Old 09-18-2001, 10:17 PM   #1
MekoNY
Member#: 8000
2005 Accord
Graphite
Default 2000 Legacy rotors.....they suck
Ok, here's the scoop. I bought the car new. Dealer replaced the rotors at 20,000 miles because they were warped to hell. The car now has close to 40,000 miles and the crazy vibrations and shaking felt through the steering wheel has re-appeared during braking only. I replaced the brakes two weeks ago but might need to upgrade my rotors now.
Do you guys recommend any particular types(slotted, cross drilled) or specific brands.
All I do is commute in heavy traffic but drive fast (sometimes WAY too fast) when the road allows it. I just don't want to feel any shaking or vibrations when some a$$hole decides to switch lanes 100 feet in front of me. I know it's not the ABS coming on because that feels and sounds totally different. So what's the verdict??
MekoNY is offline   Reply With Quote
Old 09-18-2001, 11:24 PM   #2
francophile
Member#: 8666
2005 STi
Crystal Gray
Default Yep
They do suck :-( I'm going to have mine either replaced or turned under warranty; when they go out again, which I expect they will, I'll be looking to replace them with some aftermarket rotors.
Regards,
-wdb
francophile is offline   Reply With Quote
Old 09-18-2001, 11:56 PM   #3
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I'd get slotted. Cross Drilled looks cool but they can warp or crack easier than solid rotors.
Huge debate over this every time someone asks about it.
Primitive Racing has slotted Brembo's for $180 for the fronts, I am pretty sure they will work on your car but you might double check.
It could be that your dealer or mechanic is putting too much torque on the wheel lug nuts. Anything much more than 75ft/lbs can and will warp the rotors.
remarcable is offline   Reply With Quote
Old 09-19-2001, 08:27 AM   #4
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Default hmmmmmmmmm....
Well if you "replaced the brakes" I assume you mean new pads, if this is the case and you didn't get the rotors turned, then that would explain your problem. Every pad will seat differently, so a new surface is the only way to go.
I know you have the same rotor size as the 2.5 RS, I also then assume they are the same rotors... however through driving my fiancee's 2002 Legacy I'm 99% sure they are the same. I don't feel the rotor is the problem with the stock Subaru brakes. Pads, SS brake lines, and better fluid make the stock system better. now if your fading the brakes in traffic, you need to ease up on your driving.
If oddly warn rotors is the only issue, then maybe you should upgrade, but if your going to throw down for new rotors, better get new pads to offer proper seating.
This is all my opinion, but I feel that the stock Subaru system is great, and unless your hitting the Race Track the stock rotors do the job.. I've never faded mine in hard testing or while on the Marshalltown track.
I run stock rotors and pads, Goodridge SS lines and Valvoline sythentic brake fluid. I plan to upgrade pads and turn my rotors next spring.
Jon
omahasubaru is offline   Reply With Quote
Old 09-19-2001, 12:11 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I warped my rotors at around 25k miles after installing Mintex 1155s (and getting the rotors turned) and then doing a two-day track event. Soon thereafter I installed cryo-treated Subaru OEM rotors, which never warped (I recently replaced them with around 35-38k miles). Those rotors were subjected to a couple track events (3 days on track), numerous auto-x events, and all sorts of barn-storming around the winding back roads of New England. All of the mileage was with the same type of pads (1155s) that warped the non-cryo'd stock rotors.
The rotors I just installed are non-cryo'd OEM-sized plain Brembo rotors, which I got from Diversified Cryogenics (www.frozenrotors.com) for I think $49 each (about 2/3 the cost of new Subaru rotors). I've only got about 1000 miles on them thus far, so I can't say how they'll hold up long term.
My suggestions? Get some good rotors, perhaps cryo-treated, and take care of them! I agree with Jon, the Subaru brakes are more than sufficient for hard street use. Break them in properly (see http://www.baer.com/bedding_street for details) and don't abuse them. What do I mean by that? Make sure you warm the brakes before you pound on them, and when you're done pounding on them, don't park the car immediately - allow the brakes to cool a bit first.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 09-19-2001, 11:57 PM   #6
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Pat
Thanks for the great info but.... could you please clarify this paragraph.
"The rotors I just installed are non-cryo'd OEM-sized plain Brembo rotors, which I got from Diversified Cryogenics (www.frozenrotors.com) for I think $49 each (about 2/3 the cost of new Subaru rotors). I've only got about 1000 miles on them thus far, so I can't say how they'll hold up long term. "
You bought non-cryoed rotors from a cryogenic company for $49 each. I went to the website and I didnt see any non-cryoed products???
Please amplify
subysouth is offline   Reply With Quote
Old 09-20-2001, 07:33 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Diversified will actually source rotors for you. When I had my OEM rotors cryo'd, I didn't have to got to my dealer, buy rotors, and then ship them to Diversified - they got them for me. When I bought my track-duty rotors (cryo treated Brembos) I discovered that Diversified could get plain Brembo rotors for me. No, they're not listed on the website, and maybe I could find them elsewhere cheaper, but I just went with Diversified. Various Subaru shops have Brembo stuff, but they sell all the silly slotted and cross-drilled rotors, which I don't need - I just wanted plain Brembos.
Pat
Old 09-20-2001, 07:55 PM   #8
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Wink cryo does a rotor good!
if you guys have the time and the money (it's not THAT expensive) I can't recommend cryoing your rotors more! www.800below.com does it for cheap. plus also the breaking in and maintaining them also makes a difference: don't stand on the brakes after heavy usage and KEEP standing on them in traffic! the brake pads are compressing the rotor while it's still hot and therefore maleable! use the parking brake or put the car in park! (subie's use a inner drum rear rotor which doesn't use the rear pads to clamp onto the disc, therefore avoiding the same compression.) i'm pretty sure that's the #1 cause of warped rotors.
-chrisC
silverSurfer is offline   Reply With Quote
Old 09-22-2001, 10:29 AM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Got it
makes sense now. Thanks Pat, that does seem like a good price even for just the regular Brembo rotors.
Old 09-22-2001, 10:34 AM   #10
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Chris may be on to something.
I do many track days... been lucky enough to not have major issues.
anotherB4 is offline   Reply With Quote
Old 01-08-2002, 10:32 AM   #11
Mike2000GT
Member#: 2709
2006 WRX Wagon
SGM
Bump... good info here...
Pat, anything else you want to share on the rotors?
Question, I've got 25K on my 00 GT. How'd you guys get em replaced under warranty? I've got some warpage (heh... some) and would like to get the rotors replaced as cheaply as possible... So free under warranty would be super!
TIA,
Mike
Mike2000GT is offline   Reply With Quote
Old 01-08-2002, 11:40 AM   #12
kbrate
Member#: 7472
2001 Legacy
Winestone Pearl
Question Non GT Brakes
I have a 2001 L Wagon -10.7 in Front Discs - Twin Piston Calipers - Are Brembo Discs ave. for these or only the GT 11.4 in Discs.
How hard would it be to put the bigger GT/OB Discs on an L. I would think that the Twin Piston Caliper would be the same so a bracket should do it but if the headlights are different you never know...
Ken
kbrate is offline   Reply With Quote
Old 01-08-2002, 11:44 AM   #13
MekoNY
Member#: 8000
2005 Accord
Graphite
Default do what I did......
Wow, the threads been ressurected.
Just take the car back and tell them your problem. When he tells you it's the rotors indicate to them you find the rotor quality unacceptable. The dealer sided with me and threw them on at no cost. I guess it depends on your dealer and your demeanor.
BTW- I take back what I said on the rotors sucking. After they were replaced, my original problems started occuring again. So I had them recut and resurfaced AND also changed my braking style. 20K miles later I have not had any problems. All along it was me who had the problem. I was always slamming on the brakes and stopping short. My rotors are still smooth to this day. I also don't wash my wheels right after I drive. If you don't abuse your brakes, the rotors work fine. I wish I could say the same about the tranny.
Good luck
Old 01-08-2002, 12:21 PM   #14
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Guys, here in Puerto Rico we upgrade the brakes to the '01 H6 brake in the outbacks and legacies.
You might want to try this plus add the sloted rotors to boost.
Just get the H6 rotors and calliper mounts. That's it!!!!
I did it on my '00 Outback which was on the 3rd set of rotors!
Just find someone in your area with a WRX that has upgraded to 4pots and do an offer for the caliper mounts. Rotors are usually $200. for the set.
Leo
PS:
You'll be able to abuse them once again
Leonardo is offline   Reply With Quote
Old 01-08-2002, 12:57 PM   #15
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I have a set of the 11.4" rotors/calipers/pads that came on the Legacy GT/WRX/Outback on my 93 Turbo and i must say that they're very nice. I'm not easy on brakes, but these have held up good in the extreme heat and bitter cold.
DLC is offline   Reply With Quote
Old 01-09-2002, 10:40 AM   #16
2001LegactGT
Member#: 5089
2002 Audi A4
Denim Blue
I had pretty much the same problem with me 00 GT my 01GT brakes are much nicer. During stopping the brakes were awful made noise felt like it was grinding and u could feel it in the wheel. Just like u mentioned earlier.
After bothering the dealership enough and having them try a few different things ( I can't remember them all off hand). I believe they replaced the pads in the back thats where the problem was and tehy replaced the "shims" (sp?) I believe they are pieces that keep the brakes balanced and even or something not exactly sure. Now the brakes have no problems what so ever. Not sure if the is the same thing you are feeling but thought I would share.
2001LegactGT is offline   Reply With Quote
Old 01-09-2002, 11:09 AM   #17
Mike2000GT
Member#: 2709
2006 WRX Wagon
SGM
Thanks for the input, but no, I replaced the pads at Summit Point, and I think that the break in I did may have warped them.
For future reference, if you get a lot of squeeling from your brakes, you may be down to the indicators on the pads. This lets you know that you are probably in need of new pads.
Bill from frozenrotors.com called me at about 5:30 last night for the quote I requested on a set of rotors. At ~$50 for each rotor to start (brembo oem equivolent) I was pretty happy with that. I'm going to try the dealer first, as that would be free... and free is good.
I've got to remember to request to go with the tech so I can point out the problem.
Mike2000GT
Old 01-09-2002, 01:55 PM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Default Re: Non GT Brakes
My '97 2.5GT has the same brakes as your L, with the smaller 10.7" front discs. The GT didn't get the bigger front discs until '00 or later (I'm not even sure if the '00 cars have the bigger discs). Anyway, the answer is Yes, the Brembo rotors are available for your brakes. As far as I know Brembo does not sell replacements for the bigger 11.4" GT/OB/WRX discs.
Ken
Your thinking is correct - the only difference is the rotor itself and the caliper bracket.
They're kinda round, flat-ish, and silver. I think they're made of some sort of metal.
The cryo-treated Brembos I use for track days are still in excellent shape. Summit Point beat them up pretty good, but they took the lickin' and keep on stoppin'. I will definitely add cooling ducts to them in the future.
The non-cryo'd Brembos I use on the streets with Mintex 1155s have developed a little bit of a "nibble". (That's what the guy at Diversified called it - just a slight vibration in the pedal under braking). I'm still very happy with them. I think I'm getting close to replacement time on the Mintex pads, which have a reputation for being hard on rotors, and there's still tons of life left in this set of discs. With these available for $49 + S/H, and new Subaru rotos costing $72 + tax at the dealership, this is a no-brainer choice for me.
Pat Olsen
Old 01-16-2002, 10:44 PM   #19
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I know it's a little late, but I did this write up on cross-drilled vs. slotted a while back.....I think I posted it here at one point and time. It's on my site if anyone wants to do some reading, under notes & tips
Anyone running a set of 4 pots on their legacy? If so, are they Sti or other?
Also what's probably the biggest rotor/caliper setup I could get in a 16" wheel?
Thanks
Legacy777 is offline   Reply With Quote
Here's he pic's. They suck! but they are there. Subie Girl Member's Car Gallery 17 07-22-2007 10:55 PM
Here's the pic's. They suck! but they are there. Subie Girl Newbies & FAQs 0 07-21-2007 10:16 PM
I hate Sunoco...they lie and they suck... (Venting) BigJ04STi Tri-State Area Forum 35 03-04-2006 12:36 AM
Rotor size on a 2000 legacy? Mx5racer Legacy Forum 21 02-16-2005 05:00 PM
H6 rotors on pre 2000+ legacy hub? WRXwannbe Brakes, Steering & Suspension 6 08-13-2002 03:52 PM
