Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Old 09-19-2001, 04:52 PM   #1
Jademonkey
Member#: 9213
2000 Nissan Xterra
Red
Default swapping front and rear tires
My front tires are starting to show signs of balding. My brother suggests I go ahead and swap the front and rears. I did this with my old Buick but was wondering if that would have any negative effects on the AWD system.
thanks,
greg
ps i think i-club.com should be printed on the first page of every owners manual. I had a heckuva time finding anything about my car until i found this site.
Jademonkey is offline   Reply With Quote
Old 09-19-2001, 05:06 PM   #2
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Yikes! Fronts balding and rears in good shape?
You should get 4 new *identical* tires.
But anyway to answer your question, just jack the car up on 4 jack stands, remove tires.
Move front tires to the rear, move rear tires to the front.
It used to be a steadfast rule with older radial tires to not swap sides, and I still follow it.
So RF --> RR RR--> RF
same for other side.
remarcable is offline   Reply With Quote
Old 09-19-2001, 05:19 PM   #3
IowaRS
Member#: 5385
2000 2.5RS(T)
Silverthorn
I'll assume since you have a 2001 that you are running the stock RE92's. They are unidirectional so you can swap them front to back left to right.
Be aware that some tires (Kumho 712's for example) can only be swapped front to back on the same side (without removing the tire from the wheel)
Keep a close eye on the tire wear, the RS's seem to like to wear the insides of the tires.
I recommend checking tire wear everytime you check the air pressure in them (once a week)
IowaRS is offline   Reply With Quote
Old 09-19-2001, 06:04 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
I believe the owner's manual indicates the rotation method suggested by remarcable, and I would follow that.
It also suggests tire rotation every 6K, and I would also follow that.
Julian is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:54 AM.
