Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 02-03-2006, 04:45 PM   #1
soslow
Member#: 95027
'13 BRZed
pretend racecar
Question which year model impreza chassis to biuld on?
I will be selling my Rs soon for a forester. after I get the forester I'm going to buy another 2-door coupe. I'm trying to decide what year to get from the standpoint of emissions, etc. (thankfully they don't inspect in AR)
Here's the project: Take an impreza coupe and make it look similiar to a 22b, particularly the front and rear bumpers and flaired fenders.
The motor- fully biult EJ257 turbo w/ FMIC and ??lbs of boost until I get 540 WHP and similiar torque numbers dyno tuned of course. this power will be fed through a carbon on carbon clutch to a (possibly modified if necessary for reliability/durability) STi 6-speed. STi lsd diffs front and rear with sti 5x114 hubs, brakes (modified w/ slotted rotors and good pads) and all the rest of the STi driveline. (ok, brakes aren't driveline but you know what I mean).
coilover suspension, interior swap, blah, blah.
In other words nothing on the car is going to be the same after I'm done (probably gonna be seem welded and caged too) so should I just get a 95 brighton coupe or is there a particular reason to get a newer model impreza?
thanks for reading this novel....now for your thoughts
loganD.
and I won't be driving the car everyday, just working on it since i'll have the forsester.
soslow is offline   Reply With Quote
Old 02-03-2006, 06:23 PM   #2
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
why dont you buy soon2bgreat's car or some other monster big budget'ed swapped 2 door. theres lots running around. save yourself money too.
swapstar is offline   Reply With Quote
Old 02-03-2006, 06:36 PM   #3
Billy
Member#: 1391
1997 GF - silent ed.
12.677@107.87 untuned
There's some good info here...
http://www.rs25.com/forums/showthread.php?t=40838
Don't think you'll need to register to read it.
Billy is offline   Reply With Quote
Old 02-05-2006, 03:57 PM   #4
soslow
Member#: 95027
'13 BRZed
pretend racecar
Impreza GC8
I don't want to buy somebody elses car because I can't upfront the money and I would rather biuld my car myself. I can afford to pay it out over time if I do (most) of the swap myself
Looked at the thread and its like everybody says L model but nobody seemed to mention the 1.8 brighton coupe, is there a reason like the wiring is too different or something?
thanks.
Old 02-05-2006, 05:12 PM   #5
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
thanks.
The brighton coupe isn't much harder in terms of wiring. They're harder to find and are a little more lightweight than some of the L's.
petawabit is offline   Reply With Quote
Old 02-05-2006, 06:09 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
If weight is your concern, find a 93-96 that doesn't have ABS
Old 02-05-2006, 06:10 PM   #7
soslow
Member#: 95027
'13 BRZed
pretend racecar
i figure since they (BRIGHTON COUPE) had less options I could get one cheaper so then that is what ill do.
thanks everydody
loganD.
Old 02-05-2006, 10:26 PM   #8
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I started with a brighton. You will have to add things like a tach, new control arms in the rear so you can add a anti-sway bay, no right mirror (fine with me) rear drums, no abs. I love mine.
bmxpunk is offline   Reply With Quote
Old 02-06-2006, 02:37 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
95 or older no obd-2
Old 02-06-2006, 05:10 AM   #10
Skully
Member#: 48990
98 Impreza RS
RBP
i agree... 93-95. Since its OBD-1 all you have to pass is the sniffer and that is it.
-Thomas
Skully is offline   Reply With Quote
Old 02-06-2006, 08:54 AM   #11
soslow
Member#: 95027
'13 BRZed
pretend racecar
Impreza GC8
loks good, but it will have to be a 95 since I don't think they made the coupe before then if I remember correctly.
these aren't a problem as I have to change all that stuff anyway when I put in the STi parts and I should be able to get a tach with the interior swap, although I'm thinking of doing a custom interior...... not sure how doable that is but i'll search
Old 02-06-2006, 08:57 AM   #12
soslow
Member#: 95027
'13 BRZed
pretend racecar
Impreza GC8
oh and come to think of it wont I get OBD 2 when i swap in the new ECU and whatnot? that would be the best of both worlds, getting tested as obd1 but having all the capabilities of obd2 (but like I said they don't test in AR, but if I ever move)
Old 02-06-2006, 11:06 AM   #13
fliz
Member#: 30342
For that kind of power, you'll probably want an aftermarket ECU. None of the ones I've seen are OBDII
fliz is offline   Reply With Quote
Old 02-06-2006, 04:56 PM   #14
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
no jdm is obd2, usdm is a friendly obd2 option though
Old 02-06-2006, 05:50 PM   #15
soslow
Member#: 95027
'13 BRZed
pretend racecar
Impreza GC8
Ok I guess I'll be looking into my ECu options come swaptime....
about the abs though. Its kind of a nice thing to have in certain situations-would the abs system from an STi or another impreza work in this application? its not really a big deal as the car won't be a daily driver (more than likely won't be anyway lotsa horsepower can be addictive I've heard) just would be nice. and I could run a switch off the fuse box to deactivate ABS with just the flip of button/switch. that would be kinda cool especially if the ABS light didn't come on.
has anybody done a completely custom interior/gauges around here? like autometer speedo, tach, etc.
Old 02-07-2006, 01:44 AM   #16
swappedGF
Member#: 5075
98 v7 OBSTi
white/grey/gold
I thought V7 and up was OBDII compliant
Ill need this info if anyone can confirm. Also what is the cutoff for only having to pass the sniffer? is it 95? And is this for all states? I'm in IL
swappedGF is offline   Reply With Quote
Old 02-07-2006, 07:41 AM   #17
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
why not just get a non-abs to begin with. if you are trying to shave weight, thats a good way to get rid of an ugly thing. the abs guy also takes the space of a IC water spray holder tank. not cool
Old 02-07-2006, 04:41 PM   #18
soslow
Member#: 95027
'13 BRZed
pretend racecar
Impreza GC8
When it comes to weight I'm more concerned with getting the car as close to 50:50 weight distribution than flat out making the car as light as possibly unless someboby can explain otherwise I believe 2800-2900 lb. car that is as close as possible to 50:50 will handle better than a car that weigh 2500-2600 but is not any better balanced than stock. Jus curious about that, and I guess I wont have ABS...
*goes to the interior furom for gauge info*
Old 02-07-2006, 06:45 PM   #19
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
run heavy rear bumper beam, battar to trunk, giant wing, r180 diff, and then run a NA 2.5 motor in the front with skimpy everything. that might be close to 50-50. i dont know if its possible to do a true 50-50 with an impreza, sombody with a cornerweight scale might be able to share their exierancfe
Old 02-07-2006, 11:11 PM   #20
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I've never seen a 50/50 Impreza...
swapstar, type slower dude
Old 02-08-2006, 02:10 AM   #21
azn2nr
Member#: 35276
the above is a 96 brighton full swap. this brighton came with obd2. r180, brembos and the dash. the dash doesnt fit too well because it has the old style door cards from the 93-95/6 L. rs door cards fit with the new dash but they are hard to find and cost over 350 each side. that car with stock sti swap is verry fast and i mean verry fast. i dont know why you want 540 horsepower, with a car that weighs nothing 300 is just fine
azn2nr is offline   Reply With Quote
Old 02-08-2006, 09:30 AM   #22
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
there's a free coupe in mid-atlantic...its located in PA and needs a rear quarter panel...
Old 02-08-2006, 10:53 PM   #23
gc8gc8
Member#: 106986
i would buy 93 to 98 and do a right hand drive conversion with a jdm motor
gc8gc8 is offline   Reply With Quote
Old 02-09-2006, 12:15 PM   #24
soslow
Member#: 95027
'13 BRZed
pretend racecar
Thumbs up
hook me up with that would ya?
thats almost as good as my dad's "I don't know why you want more power you can only go the speed limit"
Old 02-09-2006, 01:14 PM   #25
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
this whole thread could be answered by
you are looking for the elusive 95 brighton coupe rather rare but very desirable AWD -rear disk
prefection would be a red one (most of the other colors are aweful) with black interior
Unequal length question. 2002 impreza headers to fit on a 2000 legacy? Super_HKS Newbies & FAQs 1 11-02-2009 07:48 PM
('93-'01) Best year/model impreza? (not wrx/sti) Hobbes2.2 Impreza Forum 4 07-11-2007 11:39 PM
New years eve party. What to play on the digital projector? Chewyguru Off-Topic 29 12-30-2005 07:52 PM
OEM wrx wing that is raised, what model Impreza does this come on? Spectre186 Member's Car Gallery 8 04-03-2005 09:52 PM
Which factory Subaru oil filter to use on my 2002 WRX gsodonis Service & Maintenance 2 10-02-2003 03:20 PM
