every in many many moons, we have STi Ver. 6 RA gear sets in stock and ready to ship.
Version 6 STI RA (Special Edition) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- Stronger than stock WRX gears
- 1mm thicker gears
- Cryotreated for added durability
- Replace gears 1-4 (shorter ratios)
- Retains stock 4th and 5th gear ratios
- Better accelleration, same cruising fuel mileage
Version 6 STI RA (Normal) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- 1mm thicker gears
- Replace all gears (shorter ratios)
- Ideal for track
JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box; the way it was designed to be. This conversion will be particularly useful for those of you who regularly track or drag race your car. As I'm sure you've noticed, their is a large space in gear ratios between 4th and 5th gears on the USDM 6spd. This oftentimes causes a grinding when shifting from 4 to 5 quickly because the synchros cannot catch up quickly enough to compensate for the large difference between gear ratios. Professional installation is recommended.
- Excellent upgrade for motorsports guys
- Better accelleration in 5th and 6th gear.
- Eliminates grinding when shifting up from 4th to 5th gear
- Restores 6 spd. to intended gearing
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$319 Shipped for 5/6th Gear Conversion
$769 for rebuild w/ 5/6th Gear Conversion
Genuine Subaru Synchro & Bearing Kit for 6 Speed Manual Transmission (13 pcs) - 04+ STi
We have packaged together the most commonly damaged synchros and bearings for the Subaru STI 6-speed transmission. In all likelihood, if a transmission rebuild is necessary, these synchros and bearings also need to be replaced. Replacing these synchros and bearings can also cure many "mystery" gear box issues such as, "why does my tranny always grind going into 3rd gear," or "how come I sometimes can't shift down into 2nd gear." These are in stock and ready to ship. You can also send us your 6spd. to be rebuilt with these.
- Should be replaced when rebuilding your tranny
- Cures many transmission gremlins
$419 Shipped for Synchro and Bearing Kit
$869 for rebuild w/ new Bearing and Synchro Kit
Save money if you do both at the same time!
$719 Shipped for Synchro and Bearing kit, and 5/6th Spd. Conversion
$1149 for rebuild w/ new Bearing and Synchro Kit, and 5/6th Spd. Conversion
Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $250 Shipped
These mounts are stiffer than the STi Group N mounts and are designed to reduce excessive flex in the stock mounts.
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 01-30-2006, 09:18 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) Exedy Organic Clutch Kit and Steetlite Flywheel - 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Twin Plate Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2205 lbs/ft.
4) Exedy Organic Clutch Kit and Steetlite Flywheel - 04+ STi
-Weight: clutch - 14.3lbs, flywheel - 15.4 lbs.
$925 Shipped!!!
$1350 Installed!!!
5) Exedy Hyper Single Clutch/Flywheel Kit - 04+ STi
6) Exedy Twin-Plate Clutch/Flywheel Kit - 04+ STi
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 01-30-2006, 09:19 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) ACT HD Street Disc Kit and Steetlite Flywheel - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 01-31-2006, 12:03 AM   #4
b4437
Member#: 23162
2006 300c,forester x
silver steel
waiting on my 6spd.
b4437 is offline
Old 01-31-2006, 01:40 AM   #5
Fishang
Member#: 66390
How much for just the ACT HD Street Disc Kit for 05 STi (no flywheel) shipped to San Diego?
Fishang is offline
Old 02-01-2006, 12:17 PM   #6
11secwagon
Member#: 106084
2003 WRX Wagon
PM sent
11secwagon is offline
Old 02-01-2006, 07:30 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
$575 shipped including CA tax.
Thanks,
Geoff
Gruppe-S is offline
Old 02-05-2006, 01:01 AM   #8
b4437
Member#: 23162
silver steel
bump,for a great vendor.
b4437 is offline
Old 02-08-2006, 11:55 AM   #9
HeeroRaven
Member Sales Rating: (4)
Member#: 68793
2002 Subaru WRX
Midnight Black
Are the RA gears still in stock?
HeeroRaven is offline
Old 02-08-2006, 04:53 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
No sir. They're no longer in stock.
Thanks,
Geoff
Gruppe-S is offline
Old 02-09-2006, 12:28 AM   #11
beecha91
Member Sales Rating: (16)
Member#: 55009
Pm me with the best price for twin plate excedy godspeed quoted me 1500 shipped. thanks!
Don-
beecha91 is offline
Old 02-09-2006, 03:39 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
PM sent
Gruppe-S is offline
Closed Thread
JDM RA Gearset IN STOCK, Group N Mounts, Kartboy, & Clutches IA Performance Drivetrain 18 06-13-2011 05:29 PM
RAWWWR! RA Gearsets, ACT and Exedy Clutches! WorldOne Drivetrain 32 04-30-2007 06:31 PM
STi V6 RA Gearsets, Cusco Motor Mounts, ACT and Exedy Clutches and Flywheels Z1 Performance Drivetrain 13 10-10-2005 06:15 PM
STi RA gearset in stock Z1 Performance Drivetrain 2 05-17-2005 02:14 PM
Anybody know where I would find a STI Type RA Gearset in stock for an '02 WRX? 2.2gotboost Transmission (AT/MT) & Driveline 13 03-21-2004 08:25 PM
