Old 02-01-2006, 08:10 PM   #1
Ronaldo
Member#: 53700
2004 WRX
Rally Blue
Question alarm goes off AUTOmaticly HELP PLZ!!!!!!!!!!!!!!
hi, i currently have compustar alarm installed to my 04 wrx
and when i turn on the compustar alarm and lock the door, alarm just go off after 30 sec or so...
i have to put the compustar alarm into valet mode for the alarm to stop.
and the passive mode for the compustar is off too
my stock alarm is disable...
or is it the passive mode is on for the stock alarm? how do i disable it?
i lost my owners manual...
plz help !!
Ronaldo is offline   Reply With Quote
Old 02-01-2006, 08:16 PM   #2
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
plz help !!
have you unplugged the stock wrx alarm? i belive its under the center console near the ebrake.. might need to just unplug it
szeny is offline   Reply With Quote
Old 02-01-2006, 08:23 PM   #3
Ronaldo
Member#: 53700
2004 WRX
Rally Blue
wwhich plug is it? i took the console off. i am a newbie , sorry
Old 02-01-2006, 09:32 PM   #4
julezamazing212
Scooby Scammer- Do Not Buy From User
Member#: 100911
Or Maybe Ur Battery Is Low On Voltage Sometimes Alarms Do That As A Warning To Change Ur Battery Or Check It
julezamazing212 is offline   Reply With Quote
Old 02-01-2006, 10:11 PM   #5
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
So which alarm is going off horn or siren?
It takes 30 secs for the compustar alarms shock sensor to ctivate it may be WAY to sensitive, as in feather falls it goes off.
And you say you have to put it in valet mode to stop the alarm, as in key on/off 5 times because the remote doesnt work all the time? or with the remote?
audio1der is offline   Reply With Quote
Old 02-02-2006, 01:16 AM   #6
Ronaldo
Member#: 53700
2004 WRX
Rally Blue
i put the compustar alarm to valet mode...
Old 02-02-2006, 01:35 AM   #7
joe r
Member#: 53412
2003 Outback
Black and Gold.
what does it show on your remote display when it go's off.?
"lets start from square one"
joe r
joe r is offline   Reply With Quote
Old 02-02-2006, 02:12 AM   #8
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
directions and pics in here to unplug factory... http://www.scoobymods.com/forums/showthread.php?t=1900
Old 02-02-2006, 03:07 AM   #9
Ronaldo
Member#: 53700
2004 WRX
Rally Blue
When it goes off it shows a hammer breaking into the car.
but nothing happen to the car...
Old 02-02-2006, 03:20 AM   #10
joe r
Member#: 53412
2003 Outback
Black and Gold.
lol your shock censor is way to high,turn it down.
I am a compustar freek but I do not like there shock censor's.
I have every time used a audiovox shock censor with all my compustar alarms as they are kick arse.
joe r
Old 02-02-2006, 03:20 PM   #11
Ronaldo
Member#: 53700
2004 WRX
Rally Blue
how do i turn down the shock sensor?
Old 02-02-2006, 04:14 PM   #12
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
Find it under the knee bolster and turn it so the numbers go down.
Its flat black , egg shaped with a white plug at one end.
Old 02-02-2006, 04:27 PM   #13
TheLegacy
Member#: 47615
2007 BMW 335XI
Saphire Black
i love compustar but if u sneezed next to my car... it would go off lol
TheLegacy is offline   Reply With Quote
Old 02-02-2006, 08:48 PM   #14
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
I have my sensor on the, 4 out of 10, setting. It's a compustar. Never had any issues with it being to sensitive. And it goes off if people give the "kick the tire test".
Like most people said, it's probably your shock sensor. Turn it down and you should be fine.
Old 02-03-2006, 12:47 AM   #15
Ronaldo
Member#: 53700
2004 WRX
Rally Blue
it was fine before, after a month away from holiday its like this
Old 02-03-2006, 02:12 AM   #16
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
That is odd. Maybe somehow the little wheel got spun and it turned up the sentivity. To rule this problem out check to see what it's on (shock sensor). If it's 4 and under, then you have a different problem and we'll go from there.
Old 02-03-2006, 02:45 AM   #17
Ronaldo
Member#: 53700
2004 WRX
Rally Blue
thanks i check it tomorw
Old 03-13-2006, 10:21 PM   #18
Qball
Member#: 104451
2004 g-friend's wrx
is the compustar the stock or aftermarket?
Qball is offline   Reply With Quote
Viper 5901 installed but alarm goes off when auto start when armed. HELP xaznxeclipsex Car Audio, Video & Security 14 06-29-2009 05:01 PM
My alarm goes off on its own sometimes DJ 9iron Car Audio, Video & Security 6 01-12-2005 08:43 AM
Factory Alarm goes off after brake work? Mr.Hanky Car Audio, Video & Security 2 03-26-2004 01:06 AM
alarm goes off when i use the key bziller Car Audio, Video & Security 4 07-16-2002 01:22 PM
headlight on, alarm goes off??? Nanase Car Audio, Video & Security 3 01-10-2001 12:08 AM
