Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 02-01-2006, 12:24 PM   #1
Subiemax
Member#: 30691
2013 FRS
RED
Default water injection question
Just started to set up my water injection and was wondering where people are mounting their nozzle at. I have a STi with factory I/C. I am thinking of mounting it in the Y-Pipe of the I/C befor it splits.
Can U drill and tap the Y-pipe? I thinks its cast, ashould be able to?
Where are other people mounting it?
Max
Subiemax is offline   Reply With Quote
Old 02-01-2006, 12:27 PM   #2
Gethin
Member#: 2998
I see a lot of setups with the jet pointing down at the IC to throttle body hose location.
Gethin is offline   Reply With Quote
Old 02-01-2006, 03:32 PM   #3
Subiemax
Member#: 30691
2013 FRS
RED
I don't think that would be a good set up.
I think the idea is to get the water/meth atomised(sp) into the intake stream.
Having it at the TB would make it almost strait liquid.
Pistons don't like liquid!
Old 02-01-2006, 06:27 PM   #4
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
If you take the intercooler off and look inside the outlet, there is nice little flat spot on the bottom just beyond the outlet. It is right in front of the core. That is where I like to mount it. really ease to drill and hides well. It's kinda stealthy mounted right there.
RickInLittleElm is offline   Reply With Quote
Old 02-01-2006, 09:06 PM   #5
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Mine appears to atomize just fine in the spot right above the TMIC outlet... gains are from nozzle changout from 175ml to 375ml, nothing else. I didn't change nozzle position either. It is the same as before, right above the throttle body in the intercooler
I have it mounted at teh outlet of teh intercooler. I use a MRT TMIC, not a OEM, but the concept is the same. The runners on our cars are long enough, that I think we get much better atomization than that of a inline motor with a 1 into 4 intake manifold. On an inline car I would mount it closer to the turbo outlet.
DP
DonkeyPunch is offline   Reply With Quote
Old 02-02-2006, 06:44 AM   #6
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
I did mine like this, courtesy of Riftswrx:
"At this point all that's left is finding out where you want to mount your nozzle. >I< drilled a small hose in the silicone intercooler hose going to my throttle body, then using two washers I pushed the nozzle through the hole, and then screwed on one of the brass hose fittings. The washers pressing the silicone, effectively making a gasket. At that point I simply connected a length of hose from the solenoid to the brass fitting."
Frank
fmowry is offline   Reply With Quote
Old 02-02-2006, 09:07 AM   #7
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
This is for Alcohol injection but you get the idea... Works like champ..!
xcntrk75 is offline   Reply With Quote
Old 02-02-2006, 09:38 AM   #8
writersblock
Member#: 28912
Platinum Silver
Aquamist actually makes an intercooler to throttle body hose with two bosses for the injection nozzles.
Writersblock
writersblock is offline   Reply With Quote
Old 02-02-2006, 12:16 PM   #9
writersblock
Member#: 28912
Platinum Silver
I couldn't find the link for my original post. It is: http://www.aquamist.co.uk/press/
Writersblock
Old 02-02-2006, 01:05 PM   #10
Gethin
Member#: 2998
<pistons dont like liquid>
well you're not putting liquid in there, it's atomised water into intake stream
Old 02-02-2006, 07:07 PM   #11
Subiemax
Member#: 30691
2013 FRS
RED
Allright, Looks like I be putting it in the tmic output.
If works for everone else it works for.
Thanks for all the input.
Water injection question, pump activated by relay wcbjr Water/Methanol Injection, Nitrous & Intercooler Cooling 2 02-22-2005 01:24 PM
Exhaust Water Injection question for Autotranny Kevin Thomas Transmission (AT/MT) & Driveline 10 09-08-2003 09:09 AM
water injection question FuelCutOff Engine Management & Tuning 9 09-03-2003 10:59 PM
Water Injection Questions TCENGEL Water/Methanol Injection, Nitrous & Intercooler Cooling 37 07-16-2002 05:50 PM
Water Injection Question! MN Technical Forum Archive 7 05-10-2000 03:15 PM
