Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 01-31-2006, 12:06 PM   #1
i4dat
Member#: 83512
2003 Subaru WRX
Sedona Red
Question UTEC question; NooB
Hello, I had a question concerning the check engine light when using the UTEC.
The manual says that the Check engine light will flash showing which map you have selected when using the Map Selector switch.
Mines does not.
If I switch to the Security Mode, the check engine light will flash continously, which is what the manual specifies. So I know that it will work when switched to Map 7.
Why won't it flash when you change your maps?
Any help would be greatly appreciated.
Thanks.
David
i4dat is offline   Reply With Quote
Old 01-31-2006, 12:48 PM   #2
Davenow
Member#: 23676
I have had 2 UTECS (one in my 02 wrx and one in my STI) and neither ever flashed to show what map I was on when I changed maps. Are you sure you are reading that correctly?
Old 01-31-2006, 01:38 PM   #3
i4dat
Member#: 83512
2003 Subaru WRX
Sedona Red
Well I can only go by the instructions from Turbo XS.
The UTEC Dashboard will show both the number of the Map and the switch position that is selected once the car is running. If the car is not running the UTEC may revert back to stock mode. Also, when starting the car the check engine light will flash and indicate which map you have selected. For example if you have selected map 2 the check engine light will flash twice and then stay on until the car is started.
This is from the 17th page of the UTEC Manual under the General Information Section.
I just want to know if this is a mistake or if my UTEC is freaking out.
It is also supposed to flash the Check Engine light if it encounters Knock.
I just want to make sure that this feature is working and not disabled along with the Map Number Flashing.
Don't want to end up with a nasty surprise.
Thanks.
David.
Old 01-31-2006, 01:44 PM   #4
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
Mine does that...
What you need to do is turn your key to "Acc" and wait for the light to blink. Don't start your car right away...put the key to Acc...wait 5 secs so you can see the blink....then start your car. It won't flash after you change maps, just when you initially turn on the car. Plus, as I'm sure (I hope) you know, map change is not "on the fly" for the Utec. You can change maps, but it won't take effect until the RPMs drop below 1500 or so (where UTEC takes over for stock ECU).
I'm on map 3 so my CEL blinks 3 times and then holds on the 4th.....
YourMother'sLover is offline   Reply With Quote
Old 01-31-2006, 01:49 PM   #5
i4dat
Member#: 83512
2003 Subaru WRX
Sedona Red
Thanks for the input.
When I get a chance I will have to see if it will do it after waiting a few seconds.
Thanks again, I appreciate the help.
David.
Old 01-31-2006, 03:44 PM   #6
Lost_Pete
Member#: 100570
It depends on the version of software you have. The latest version (5.0) does not flash the CEL to indicate the map selected.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 01-31-2006, 04:24 PM   #7
Gethin
Member#: 2998
^^^^^^ 12345
v5 of the firmware no longer flashes CEL to indicate map selection. Explaied in the v5 update notes
http://www.turboxs.com/downloads/UTE...nformation.doc
Gethin is offline   Reply With Quote
Old 01-31-2006, 06:01 PM   #8
fzturbo
Member#: 43482
2004 JDM 2 litre STI
Hi, sorry for hi jacking the thread, i just want to know something since i'm also a noob at UTEC, is there anyway to erase a cel with the utec??? got my check engine light on and want to shut it.
Thanks.
fzturbo is offline   Reply With Quote
Old 01-31-2006, 06:47 PM   #9
Gethin
Member#: 2998
You need a OBD2 tool to remove the stored code from the stock Subaru ECU, the UTEC is a seperate piggyback unit. It's good to read the code before erasing it so you know the cause.
If you are asking if you can supress the CEL light completely, then yes the UTEC can disable all CEL's from appearing. They will still be stored in the ECU to be retrieved via OBD2 and it will still flash if it detects knock. Beware that if you disable the CEL light using the UTEC you will not get any indication that you are having problems if they appear!
Old 02-01-2006, 09:53 AM   #10
i4dat
Member#: 83512
2003 Subaru WRX
Sedona Red
Ok, now it makes sense.
I guess it pays to read the updates to the manual as well.
Thanks and take care.
David.
utec help/ noob wasey13 UTEC 12 10-29-2006 02:05 PM
UTEC w/ 2004 and CEL's ???? UTEC NOOB mmorningstar Engine Management & Tuning 14 05-12-2005 04:14 PM
Ultra noob utec tuning Q duckride Engine Management & Tuning 1 08-06-2003 04:14 PM
Utec Noob boost question C Dust Engine Management & Tuning 1 07-21-2003 02:06 PM
Noob UTEC Question Re: Knock and 91Octane Brian Broz Engine Management & Tuning 2 03-01-2003 08:51 PM
Message Board Statistics All times are GMT -4. The time now is 02:31 AM.
