Old 02-02-2006, 06:49 PM   #1
weaC sauCe
Member#: 43625
2011 Ford Raptor
world rally blue
Default What code reader would you recommend?
I am using a UTEC with my Sti but need to read the engine codes. Is there a good quality inexpensive one? If I have to spend a bunch for a good one should I just buy an Access Port instead?
weaC sauCe is offline   Reply With Quote
Old 02-02-2006, 07:25 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The AP is not a good code reader, it isn't a true OBDII device and won't always report codes accurately.
You need a separate, generic OBDII scanner/reader. My recommendation is AutoXray, www.autoxray.com
They have a range of units with varying features that should meet your needs.
Old 02-02-2006, 07:26 PM   #3
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
ScanGauge $129.99. Works great and also tells you 4 sensor readings at a time. You can pick from 11 out of the 12 it can show. It won't show the Fuel pressure but it will show all the other ones it says it can. It has a 1 to 2 sec. delay but will deffinetly show you the basic sensor readings as the ECU sees them.
wrxdrvr is offline   Reply With Quote
Old 02-03-2006, 01:25 PM   #4
weaC sauCe
Member#: 43625
2011 Ford Raptor
world rally blue
Thanks guys, I will pick one up.
Hank
Old 02-03-2006, 02:25 PM   #5
Freon
Member#: 88322
2009 BMW 135i
I use a cheap Actron unit. Cost $80. Works fine to read codes, nothing special.
Freon is offline   Reply With Quote
Old 02-03-2006, 02:30 PM   #6
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
what about ecuExplorer? I have been using that with my cobb cable....will that not pick up all possible CELs?
Rasmusson14 is offline   Reply With Quote
Old 02-04-2006, 01:31 AM   #7
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Me too i bought it t Bridge Auto parts on 9A in Elmsford, it was same price.. it would be better if it wasnt LCD screen
PaulRex is offline   Reply With Quote
What HID kit would you recommend? brfatal Electrical & Lighting 23 06-28-2005 08:44 AM
('93-'01) What tools would you recommend for an Impreza owner? akm3 Impreza Forum 3 09-27-2003 06:51 AM
Coming up on 20k. What would you recommend be maintenanced. thrdeye Service & Maintenance 1 08-06-2003 07:05 PM
What mbc would you recommend? Impreza01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-04-2003 10:39 AM
what tire size would you recommend? nick25RS Brakes, Steering & Suspension 4 11-18-2002 10:23 PM
