Old 01-31-2006, 12:12 AM   #1
Rokkit
Member#: 84181
NASA #530 GTS2
Default ABS Matching Dash Switch
Hey guys, did some searching around and can't really find anything. What im looking for is a dash switch that matches the "cruise control" and "Fog Light" switches. I would like to install an on/off ABS switch in my car for some winter driving conditions, without having the hack-job feel and without having to pull the fuse every time.
Im sure someone has something made up that looks nice.
Thanks,
Mike
Rokkit is offline   Reply With Quote
Old 01-31-2006, 12:45 AM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
That's a good idea. I'd say go to the used parts forum and find someone that is parting a car. Purchase the fog switch with a plug and a bit of wiring. Then you can take your new switch and wire it in as necessary. Some acetone on a rag will make short work of the label on the switch. You could probably even make a nice stencil to re-label it as ABS or some such similar marking.
specialev is offline   Reply With Quote
Old 01-31-2006, 12:53 AM   #3
MrH00nel2
Member#: 80474
2002 Z06
1200whp
you know what you can try... is something like the turbo xs switch.
or look for dash part on ebay that has a fog light on it or something.
MrH00nel2 is offline   Reply With Quote
Old 01-31-2006, 01:12 AM   #4
Rubr_Duky
Member#: 2159
2015 STi
I've been giving thought to making a small PCB that would switch off ABS, but would reset when I turn the car off. Something like that for track conditions or or snow/gravel/sand would be perfect. So long as it resets when I turn the car off & then on again.
The cruise button would be better suited for this purpose, because it does not hold it's 'on' position.
I didn't look as closely at the fog/cruise buttons as I did the speedo dials, but it seems to me as if the gray color is on the face, and the testure is printed on top of that, and the plastic is just a little bit milky-white for daytime non-lit visibility, and the green tint is printed on the back (this part I know for sure). This seems to be the pattern for things like this, so you'd have a bit of trouble removing the texture, and the gray in order to replace the icon with something else.
Just an observation.
RD
Rubr_Duky is offline   Reply With Quote
Old 01-31-2006, 06:17 PM   #5
Diode663
Member#: 70325
03 Wrx Sedan
WTB Rear Lateral Links
I have a normal rocker switch in one of the blanks by my ebrake that turns on and off the abs without restarting the car. IIRC I wired it into the ABS motor fuse so it can be turned on and off without having to turn off and restart the car. Works like a dream. Im not sure why you would want a PCB to do this? Please elaborate.
Diode663 is offline   Reply With Quote
Old 01-31-2006, 08:19 PM   #6
Rubr_Duky
Member#: 2159
2015 STi
So you don't forget that you had it turned off when it happens that you need it.
Just like the cruise function, it resets itself to off every time you start the car. Not that you can't switch it on and off while the car is on, but if you happen to forget, and end up needing it, then it's there. If you're doing a track day, it's easy to remember to push the button to turn off the ABS, and admittedly, might be a pain to turn it off on a regular basis for inclement weather, but I'm one who would seldom use this function, so I'd rather have it on by default when I start the car, and have the ability to turn it off and then on again, but don't want to have to remember to turn ABS back on when I hit the street again. Just a safety thing.
RD
Old 02-01-2006, 10:39 AM   #7
Rokkit
Member#: 84181
NASA #530 GTS2
This is excatly what I want to avoid... I dont like that kinda look, I want something that looks stock and like it SHOULD be there. Hell, maybe I would even replace the lightbulb condom to another color so the fogs, cruise and abs switch would show diff colors when the switch was engaged.
I like the idea of auto reset, but it seems that could be attibuted to the ecu of the cruise control. Similar to the Cruise vs Fogs... the fogs dont reset when you turn your car off but cruise does.
It would be very easy for me to drill a hole in a blank and fit a switch, but I want to do it differently...
Old 02-01-2006, 10:45 AM   #8
TreeSki
Member#: 58626
do the 02's have the blank switch immediately to the right of the cruise/fog/ic spray buttons that is filled with the headlight leveler in the STi? I had this spot blank in my 04 WRX so i bought a heated seat switch from Jamie that fit the location. Now I have a perfectly stock switch there to turn my sub amp on/off. works like a charm and, as i said, looks perfectly stock...just my $.02
TreeSki is offline   Reply With Quote
Old 02-01-2006, 10:51 AM   #9
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I have a cruise button for sale if you want to try that. Pic:
http://gallery13273.fotopic.net/p11645156.html
garface is offline   Reply With Quote
ABS cut-off switch installation guide dant Brakes, Steering & Suspension 98 09-12-2009 01:47 AM
ABS on/off switch? alacrity024 Brakes, Steering & Suspension 4 01-28-2004 05:34 PM
Matching dash texture onto Defi Pod tnmn28 Interior & Exterior Modification 8 08-22-2002 12:31 AM
ABS on/off switch jamz New England Impreza Club Forum -- NESIC 23 01-31-2002 11:01 AM
ABS cut off switch WRXPOWER Brakes, Steering & Suspension 5 10-02-2001 03:05 AM
