Old 02-03-2006, 04:40 PM   #1
tech
Member#: 73175
2004 wrx
java black
Default reading live boost with AP
my question is can i read live boost of my stock wrx before loading a base map with accessport??? Did not install the ap yet and would like to know the stock boost of my car and see if my boost gauge is accurate
tech is offline   Reply With Quote
Old 02-03-2006, 04:43 PM   #2
hondaeater69
Member#: 60324
no you cannot. In order to get to the menu options (one of which is live boost), the AP must be in married form.
Old 02-03-2006, 04:54 PM   #3
perret318
Member#: 23510
WHO DAT!
I believe that you can just hold down the Up and Down arrows when you start the AP, and you can access that option without being married.
I'm not at my car now though, so I can't verify that.
perret318 is offline   Reply With Quote
Old 02-03-2006, 04:55 PM   #4
hondaeater69
Member#: 60324
that is true/\. . .i would try that.
Old 02-03-2006, 08:13 PM   #5
tech
Member#: 73175
2004 wrx
java black
somebody can confirm this????
Old 02-03-2006, 09:35 PM   #6
TJ
Member#: 41735
I'm on your lawn
do something about it
you can run the live boost with the AP without the AP being married
i have cleared codes from other cars that dont even have AP or are running Utec's
TJ is offline   Reply With Quote
Old 02-03-2006, 10:53 PM   #7
tech
Member#: 73175
2004 wrx
java black
so i only plug it in the obd2 without the other connections and just turn it on???
Old 02-03-2006, 10:59 PM   #8
TJ
Member#: 41735
I'm on your lawn
yea the Ap runs off the OBD or the dc power cable
it works fine just try it out
Old 02-03-2006, 11:09 PM   #9
tech
Member#: 73175
2004 wrx
java black
so just to make sure (don't want to scrw anything up) no need to plug the other connectors together and the other one that came with my ap just the obd after turn it on and press on both arrow until the menu shows up is that correct?
Old 02-03-2006, 11:22 PM   #10
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
You don't need to hook anything together, other than the OBD2 plug into its corresponding port, to read live boost.
specialev is offline   Reply With Quote
Old 02-04-2006, 08:53 AM   #11
tech
Member#: 73175
2004 wrx
java black
i plugged it into the odb after press on two arrows it says waiting for pc after that nothing????
Old 02-04-2006, 02:22 PM   #12
hondaeater69
Member#: 60324
the arrow trick is to get it into PC sync mode. You have to marry it like i orignally stated. I can't think of any other way to get to that menu screen.
Why not just flash it? If you're curious what your car is doing stock, you can just revert back to stock after you flash to whatever stage you want, then check your boost levels against your gauge.
Old 02-04-2006, 02:24 PM   #13
hondaeater69
Member#: 60324
the AP doesn't have to married to whatever car you use the live boost/scanner tool on, but it does have to be married on SOME car to even to that screen to select that option.
Old 02-04-2006, 02:52 PM   #14
tech
Member#: 73175
2004 wrx
java black
yeah i just flashed it
Old 02-04-2006, 05:51 PM   #15
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Gimme the nOOb review, so I can live vicariously through you 'till I get mine in the spring.
HAL1 is offline   Reply With Quote
Old 02-04-2006, 11:22 PM   #16
Scoobie Noobie
Member#: 65498
And...?
Scoobie Noobie is offline   Reply With Quote
Old 02-05-2006, 08:51 AM   #17
tech
Member#: 73175
2004 wrx
java black
Wow after only a day the car is so smooth and the power as really increased. Really this is a great mod and if it keeps on settling for the 1 or 2 weeks too come i thinks it will be awsome. Stage 2 must be
Old 02-25-2006, 01:50 AM   #18
subeesteve25
Guest
Member#:
I'm confused how some say stage 2 gets better after a week. What gets better, do u feel more power, smoother? I felt it alot smoother and a bit more powerful right after. What makes the map perform better after u been running it for a week or to?
Old 02-25-2006, 11:18 PM   #19
02WRX_BLUE
Member#: 13704
2006 EVO MR
Apex Silver
Your car (ECU) has set the adaptive timing to compensate for changes. Therefore, it is smoother!
02WRX_BLUE is offline   Reply With Quote
Old 02-26-2006, 03:08 AM   #20
IIdiceII
Member#: 90438
I just got my AP yesterday. So you guys are saying, I can turn the car on and plug the AP into the obd and without connecting the test connectors, drive around and read live boost?
IIdiceII is offline   Reply With Quote
Old 02-26-2006, 02:19 PM   #21
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
No - the AP needs to be married to SOME car (not necessarily YOURS) before you can get to that mode.
Be careful doing this though - trying to achieve full boost while watching a small screen and not killing youself is not easy. Find a buddy to help.
mcowger is offline   Reply With Quote
Old 02-26-2006, 03:03 PM   #22
-Kevlar-
Member#: 82378
so you can clear other cars codes? neat...
-Kevlar- is offline   Reply With Quote
Old 02-26-2006, 05:10 PM   #23
hondaeater69
Member#: 60324
Originally Posted by wrxblubayou
so you can clear other cars codes? ...
yepper
Old 02-26-2006, 05:21 PM   #24
-Kevlar-
Member#: 82378
never pulled a code in another car. same format? or you cant read em just clear em?
Old 02-26-2006, 06:20 PM   #25
hondaeater69
Member#: 60324
Ive read and cleared DTC's on my car with someone elses ap (don't remember if it was an 04 also)
AP read live boost limit? hettchen AccessPort 2 09-10-2007 08:30 AM
how do u read target boost with the ap ver2 ppericfe AccessPort 4 02-08-2007 06:33 PM
read live boost vs boost gauge? Kenji815 AccessPort 8 08-02-2006 05:49 AM
?? about reading live boost with AP pictureboy AccessPort 9 07-06-2006 06:05 PM
Cant tell if im getting full boost with AP SSsleeper96 Engine Management & Tuning 11 12-15-2004 10:17 PM
