Old 02-02-2006, 11:48 AM   #1
Rokkit
Member#: 84181
NASA #530 GTS2
Default P+P Stock Headers Vs Aftermarket
Just wondering what the positives or negitives of P+P stock headers are vs aftermarket tubular headers.
Im debating on just P+P my stockers and running with that when I upgrade...
I don't know the actual differences between stock headers and tubular headers when it comes to airflow.
Also, heat retention can be solved by wrapping aftermarkets, but its jut another 30$ on top of the 800, heh.
I did search, any comments in this comparison would be great.
Thanks all,
Mike
Rokkit is offline   Reply With Quote
Old 02-02-2006, 12:24 PM   #2
The Cheat
Member#: 66044
2004 WRX/1994 Miata
from what i've gathered, you would be better off p&p'ing your stock headers unless your pushing like eleventy billion horsepower. aftermarket headers will give you better top end performance but increase turbo lag slightly due to the fact that you have to fill a larger area with exhuast gases before the turbo starts to spin. i think thats right, i'm sure i read it somewhere else on here. Most people seem to recommend gasket matching and polishing for the best results for anything below 300hp.
there was a shop that tested a bunch of different headers and did a write up on it but i cant seem to find it at the momment.
The Cheat is offline   Reply With Quote
Old 02-02-2006, 12:25 PM   #3
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
P&P stockers, better low end through spool.
Tubular headers, sacrifice low end for more top end.
Weight.
Pick your poison.
J-Rex2004 is offline   Reply With Quote
Old 02-02-2006, 12:46 PM   #4
Rokkit
Member#: 84181
NASA #530 GTS2
Stocks are heavier i would assume, being cast right?
Old 02-02-2006, 12:49 PM   #5
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
correct.
Old 02-02-2006, 12:50 PM   #6
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
yes, cast is considerably heavier. i could hold my borla headers with one hand easily but had to use some muscle carrying the stock header. there is definitely some lag, as i just recently swapped back to the stock header, but also did notice a drop in power top end. i'm going to swap back to the borla once i get tuned.
anthonyrb98 is offline   Reply With Quote
Old 02-02-2006, 01:15 PM   #7
Rokkit
Member#: 84181
NASA #530 GTS2
Hm in debating on turbos for the future, but I do a lot of rallyx, autox, etc. So i need the semi low end/mid range.
I would assume P+P the stockers would be a better choice.
Do you know the interior diamer of the piping vs after market headers?
Borla, etc.
Thanks,
Mike
Old 02-02-2006, 01:18 PM   #8
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
FYI the old esx 9sec car was using the stock exaust manifold, it was P&P.
Just port the stock headers, you don't want to lose that famous boxer rumble.
fastwrx006 is offline   Reply With Quote
Old 02-02-2006, 01:20 PM   #9
Rokkit
Member#: 84181
NASA #530 GTS2
You dont lose the boxer rumble with aftermarket headers hehe. its lost with EQUAL LENGTH headers... which are actually more expensive than the borla or xxtuning headers...
most are unequal like the stockers.
Old 02-02-2006, 03:39 PM   #10
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
Black is Borla, blue is a ported stocker. This is with a VF30 and stock TMIC.
Ported sound clip: http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
Borla sound clip: http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
McBain_TP is offline   Reply With Quote
Old 02-03-2006, 01:32 AM   #11
testes1010
Member#: 47145
2012 Gas Saver
Weight.
Pick your poison.
my big concern was price...$600+ for quality coated headers...$200 for matchported & ceramic coated stock manifold...to me it was an easy choice...
testes1010 is offline   Reply With Quote
Old 02-03-2006, 01:57 AM   #12
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
FYI XXtuning headers WILL break... vivid racing sucks.
I have MRT headers.. i didnt lose the boxer sounds, its just raspier.. they're extremely lighter than the stockers and take up much less space under the block(not that it really matters). From what i've seen, aftermarkets WILL make a difference if tuned right... tuning is the key. I made about 13 more ponies with the MRT's than with the stocker. I didnt have it pnp'ed however... You just have to look at what YOU use the car for and what you need. If you need low end, go with the stockers, if you want high end, aftermarkets...
vipernj is offline   Reply With Quote
Old 02-03-2006, 07:58 AM   #13
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
i am also debating this as well too.... I just got a turbo upgrade which likely won't be wanting for much on the top end of the scale... infact, all it will be good for is top end highway power....But then again, I consider how much of a gain in top end HP my Gruppe S headers have been on my current setup, and I am thinking that I will get even more out of them on an even bigger turbo
jigga is offline   Reply With Quote
Old 02-03-2006, 08:53 AM   #14
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Excellent way of putting it.
I'd also like to let everyone know the "butt dyno" is not accurate enough to notice that 10-15hp difference.. but your time slip will. So if you're interested in a timeslip, go with the header.. if you don't plan on drag racing your car - use the ported manifold.
PeteDucati is offline   Reply With Quote
Old 02-03-2006, 09:04 AM   #15
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
I currently have the Borla on my car. I did lose a my low end when I put them on (Cobb II).
I had my car tuned by PDX and Tim did an amazing job of getting my low end back. I can make 1 bar at 2900 rpm with the Borla.
I want more lowend (autocross, street) so I'm going to go P&P stock headers and a Deadbolt turbo. The extra HP on top is not nearly that important to me.
dbrier is offline   Reply With Quote
Old 02-03-2006, 09:14 AM   #16
Rokkit
Member#: 84181
NASA #530 GTS2
great responses everyone. I guess ill be P+Pin my extra set of headers then
Thanks to you all
Mike
Old 02-03-2006, 09:57 AM   #17
blue blurr
Member#: 51111
I would P&P your stockers. I have aftermarket ones right now with a vf34 and I'm going to P&P my stock ones and get them heat treated and then put them back on. The little top end that I will loose will be worth the heat restraint and low end that I gain. Thatís just my opinion.
blue blurr is offline   Reply With Quote
Old 02-03-2006, 10:02 AM   #18
BLACK02WAGON
Member#: 32574
2012 Nissan GTR BE
Vibrant Red
Impreza WRX STi
Take a look at Crucial Racing as from what I have heard, they have a program to send yours in and have them P&P'd and ceramic coated for $200. This is a killer deal if it is correct.
BLACK02WAGON is offline   Reply With Quote
Old 02-03-2006, 11:30 AM   #19
wrx-boy
Member#: 43662
2005 STi
CGM
P & P is the way to go!! Tis what I did and love it for several reasons...
-Stealth (No Dealer will know the diff. if you've P & P'd or Gutted your Uppie)
-Low End still there
-Better heat retention (Unless wrapped)
Just my $.02...
wrx-boy is offline   Reply With Quote
Old 02-03-2006, 12:06 PM   #20
MachinesWRX
Member#: 89484
2005 WRX
CGM
Well im in a predicament then...I want to keep good low-end but i love the equal-length sound much better then the stock sound.
Any recomendations for some good EL headers?
MachinesWRX is offline   Reply With Quote
Old 02-03-2006, 12:11 PM   #21
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
The Fujitsubo was looking good.. and the GP Moto's include the "up pipe" in the design. APS has a sick equal length system but would require the STi oil pan to fit the WRX.
Old 02-03-2006, 02:26 PM   #22
testes1010
Member#: 47145
2012 Gas Saver
that is completely correct, that what I'm running....
Old 02-03-2006, 02:40 PM   #23
perret318
Member#: 23510
WHO DAT!
Booooo... How can you like the Honda-esque fart sound over the boxer burble?
perret318 is offline   Reply With Quote
Old 02-03-2006, 02:43 PM   #24
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
It's not a boxer "burble".. it's unequal exhaust pulses. And it's not Honda-esque.
Old 02-03-2006, 03:21 PM   #25
perret318
Member#: 23510
WHO DAT!
OK, so it's not from the boxer design itself; it's the unequal-length headers, fine. But I stand firm on the Honda-esque-ness of the equal-length headers' sound.
Need stock header and aftermarket uppipe psyber_0ptix NESIC Private Classifieds 9 04-08-2007 09:29 PM
wrap on stock headers vs aftermarket w/ wrap? OvrClkdPmp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-31-2005 12:52 PM
stock egt vs aftermarket REDI-wgn Engine Management & Tuning 8 01-31-2005 05:35 PM
Cobb headers - stock catback vs aftermarket chrhon Normally Aspirated Powertrain 7 04-03-2004 10:02 AM
Weights of stock exhaust VS aftermarket components twinz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-16-2002 03:09 PM
