Old 02-02-2006, 08:55 PM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default EJ20K spark plug wires
When you folks with Ks need plug wires, which do you get?
Lachlan is offline   Reply With Quote
Old 02-02-2006, 09:02 PM   #2
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
I think EJ25D should work.
THAWA is offline   Reply With Quote
Old 02-02-2006, 09:03 PM   #3
Lachlan
Member#: 19470
1981 Brat GL
Which one is that?
Old 02-02-2006, 09:07 PM   #4
THAWA
Member#: 44581
3 Boxers 2 AWD
Dohc 2.5 Na
Old 02-03-2006, 05:25 PM   #5
Lachlan
Member#: 19470
1981 Brat GL
I got some of those from the dealer today (P/N SOA430Q122) and they are not the same lengths. Any other suggestions?
Old 02-03-2006, 05:30 PM   #6
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
i think there at 2 types.
there are dohcs with a offset coil pack (i think)
and i know ive seen a dohc 2.5 with a centered coil pack, it was in a legacy 2.5GT. those are the ones that should fit.
did the ones you get have different lengths per side?
Hurley 2.5 WRS is offline   Reply With Quote
Old 02-03-2006, 05:36 PM   #7
Lachlan
Member#: 19470
1981 Brat GL
There are two pairs, and there's a very slight difference in length of the two. One of the pairs has the coil pack connectors at a 90 degree angle, the other pair is straight. The ones on my car are all stubby straight.
Old 02-03-2006, 05:42 PM   #8
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
so they would still fit right?
im trying to look into this as well, i need new wires too
Old 02-03-2006, 05:44 PM   #9
Lachlan
Member#: 19470
1981 Brat GL
Mine are set up with one short, two mediums, and two long. The coil side connectors look nothing like the ones they gave me.
I think there must have been a change in the 98s at some point. Kevin@ JDM importers suggested looking at NGK wires, but nobody sells those around here.
Old 02-03-2006, 06:48 PM   #10
Lachlan
Member#: 19470
1981 Brat GL
The 97 Legacy and 98 RS NGK wires are FX54; I called up a place that sells NGK and they said the EJ20K takes the FX47, but they don't have access to them.
Old 02-03-2006, 07:30 PM   #11
Mudpup
Member#: 11855
2001 STi IV RA swap
'87 RXII in progress
Magnecor KV85's. Download their pdf catalog and follow the directions for Subaru. Kinda spendy, but they cover all variations of the ej20's plug wires, and their product kicks arse.
Jason
Mudpup is offline   Reply With Quote
Old 02-03-2006, 10:36 PM   #12
Lachlan
Member#: 19470
1981 Brat GL
yes, but Magnecors cost 3x as much as either NGK or OEM
Old 02-03-2006, 10:53 PM   #13
Lachlan
Member#: 19470
1981 Brat GL
Can anyone with an EJ20K confirm the successful use of either 98 RS or 97 Leg GT wires?
Old 02-04-2006, 03:37 AM   #14
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
Jason
good info, thanks a bunch.
is KV85 the part or model number?
Old 02-04-2006, 07:33 AM   #15
Mudpup
Member#: 11855
2001 STi IV RA swap
Model number. The catalog will break down the part number based on year, length, connection type at the coil, and shape of the boot at the plug. KV85 is their wire set most applicable to street use.
As for being three times as expensive...... I've never been rational with my Impreza. Too much associated dopamine. If you want cheap, buy a dsm.
Jason
Old 02-04-2006, 12:28 PM   #16
Lachlan
Member#: 19470
1981 Brat GL
I think the magnecor p/n for EJ20K's is 45339 (teardrop dust covers, female coil towers)
Old 02-04-2006, 12:29 PM   #17
Lachlan
Member#: 19470
1981 Brat GL
Jason
$50 for OEM or NGKs still isn't cheap...
Old 02-04-2006, 04:05 PM   #18
Lachlan
Member#: 19470
1981 Brat GL
Bumpo
Old 07-13-2006, 07:02 PM   #19
Zora
Member#: 74712
2006 Saab 92x Aero
Obsidian Black Pearl
bump indeed
Zora is offline   Reply With Quote
Old 10-06-2007, 05:02 PM   #20
2002t-wrex
Member#: 37729
2004 WRX Wagon
Am I able to walk into a autoparts store and pick up a set that will fit my EJ20K (VER4 Type R)? I dont want special order that has to come in the mail.
2002t-wrex is offline   Reply With Quote
Old 10-06-2007, 05:51 PM   #21
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not that i have found
only thing i found was japanparts or magnacore big $ either way
spark plug wires/ plugs reality1011 Normally Aspirated Powertrain 30 02-27-2010 10:09 AM
FS: STi spark plug wires for non-coil-on-plug turbo engines Necromancer VIC Private Classifieds 6 09-20-2009 12:35 PM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
('93-'01) Are the spark plug wires the same for the Impreza 1999 to 2001 2.5rsMI Impreza Forum 0 06-11-2001 06:15 PM
Spark Plug Wires Alpine Sube New England Impreza Club Forum -- NESIC 1 07-14-2000 01:51 PM
