Old 01-31-2006, 02:47 PM   #1
simprezl25
Member#: 71647
2002 Bug iD
Default for my swap, wrx 2002 OR 2003 ECU???
hi, i am doing a swap on my 2002 2.5rs an i have a 2002 wrx engine WITH 2003 bulkhead harness and 2003 front harness these harnesses are going to be sent out to garagetuning in about 2 weeks to get rewired. but i have no idea witch ecu i should get. i heard that the 2002 2003 wrx is are similar but im not sure. i think i should get a 2002 right??
thanx for you input.
simprezl25 is offline   Reply With Quote
Old 01-31-2006, 02:57 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
2003 has an evap system sensor that the 2002 does not, i have to figure out how to bypass it to work with my 2003 WRX ECU
Old 02-01-2006, 11:01 AM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Why would you rewire those harnesses rather than just plug them into to your current dash? You already have a GD.
Use whatever harness you like 02 or 03, but use the 02 ECU.
jamesfacts is offline   Reply With Quote
Old 02-01-2006, 12:43 PM   #4
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
that started in 03? huh, i thought it was 04. I need to do the same.
subbyspeed is offline   Reply With Quote
Old 02-01-2006, 04:26 PM   #5
simprezl25
Member#: 71647
2002 Bug iD
so i can just plug and play everything?? to the 2002 wrx motor???? what about the fuel pump controller and what is a GD? haha
Old 02-02-2006, 02:53 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
you'll need the FP controller and btw the dash harnesses are NOT identical
your RS may use the same cluster but you still have a different ECU connectors and such
and GD is your body code
Old 02-03-2006, 12:16 AM   #7
simprezl25
Member#: 71647
2002 Bug iD
ok ahha kool, i have the fp controller and i have the 2003 front and bulkhead harness. yeh i think i will be selling the 2.5rs engine and the harnesses afterwards.
even though im going to use a 2002 ecu with 2003 harness will the connectors be the same?? i think so. o man is this is a plug and play sort of thing i am going to be so happy! ahha, cant wait till summer.
Old 02-03-2006, 12:55 AM   #8
jamesfacts
Member#: 51282
98 RS
Correct, but I'm saying replace the full bulkhead harness.
Old 02-03-2006, 02:09 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
ah sorry i read that all wrong, do as he suggested, replace the bulkhead and engine bay harnesses and save yourself the work of splicing
yes it will be a bit more pricey but you'll have less to worry about in the long run.
Old 02-03-2006, 05:28 AM   #10
simprezl25
Member#: 71647
2002 Bug iD
so the 2002 ecu will work fine with the 2003 harnesses?? and all i hae to reiwre up is the fp controller??
i have the whole 2003 front harness and the whole 2003 bulkhead harness, just need to get a 2002 ecu.
Old 02-03-2006, 07:00 AM   #11
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
The 2002 will work fine, just plug and play man.
TyranosaurusWRX is offline   Reply With Quote
Old 02-03-2006, 11:18 AM   #12
jamesfacts
Member#: 51282
98 RS
You don't need to use the 03 front harness, just the bulkhead.
Almost - you will get a 1446 code as has been suggested before. Best bet is to find a 02 ECU. We can fix the 02 harness so it doesn't throw the code as well.
Old 02-03-2006, 02:27 PM   #13
sidewayz
Member#: 5810
2001 S366 2.5RS
your right. the '04 has the extra pressure sensor thingy the 03 and under dont have it.
sidewayz is offline   Reply With Quote
Old 02-03-2006, 02:38 PM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
trust me '03's have it. the reason i know is because when i said the code a UTEC beta tester recognized the code right away. '04 might have a different sensor but it's definitely an EVAP system P1446 stored. it's because the '03 had an extra sensor that the '02 did not. Do i know exactly what the difference between 02 and 03 are? no i don't but there is definitely a difference.
Old 02-03-2006, 03:03 PM   #15
sidewayz
Member#: 5810
2001 S366 2.5RS
My 03 ecu hasnt thrown a code for it neither does my ecu have a pin on the ecu for it.. possibly a middle year change?
Old 02-03-2006, 03:42 PM   #16
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
^^^ Yeah, I was going to mention, there is a differentiation between early and late 03's. Not sure what it is exactly though.
Old 02-03-2006, 04:12 PM   #17
simprezl25
Member#: 71647
2002 Bug iD
man then i just blew money on the front harness....**** i guess i can sel it then. but anyways, how much is it to get the 1446 code thing fxed?? and have the fp controller wired up??
Old 02-04-2006, 01:06 AM   #18
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
I've posted how to wiring fuel pump contoller on here and also on scoobymods check it out there.. if you have questions on swap pm me i'll try to answer all the questions you have..
taeyax82 is offline   Reply With Quote
Old 02-04-2006, 02:16 AM   #19
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
the code can be flashed out with an access port(i intend to flash out the P0420, the rear o2 heater p0141, and the p1446 evap codes).
not wasting the money on a rear o2 if it's not gonna have a cat to check if you know what i mean
btw: here's some wiring info for ya with some pictures
http://forums.nasioc.com/forums/showthread.php?t=880061
Old 02-04-2006, 08:19 PM   #20
simprezl25
Member#: 71647
2002 Bug iD
alright thanx
Old 02-04-2006, 08:24 PM   #21
simprezl25
Member#: 71647
2002 Bug iD
thanx for the fuel pump things, but yeh i hope my engine will mate up to harnesses and everything will work. ill keep in toush guys thanx but the swap is going to happen in the summer
Accessport for 2002 or 2003 WRX mattyturbo Engine/Power/Exhaust 0 02-27-2007 05:49 PM
WTB cargo cover for wrx wagon 2002 or 2003 kite_tmr Private 'Wanted' Classifieds 3 08-31-2006 10:23 AM
2002 or 2003 WRX? fstede21 Newbies & FAQs 15 03-10-2002 10:21 AM
