Old 01-31-2006, 11:31 AM   #1
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
Default Code 0031 and testing the front O2
I've got that code after doing some work on the uppipe/headers. Is there any way to test the sensor before I plunk down $160 for a replacement?
I tested the continuity of the blue and white wire with a voltmeter at the plug and at the sensor itself by strippng away a very small bit of wiring shielding in the hopes that one of the wires is broken somewhere in between but things seem fine. Does that mean I'm pretty much screwed and need to replace it?
I reset the codes with the AP but it only takes starting the car to pop them back up again. Nothing was touched at the plug side of the sensor but of course I had to remove the sensor when I pulled the exhaust manny attached to the uppipe.
Thanks,
Frank
fmowry is offline   Reply With Quote
Im Near Dallas.. And I Need The Front O2 Sensor Asap ! eMoneyyy TXIC Private Classifieds 1 07-21-2009 03:36 PM
02 2.5RS and 94 L front O2 sensor the same? 83Rabbit Normally Aspirated Powertrain 2 06-22-2006 01:18 AM
Is there a reason the Front O2 sensor is before the turbo? drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-28-2005 05:51 PM
Running rich and studdering with front O2 heater code zombiedog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-09-2005 12:24 PM
So has anyone moved the front O2 to the downpipe? SlideWRX Engine Management & Tuning 2 06-23-2004 11:10 AM
