Old 02-02-2006, 08:59 PM   #1
tech
Member#: 73175
2004 wrx
java black
Default Accessport with 2,5 inch exhaust
this is not a bad thing is it???? or do it really takes 3 inches exhaust???
tech is offline   Reply With Quote
Old 02-02-2006, 09:19 PM   #2
hondaeater69
Member#: 60324
2.5 will be fine, try to keep it one consistent diameter from the turbo-back FTW
Old 02-02-2006, 09:47 PM   #3
wrxxed
Member#: 20567
04 STi
Sil/Sil
Cobb recommends the dp be 3". You could run stg1 though.
wrxxed is offline   Reply With Quote
Old 02-02-2006, 10:01 PM   #4
tech
Member#: 73175
2004 wrx
java black
i know they recommend a 3 inch cause they sell a 3 inch but nowhere do they specify that it absolutely takes a 3 inch. who is running 2.5 with cobb
Old 02-02-2006, 10:19 PM   #5
hondaeater69
Member#: 60324
you can run it, trust me, don't listen to that noob. How long is the 2.5"? (how far from the turbo back is it the same diameter)
Old 02-02-2006, 11:05 PM   #6
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
2.5" is MORE than enough on the stock turbo.
mcowger is offline   Reply With Quote
Old 02-03-2006, 10:53 AM   #7
wrxxed
Member#: 20567
04 STi
Sil/Sil
hondaeater learn some manners!
Old 02-03-2006, 10:55 AM   #8
pudnana
Member#: 89071
2000 Blue 2.5 RS
2004 Java WRX
i'm running stage 2 with a 2.5 inch bosal diverted wastegate downpipe and a stock STI catback on my 04 wrx, so good so far.
pudnana is offline   Reply With Quote
Old 02-03-2006, 01:32 PM   #9
hondaeater69
Member#: 60324
that was me with manners
Old 02-03-2006, 01:38 PM   #10
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I'm running a custom tune @ 18psi peak, stromung DP, stromung high flow cat, 3" -> 2.5" intermediate pipe and 2.5" scoobysport axleback and it's fine.
fwiw- the scoobysport axleback flows better than my previous 3" axleback.
mike
crazymikie is offline   Reply With Quote
Old 02-03-2006, 01:41 PM   #11
Virtigo
Member#: 95478
2004 Impreza WRX
Java Black Pearl
Default could be good
Dont think there will be a problem.....I am running Invidia 3" DP --> Daddy's Flex Joint 3"-->2.5" Intermediate and a DynaFlow (STI look-a-like) Axel back....sounds GREAT....and alot quiter then 3" all the way.
Virtigo is offline   Reply With Quote
Old 02-03-2006, 04:37 PM   #12
tech
Member#: 73175
2004 wrx
java black
I will be runing a scoobysport shorty downpipe+ stock 3rd cat+ stromung 2.5 intermediate pipe+ scoobysport axleback??? oh yeah and a catless uppipe
Old 02-03-2006, 04:42 PM   #13
hondaeater69
Member#: 60324
I would personnally get a pipe to replace the stock midpipe, with a high flow cat if necessary. That pipe will restrict you more than the stock muff, so if money is tight, do the whole DP first, then get the rest of it in 2.5" and you will be set.
fs: WBR 3 inch to 2.5 inch exhaust adapter $40 silverGDB SCIC Private Classifieds 10 04-09-2009 10:44 PM
2.25 Inch exhaust vs 2.5 inch exhaust kghost Normally Aspirated Powertrain 3 02-27-2007 04:51 PM
2.5 inch exhaust with VF34 shk_1010 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 49 07-03-2004 09:11 PM
Power differences between 3 inch and 2.5 inch exhaust? pha qed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-13-2004 05:14 PM
3 inch downpipe into 2.5 inch exhaust? krillz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-04-2003 09:50 AM
