Old 01-06-2011, 04:39 PM   #26
ydeardorff
Member#: 269164
I too am trying to massage an 05 WRX 2.0 Turbo into a VW based kit car. I have only just bought the engine, and am now looking for an 02 trans to shorten (with flipped internals) to complete my install.
I love this site!
I will be using an aftermarket AC system and compressor, and have a push button starter in the car.
I would like to make this build as bare bones as I can, but also using whatever is already available in the ECU and wiring system. speedo, tach, AC, etc. But obviously I wouldnt need ABS, or Airbag systems. I still need the ECU pin outs for the 05 and 04 ECU's, as well as the wiring schematics.
Any help, or links for exactly what is needed? Im new to this, but not mechanics. I have the overall design of all of this fairly figured out (basics) but any help would be great to simplify things.
Please PM me, or email me. Id like to compile a to do, or a build list in a word document to keep everything organized, then pass this on to future swappers with the conversion perversion.
Thanks
Yaughn
ydeardorff is offline   Reply With Quote
Old 01-07-2011, 02:17 AM   #27
a914622
Member#: 264504
I know this guy has do a few swaps with the later computers. Drop him a line. I think he does a "swap" harness to work with none subaru frames.
http://www.benplace.com/vw2.htm
a914622 is offline   Reply With Quote
Old 02-24-2012, 12:16 PM   #28
Beenyboy
Member#: 311401
2002 Forester
grey
Funny that I found this thread wile searching on the net and stumble on a post with a link to my website.
I'm new so I can't start a thread, but I will soon.
I'm now doing a 06 Forester XT conversion, the Turbo harness was my fist.
90% done. I'm sadly missing some relay box that I have to get for the SECONDARY AIR COMBINATION VALVE RELAY 1 & 2.
After that I will see what pin # C26 and C24 need as feedback.
There WILL be a simple way to bypass immobilizer.
As to other ECU wiring conversion from 2002 to 2010 I will glad to help if you have any question. I did 58 Subi conversion so far. Mostly with late engine.
Ben
http://www.benplace.com/subi_jm1.htm
Beenyboy is offline   Reply With Quote
Old 02-25-2012, 07:33 AM   #29
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Does it get more complicated with the newer engines, 2008+, as far as running the stock ECU, immobilizer-wise?, or is it still: ECU, Key, immobilizer module
Old 02-25-2012, 07:45 AM   #30
Beenyboy
Member#: 311401
2002 Forester
grey
Yes, it's hell, mostly because starting 08 every car is CAN-BUS.
The Analog speed signal is gone, it's now digital and come from the front wheel ABS system. My solution is simply to use 06-07 Impreza/Forester harness.
Old 02-25-2012, 10:13 PM   #31
tom bauer
Member#: 310141
CAN data and immobilizer is in late 04 up. solution is to use 04 XT or early 04 STI ECU. also to eliminate the vsv emission circuits see the thread on code P1446
tom
tom bauer is offline   Reply With Quote
Old 02-26-2012, 06:52 AM   #32
kyran013
Member#: 311390
i'm having the same dqamn problem!!!!
kyran013 is offline   Reply With Quote
2005 STI immobilizer+ECU+Ign Switch+Key+Steering column+Wheel Team Scream Interior/Dressup/Audio & Security 9 04-10-2010 03:43 PM
Ga 2005 sti 2.5 engine/5sp ra gear set BARTS Engine/Power/Exhaust 3 11-06-2009 06:38 PM
2005 STi AR FAB engine build.**PICS** moorebl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-13-2007 09:08 AM
2005 STi Suspension Question ProjectSTI General Community 2 06-17-2004 11:45 AM
2005 STi offset question CTOESHO Tire & Wheel 3 06-12-2004 11:43 PM
