Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 02-02-2006, 02:24 PM   #1
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
Default STi V4 boost solinoid ?'s
So I figured out that my boost solinoid isn't working. I ordered a blitz EBC to replace it.
My question is I've got 2 solinoids, one to control my wastegate actuator and another that's hooked up to a little black map sensor. Do I take out both solinoids? Does that little black map sensor have any function other than for the factory boost control?
Thanks all
XENONSVX is offline   Reply With Quote
Old 02-03-2006, 09:10 AM   #2
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
bump...
Old 02-03-2006, 09:15 AM   #3
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Should be 2 separate vacuum lines. One goes from the intake to the pressure sources valve, then to the MAP sensor. The other off the turbo tee line to the boost control which vents back into the intake hose. Never disconnect the line to the MAP sensor. You have to leave the boost solenoid plugged in when you take the boost hoses off for your Blitz control or you will get a CEL.
Ver.III is offline   Reply With Quote
Old 02-03-2006, 10:55 AM   #4
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
I am already getting a CEL because of my boost solenoid. If nothting was wrong with it I probably wouldn't of bought the EBC, but since it did I may as well up the boost a lil. will a resistor fix the CEL I am getting with the bad solenoid? Or am I stuck with the light unless I pick up a new solenoid?
Still unclear as to what the actual function of that MAP sensor is, seams to me like it's just there for the factory ecu to control the boost. Seams like the MAF would still controll the fuel, unless it's designed to use the readings from the MAP to control fuel once boost is in the system. But doesn't explain why the solinoid is there. Damn goofy set up. Nothing I have delt with uses a system like this.
Old 02-03-2006, 04:49 PM   #5
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
out of couriosity, how is the BOV setup on the K motors? i have one, but missing BOV, figured you guys would know...
my k motor has the funniest looking ignitor. shorty guy.
swapstar is offline   Reply With Quote
Old 02-03-2006, 05:04 PM   #6
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
pipe comes off of the IC, goes to rubber pipe, then the BOV goes in that. tube comes out of BOV and goes to intake tube.
Hurley 2.5 WRS is offline   Reply With Quote
fs: CA Prodrive 3port boost solinoid moreda_5 Engine/Power/Exhaust 1 01-17-2010 01:23 PM
02 WRX TopFeeds, Boost Solinoid, TMIC, Headers, Up-pipe, STI BOV,... Nitrousspeed Engine/Power/Exhaust 20 04-21-2009 09:20 AM
hoa 3 port boost solinoid canucme Engine/Power/Exhaust 1 04-16-2009 10:30 PM
Talk to me about upgrading my boost solinoid mrtrex Engine Management & Tuning 3 11-12-2005 12:53 AM
Link Boost Solinoid redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-16-2002 01:46 PM
