Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 02-03-2006, 06:39 AM   #1
evotell
Member#: 85492
07 STi WRB
06 Caterham Super 7
Forester Modified Integrale
Lancia Delta HF Integrale
All wheel drive Italian super car, with fully documented and comprehensive service history. This very unusual car featured in many European car magazines and TV programs is with out doubt the most coveted of all Integrales. During the past 15 years this amazing car has had in excess of $110.000.00 CDN of performances modifications by Europe’s leadings Ferrari & Integrale specialist. From the outside this incredible car appears totally stock as does the interior. The list of modifications undertaken to F1 standard include, Motec data logging engine management, 320 BHP motor, 360 ft Ib torque, Ferrari F40 brakes the list is vast and comprehensive. Finished in its original Monza red with grey Alcantara Recaro trim. Totally rust free and in outstanding condition with a shattering performance of 0-100 km in 4.1 seconds.
Engine:
1995 cc, 8V 2 liter Twin Cam, with counter rotating balance shafts
Motec data logging engine management, with anti lag & traction control facility
Fully balanced and ported cylinder head, with 3 angle valve seats & sodium filled exhaust valves
Arbath Group A head gasket
Uprated stainless Cylinder head bolts
Polished and shot piened con rods
Cosworth forged pistons with Group A gapless rings
Uprated Oil pump with modified pick up
Group A, Abarth camshafts
Group N Light weight flywheel
Fully balanced crankshaft, rods, pistons, flywheel and clutch
Group A, ceramic Turbo Charger with 360 bearing with machined housings.
Relocated and modified intercooler with uprated stainless hoses
Matched and polished inlet manifold
Turbo Charger water spray system with stainless tank in trunk
Group N stainless piston type dump valve
Uprated Hi flow competition injectors
Vernia cam wheels
Uprated throttle body with matched and machined faces
3 inch aircraft spec stainless exhaust system with aircraft type stainless hangers
Uprated competition & oversized alloy radiator, with stainless baffled header tank
Down draft Stratos Fluted induction box
Silicon hose’s
320 BHP with 360 ft Ib torque & 3800 RPM
0-100km 4.1 seconds
Transmission/Brakes:
5 speed ZF gearbox, with modified short shift cable change
Uprated main shaft bearings
Viscous center diff with 70/30 torque split to rear (stock 60/40) huge expense
Uprated and strengthened front drive shafts
Competition sintered clutch, with uprated slave cylinder and stainless clutch hose
Rear ZF LSD
Evolution rear brake calipers with oversized drilled Tarox racing rotors
Tarox 6 piston caliper front brakes with 290mm drilled rotors
Stainless brake hoses
Suspension/Steering:
Evolution front/rear suspension control arms
Evolution front lower wishbones
Evolution Hubs and top mounts
Rose jointed front drop links
Revalved Koni sport dampers, with adjustable rebound
Eblach Progressive rate springs
Uprated rear anti sway bar
Uprated front wishbone mounting plates
Group A, rear diff cradle
Group A rear diff carrier
Sparco front turret brace, with rose jointed bearings
Modified Evolution steering rack
Modified front/rear dampers to adjust camber
Bodywork:
Group A roof strengthening plates
Rear triangulation strengthening cage fitted to trunk, inc rear turret brace
Front chassis rail and A post strengthening plates
Modified hood with extra air intakes
Fully wax oiled shell
As you can see from the above list this is a very serious car that can only be described as totally unique within North America. Registered in Alberta, Canada with license plate No. LANCIA.
Only serious enquirers need apply, no tire kickers, test pilots or dreamers.
For further details call Terry Johns on (403) 302-9322. or post
Red Deer. Alberta.
$39,000.00 CDN
evotell is offline   Reply With Quote
Old 02-03-2006, 09:40 AM   #2
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Nice Car but OT need to be posted in the privet classified section.
-Kris
Chp_Stix is offline   Reply With Quote
Old 02-03-2006, 09:58 AM   #3
Pee_Sack
Member#: 98266
2003 WRX Cobb Stg 2
Same as the sky
Sorry for the super newb question, what does OT stand for?
Pee_Sack is offline   Reply With Quote
Old 02-03-2006, 10:15 AM   #4
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
Any chance you'll bring the Integrale out to the next meet?
-J
Jitenshakun is offline   Reply With Quote
Old 02-03-2006, 10:35 AM   #5
tora
Member#: 5851
09 Forester XT
+ NA Miata
Sounds beautiful...any pictures to share?
tora is offline   Reply With Quote
Old 02-03-2006, 11:12 AM   #6
evotell
Member#: 85492
07 STi WRB
06 Caterham Super 7
-J
Yes. It lands in 4 weeks time.
Old 02-03-2006, 11:13 AM   #7
evotell
Member#: 85492
07 STi WRB
06 Caterham Super 7
-Kris
sorry I thought I had done that. Guess nobodys perfect
Old 02-03-2006, 11:58 AM   #8
Jitenshakun
Member#: 61586
2005 STi
Old 02-03-2006, 12:38 PM   #9
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Wait this is for sale? Or you just bought it?
Either way, sounds like a great car!
Keiho is offline   Reply With Quote
Old 02-03-2006, 12:55 PM   #10
evotell
Member#: 85492
07 STi WRB
06 Caterham Super 7
Its both
Lancia Hyena: Zagato's Delta Integrale Coupe Spotted in The Netherlands AVANTI R5 Non-Subaru News & Rumors 1 07-04-2009 01:03 PM
New Lancia Delta Integrale to take on EVO/WRX/GT-R Mind Non-Subaru News & Rumors 23 09-07-2006 01:05 AM
Integrale evotell Canada Region Forum 8 11-28-2005 07:00 AM
Buy an Integrale? johnei Off-Topic 30 03-22-2005 03:23 PM
Does anyone in the states have an integrale? Turbo9000 Off-Topic 0 01-18-2005 09:42 PM
