Old 02-02-2006, 09:46 PM   #1
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
Default 2.5 NA heads on EJ20
Purposed swap EJ20 Block with NA 2.5 heads, 2.5 NA manifold and anything else I can salvage from EJ25. Using FMIC so fitting TMIC is not a problem.
I am piecing together my swap. I would like to get a list going so I can start buying parts. Below is a known needed parts list ? Below that are parts I' not sure are needed? Any other parts needed please add!
*I know I will need a custom bend up pipe to clear the cross member.
*Oil pan with return from turbo.
* WRX water pump, thermostat , and inlet neck
*WRX fuel pump
*Upgraded Clutch
*FMIC kit
*Turbo
*Gaskets
Item I'm not sure about and would like opinions on
*Engine management- E-manage possibly use RS ECU?
*WRX Oil Pump?
Any other parts I will need
jayfressh is offline   Reply With Quote
Old 02-03-2006, 05:19 PM   #2
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
why not just get a stock WRX exhaust manifold (for $40) and the proper turbo X member for $140 or such. cheaper, easier, better than getting ghetto fabulicious stuff made up. bolts right on, and you can source all the parts so easily
swapstar is offline   Reply With Quote
Old 02-06-2006, 08:17 PM   #3
jdmisacult
Member#: 100652
I was also curious how the 2.0 block would do with the dohc 2.5 heads. what kind of compretion ratio would we be lookin at?
jdmisacult is offline   Reply With Quote
Old 02-07-2006, 01:53 AM   #4
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
well it depends if he is using the 2.5NA SOHC heads or DOHC heads....because the WRX exhaust manifold wont bolt up to the SOHC heads IIRC
civic2scooby is offline   Reply With Quote
Old 02-07-2006, 06:39 AM   #5
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
how do you know? have you tried this or are you blurting out HEARSAY.
they bolt up just fine. all dual port heads have same pattern. you can swap a 1993 ej18 header on a 2005 sti ej257 pair of heads. thats no problem
Old 02-07-2006, 02:44 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
{blurting}
sohc heads are longer and foul on the uppipe
{/blurting}
Old 02-07-2006, 03:34 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Originally Posted by Jaxx
{blurting}
{/blurting}
classic... and correct...
Old 02-07-2006, 05:06 PM   #8
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
The heads will fit fine. The compression ratio will be about 8:1 very boost friendly. I'm opting to buy an up pipe from Chad who post here, it will clear the RS cross member.
Swapstar were you refering to bolting WRX exhaust manifold to 2.5 block?
Old 02-07-2006, 05:43 PM   #9
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
exhaust manifold bolts on to head, not to block. what block you use is un-important
Old 02-07-2006, 05:59 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
nevermind...
Old 02-07-2006, 05:59 PM   #11
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
you will have better luck, more reliablity and spend less money if you go with a WRX engine.
Those heads will fit that block. Some say they have a much better flow as well.
Zephyr is offline   Reply With Quote
Old 02-08-2006, 01:11 AM   #12
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
sorry oh subaru master...when I was asking about an RS-T setup I was told by several members on here that the exhaust mani. from the WRX wouldnt bolt up to the SOHC heads.
Old 02-08-2006, 07:12 AM   #13
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
did they say this from experiance or from hearing somthing from their nextdoor neighbors cousins uncle? lotsa good info on these boards, if you have seen a picture or done it yourself, then it is probably true. otherwise......
Old 02-08-2006, 12:07 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
oh, come on my friend. Just eat your hat and admit for once you didn't know the answer...
Old 02-08-2006, 12:10 PM   #15
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
I had a wrx header on my 2.2L n/a sohc motor, that worked. The EJ series motors should all be able to bolt to any EJ designed Ex.manifold as long as they are dual Ex.port heads. But then again the story could be different with the 2.5 SOHC.
The problem lies with the n/a X-member as well as the n/a water pump inlet hitting the cross pipe. If you are going to use a turbo exhaust manifold, it will set you up for the factory up pipe location.
There exists a custom made up pipe solution for turboing an n/a motor and not interfering with the Xmember, was it north ursalia that had it? maybe unique motorsports?
It uses the n/a ex.manifold, now it may not be the most efficient set up, as the ex. gases have to travel further before they reach the turbo, but it will work and you wont have to swap the xmember.
Hope this helps,
~Justin
Kawikid20o2 is offline   Reply With Quote
Old 02-08-2006, 01:07 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
The problem with the uppipe is absolutely specific to the SOHC EJ25 heads. DOHC EJ25 and SOHC EJ22 heads have no problemo. There is some local guy here in Colorado who made the SOHC EJ25 heads work, but he had cut a big ole chunk out of the back or the head. Everyone who looked at them, myself included, thought he was nuts and should have just gotten a custom uppipe made up...
and Chad=Unique Motorsports= custom up-pipe...
Old 02-08-2006, 04:37 PM   #17
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
word. post a picture. id love to see hacked head.
skare. run away.
Old 02-08-2006, 05:13 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
I know he used to post here, but don't remember his screenname. Saw the car at a local meet about 2 years ago and haven't seen it since...
Old 02-08-2006, 08:23 PM   #19
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Chopped head sounds really interesting, Matt.... however I'm not smart enough to figure that one out.
Old 02-08-2006, 10:27 PM   #20
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
the quesiton was bolt to head. not up pipe clearance. i stand uncorrected and correct.
haha
Old 02-09-2006, 02:54 AM   #21
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
haha
that sound like some **** I would say
NA EJ25 heads on EJ20? bigolrig Newbies & FAQs 6 10-01-2009 08:57 PM
WTB 2.5 NA longblock or just heads morrocco88 NWIC Private Classifieds 13 10-08-2007 10:42 AM
2.5 na block with wrx head gusty_1987 Subaru Conversions 0 12-21-2006 05:12 PM
WRX Valve Springs/Retainers on NA 2.5 DOHC Heads? MY99 2.5GT Normally Aspirated Powertrain 2 02-06-2006 01:01 PM
2.5 liter heads on 2.2 liter block evo2rex Subaru Conversions 1 01-27-2004 03:46 PM
