Old 02-03-2006, 08:59 AM   #1
riggs
Member#: 85389
Default FREE ECUExplorer Datalogger 3.0.25 released today for 2006 WRX..
http://www.tari.co.za/cgi-bin/yabb2/...num=1138965460
This program absolutely rocks and I hope everyone that has the Cobb AP, etc takes advantage of it...
Now just have to figure out the settings I need to use..
Best part is the software is free and since you already have the cable that comes with the Cobb AP, you can datalog at no extra cost...
riggs is offline   Reply With Quote
Old 02-03-2006, 09:11 AM   #2
Silver_04_WRX_SC
Member#: 67198
2004 Baja Turbo
Forgive me for my noobiness, but what will this do for the AP?
Silver_04_WRX_SC is offline   Reply With Quote
Old 02-03-2006, 09:14 AM   #3
riggs
Member#: 85389
You remove the OBDII cable that attaches to the AP and you hook it straight to the computer...(serial port)
The cable syncs with this software and you can read the majority of the data that the ECU reads...
enabling you to datalog....(You could datalog dyno pulls, highway runs, etc.)
Awesome software, and I have been waiting patiently on a version that would support the 06 WRX...
Old 02-03-2006, 09:18 AM   #4
riggs
Member#: 85389
Thanks for moving this, my apologies for putting it in the wrong spot...
Old 02-03-2006, 09:20 AM   #5
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
On page 5 of the instructional pdf it says it doesn't support drive by wire. So this won't help any years of the USDM STIs if that's the case. The WRX isn't drive by wire is it? I honestly don't know...
SilverSurfer04STi is offline   Reply With Quote
Old 02-03-2006, 09:25 AM   #6
riggs
Member#: 85389
It does support the USDM STI, because I have several friends that use the software. I know it does support datalogging...
Old 02-03-2006, 09:34 AM   #7
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Maybe you just can't read throttle position as one of the data fields then??? Wonder why that's in the pdf then. If it works for STi that's awesome.
Does the data just get stored in a file with some sort of delimiter and then you can export the file into a spreadsheet?
Old 02-03-2006, 09:53 AM   #8
KGreb
Member#: 13463
2012 Chevy Volt
The ECU copy and reflash functions are not yet supported on the DBW ECUs. All the logging works fine.
KGreb is offline   Reply With Quote
Old 02-03-2006, 10:05 AM   #9
Zumble
Member#: 34860
2005 Forester CGM
It reads throttle position on my Forester which is drive by wire. It logs everything just fine.
Zumble is offline   Reply With Quote
Old 02-03-2006, 10:19 AM   #10
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
OK. So I can still log everything just fine even with the DBW on the STi. Cool. Thanks.
Old 02-03-2006, 12:21 PM   #11
remowgn
Member#: 41149
09 FXT
SSM
Yep, it saves a CSV file. It's actually pretty cool... you can set it so that the defroster button turns logging on and off... so you can drive around with your laptop plugged in, and you don't even have to take your eyes off the road if you want to log a 3rd gear pull or something.
remowgn is offline   Reply With Quote
Old 02-03-2006, 02:28 PM   #12
Freon
Member#: 88322
2009 BMW 135i
Flash support and logging support are completely different problems.
It isn't so much what this program will do for your AP. It's just you can use your AP cable for this program rather than have to buy an SSM cable. If you already have an AP, this is free. Give it a shot. Why not.
Freon is offline   Reply With Quote
Old 02-03-2006, 06:59 PM   #13
riggs
Member#: 85389
How do you program it to do that?
Old 02-03-2006, 07:26 PM   #14
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Not sure about the 04 wrx i do know the 05 wrx is drive by wire.
dingobite is offline   Reply With Quote
Old 02-03-2006, 10:24 PM   #15
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
in the USDM, it is the 06 WRX which is drive by wire.
colby is offline   Reply With Quote
Old 02-04-2006, 12:04 PM   #16
dingobite
Member#: 82391
08 OBP Sti
Sorry for any wrong info the 05 is differant than the 03 wrx and older models though. Right now im google the the web over and i cannot find a standard wrx pdf spec anywhere just stis and the bugeyes.
Ive had a local tuner point out to me a certain standalone system would work on the 05 and not on the bugeyes due to the way they where built im just having a memory lasp on what he said right now.
Old 02-10-2006, 10:02 AM   #17
sebtarta
Member#: 82883
2006 2.5i Wagon
'72 Nova Turns & Stops
I have a question on this.
With my STi 05, and a 30 +/- min. drive will the data logging be huge?? it must right, about 1000 lines??
Also how to you make the ecuExplorer to start loging the data and how to save it. I have the pdf next to me, but it is not very informative on how to work the software. it shows in detail what it does.
Any light for the ecuExplorer ppl....thanx
sebtarta is offline   Reply With Quote
Old 02-10-2006, 10:16 AM   #18
edmundu
Member#: 54672
For 30min of continuous logging, you can expect a heck of a lot more than 1000 lines. I logged about 10.5 min. and it was 2830 lines.
To easily save the logs, right click in the pane which shows the available values to log, and select to trigger logging to a file using the rear defroster. Then, all you do is press the rear defrost, and it'll start logging, then press again to stop. It'll save it using the date/timestamp naming convention. Within the software you can choose where you want to save the logs. By default they are in the C:\Programfiles\Tari Racing Software\Ecuexplorer folder.
edmundu is offline   Reply With Quote
Old 02-10-2006, 11:05 AM   #19
sebtarta
Member#: 82883
2006 2.5i Wagon
Thank you very much. I guess i wont log a full 30min.
Old 02-15-2006, 09:37 PM   #20
theicewall
Member#: 70532
2004 WRX
Tariracing for Mac users anyone? Am I stuck borrowing a PC laptop?
theicewall is offline   Reply With Quote
Old 02-15-2006, 10:36 PM   #21
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
For those who have PDX or TDC maps, what steps do we need to take to record logging? how much information do either PDX or TDC require for correcting any problems you car may have?
Can someone explain step by step what needs to be done?
Old 02-15-2006, 11:20 PM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...ya just need the cable and a laptop and the progie
Old 02-17-2006, 08:00 PM   #23
Riight112
Member#: 32071
2004 WRX STi
WR Blue
+1 for a mac version please!
Riight112 is offline   Reply With Quote
How do I use AccessPort 2.0 for 2006 WRX? wonsin83 Newbies & FAQs 10 05-08-2007 08:36 AM
I thought there was going to be a 250HP 3.0 Legacy as well for 2005? HB_Dad News & Rumors 21 05-04-2004 12:51 PM
3.0 h6 question again in a wrx.. jefersun Subaru Conversions 14 02-25-2004 05:11 PM
release date for 2004 WRX, not STi WRX lova News & Rumors 12 02-24-2003 04:37 PM
h6-3.0 rear upgrade, questions for application to non WRX ciper Brakes, Steering & Suspension 7 05-25-2002 01:11 PM
