Old 02-02-2006, 06:45 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Having trouble starting car
Car cranks but doesn't want to turn on. I had it running a couple times but it doesn't seem to want to go. I've got a fresh tank of gas in there and I've reset the Apexi FC back to the stock maps. It just cranks and cranks but sometimes when I let off the key, it'll kinda stumble like it wants to start but it doesn't at all. I've also put some iridium plugs in, the correct ones for one step colder. Would that be doing anything to mess up it starting?
I'm thinking of pulling on of the plugs and seeing how it does and checking to see if they got fouled before I reset the maps.
Any input?
scoobyimprza is offline   Reply With Quote
Old 02-02-2006, 06:48 PM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Also, with the Apexi FC, the CEL comes on in the ON position but doesn't stay on. When I crank the car and when it sometimes stays on, the CEL comes on as I'm cranking or as the car starts up but then shuts off. What might that be and how do I check CELs on the Apexi FC?
Old 02-03-2006, 10:39 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Anyone?
Old 02-03-2006, 04:47 PM   #4
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
have you tried connecting the obd1 plugy guys to flash the cel?
no oem ecu?
check mafs? maf is a grumpy guy alota times.
swapstar is offline   Reply With Quote
Old 02-03-2006, 05:48 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I cleaned the MAF with some electronic cleaner. I don't have the OEM ECU, so I'll try to pull the CEL.
I pulled a spark plug and it was a little black with 4 miles on them.
Old 02-03-2006, 08:44 PM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Plugs are covered in fuel. I'm way too rich.
I need to figure out how to turn the injectors down with the Apexi FC.
Old 02-03-2006, 09:08 PM   #7
gt_drifter
Member#: 61907
1998 2.5 GT
spruce pearl
maybe check to see how much alcohol is in your tank... its a simple test.
alcohol + cold weather = no start... i.e. try starting a lighter when its 20 out
gt_drifter is offline   Reply With Quote
Old 02-03-2006, 09:50 PM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
The car is in my garage, so it's not cold.
Old 02-04-2006, 12:44 AM   #9
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
your plugs are going to be covered in fuel if your car cranks and don't start..
well i gues your fuel pump is working properly.. check your coil wires.. check if u plugged backwards.. check if your cam sensors bad.. check your maf..
taeyax82 is offline   Reply With Quote
Old 02-04-2006, 09:11 AM   #10
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
MAF is good and I am getting spark. The car was running fine a week ago.
Old 02-04-2006, 03:59 PM   #11
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
you check ignitor? what other strange things could it be?
Old 02-04-2006, 04:42 PM   #12
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
if your plugs are soaked with fuel.. Find some other plugs to put in, let the cylinders dry out, try again. See if that works any better. Do you have a spare coil to try out?
subbyspeed is offline   Reply With Quote
Old 02-04-2006, 05:10 PM   #13
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
All the coils checked out, so I pulled all the spark plugs and each one was foul so I cleaned them up. The car fired right up after that.
Old 02-04-2006, 05:16 PM   #14
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
So it starts right up, and then it'll die?
Old 02-04-2006, 06:14 PM   #15
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
similar to old carburetor problems.. hmm old carburator cars does when starting.. just have to adjust the fuel valve to fix this problems(on carb cars)..but our cars.. fuel injected and controlled by ecu..hmm check fuel pressure regulator.. what mods do you have on the car?? what kind injectors? did you get them tuned if modded or aftermarket injectors??
Old 02-04-2006, 06:36 PM   #16
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Car runs fine now. Just had to clean up the spark plugs.
Old 02-04-2006, 07:46 PM   #17
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
nice!
Having trouble starting my sti. El Senor De KC Texas Impreza Club Forum -- TXIC 37 07-16-2010 07:48 PM
car is having trouble starting? Cusson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-28-2006 07:37 PM
Freezing temps: anybody having trouble starting their car? kamil212 Mid West Subaru Owners Club Forum -- MWSOC 8 12-20-2005 10:43 PM
Anyone using Jun272 have trouble starting? sponaugle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 43 01-11-2005 11:43 PM
Is anyone having trouble starting in the cold? M a t t General Forum Archive 37 12-11-2000 04:43 PM
