Old 01-31-2006, 12:14 AM   #1
mdurbahn
Member#: 88680
Default Lights dim and blower slows :(
Driving my car home lastnight I noticed that about ever 3-4 minutes my lights were dimming and the blower motor would slow. This would last for about 10-15 seconds then the lights and blower would kick back into normal power. Anyone know what this is and how to fix it??
2003 wrx sedan 5spd 52k
mdurbahn is offline   Reply With Quote
Old 01-31-2006, 01:16 AM   #2
Rubr_Duky
Member#: 2159
2015 STi
You using full defrost?
Mine does that in the mornings with full defrost & the rear defogger going.
2004 Sedan, 56k.. old battery maybe?
dunno.
RD
Rubr_Duky is offline   Reply With Quote
Old 01-31-2006, 09:53 AM   #3
Iggy76
Member#: 82662
00 2.5RS Sedan
This could be due to a large current draw on the electrical system (stereo, lighting, accessories...). Might be battery or alternator. Have them tested to be sure which before you start replacing stuff.
Iggy76 is offline   Reply With Quote
Old 01-31-2006, 09:58 AM   #4
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Mine does the same. I can really notice it when at idle with defrost on and fan up on 4. Don't think it's the battery, just the alternator not spinning fast enough. Actually my 96 Cherokee did the same at idle and that had the off road package including a large alternator. I wouldn't be concerned unless you battery seems to be weak on start-up.
drivin blind is offline   Reply With Quote
Old 01-31-2006, 07:33 PM   #5
mdurbahn
Member#: 88680
na my battery is good ( 1 month old optima) I'll test the alt. Thanks
Old 01-31-2006, 07:57 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you have the HVAC in one of the defrost modes the AC compressor will run, even though the AC light remains off. When the compressor cycles on at idle you may see the lights dim. It will be more noticeable if you are maxing out the alternator by having a lot of things running such as lights, rear defrost, brake lights etc.
boost comes in low and slow :( GundamFan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-20-2009 11:26 AM
lights dim and rear defroster works poorly matthewhiggins118 Newbies & FAQs 11 12-17-2008 03:18 PM
OT electricians - I need a way to make lights brighten and dim to music. RaceCarRiot Off-Topic 23 11-07-2006 03:10 PM
Lights dimming and brightening Docsuby Electrical & Lighting 10 11-27-2005 04:35 PM
lights and blower motor not working NicEJ25 Electrical & Lighting 2 09-09-2003 08:10 PM
