#1 |
Member#: 60116
Vehicle:1999 RS Coupe Silver Thorn |
Later this month, I am getting a EJ20G block and plan on using the stock internals.
One of the ideas was getting WRX heads and then just using a US WRX ECU. Then the highly esteemed gentleman I am buying the block from had mentioned if he was going to keep it, he was thinking of using 2.5 heads. This opens doors to other possibilities. High Boost Turbo, or super charging; but then the choice of ECU then potential need for major re-wiring loomed into view. Although I would like to say I have time to do re-wiring, I don't. The car needs to remain streetable, and if at all possible I would like to use the ECU in the car now. Knowing that I would have to use add on/piggyback controls for boost, and fuel management. Admittedly, I am crazy. However I would like your constructive input.
#2 |
Member#: 60116
With the number of piggyback units out there, Who is best, UTEC, Greddy, Haltech?
WOuld it be better to replace the stock ECU with one of the ECU's that connects directly to the existing wiring? The replacement ECU in this case would provide all controls. Pay the money in one major purchase, or piggyback in multiple purchases? Wouldn't it be more desirable to have 1 ECU rather than a bunch of ancillary controls massaging the information going to the ECU? |
#3 |
Member#: 102779
Vehicle:1998 PM if u need JDM bits..... |
um. lota stuff you are posting.
there is no aftermarket ecu that is direct plug into your 99 rs harness that i have heard of. if doing, it might be deemed prudent to get it done all at once. if going standalone, bite teh bullet and get somthing good. stay away from teh piggybacks. 1 ecu is ideal. if you have to pass emissions it would be ideal to run the full usa WRX setup. you can outsource the wiring harness conversion, lotsa good shops that do that. then any reflash is an easy job. |
#4 |
Member#: 60116
the engine harness would be fairly straight forward, I would be able to do that no problem. Integrating the engine harness and body harness to the ECU would be the one I would like to stay away from.
Unless you are saying they would give me one from the engine to ECU. I still need to look at WRX to RS wiring. |
#5 |
Member#: 60116
moderator please move this to the tuning forum.
| Thread Tools | |
| Display Modes | |
| Of those R-STI's with SOHC 2.5 heads and 255/257 blocks: | Dubstar112 | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 05-23-2010 08:06 PM |
| SOHC 2.5 Heads on EJ22E | renyo | Normally Aspirated Powertrain | 4 | 05-30-2009 11:22 PM |
| WTB: SOHC 2.5 heads | pilfflip | NWIC Private Classifieds | 3 | 11-19-2006 04:49 PM |
| Will a DOHC f2.5 intake manifold bolt up SOHC 2.5 heads | w chapman | Normally Aspirated Powertrain | 9 | 10-11-2005 10:24 PM |
| EJ22T w/ SOHC 2.5 heads | cjfike | Normally Aspirated Powertrain | 11 | 10-01-2005 03:21 PM |
