Old 02-03-2006, 08:32 PM   #1
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Default car going in and out of wastegate pressure boost help
I'm running a V2 STi motor in the car. Replaced all my coils the other day and was finally able to drive the car in full working order. I haver been able to hit target boost until the other day.
BUT....the car seems to be randomly deciding to go into limp mode or something. No CEL though. Yesterday i was driving on the freeway, downshifted and was hitting target boost and then it all the sudden dropped to wastegate pressure. i turned off the car at a stoplight and started up again and it started running normal boost levels again. But now it's back to wastegate pressure.
any ideas??? thanks
hail2theTheif is offline   Reply With Quote
Old 02-04-2006, 02:26 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
bad boost control solenoid or pressure sensor, you aren't getting a RPM or fuel cut right?
that or you have a boost leak somewhere
note that if you don't have your wastegate covered witha heat sheild and it's been raining a good deal the actuator could very well be getting stuck open due to corrision
Old 02-04-2006, 03:29 AM   #3
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
glad the coilpacks solved your problem. ive got that issue with a bad batch of gas once, but it dosnt seem like your problem. hmm. ponder.
swapstar is offline   Reply With Quote
Old 02-04-2006, 05:20 AM   #4
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
me too swapstar.
not getting a fuel cut or anything. it's weird because when i plug in my green/black test connectors to reset the ecu it gives me code 43 whiich i believe is the pressure sensor? but i don't have a CEL when they aren't plugged in... so that might be worth looking into. anybody know if you can clean the pressure sensor?
Old 02-04-2006, 07:52 AM   #5
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
if u happen to need one i have the mutherlode of sensors. post a pixor!
05 wrx wont go in and out of 2nd gear freely.....shifter linkage?? password:ej20 Transmission (AT/MT) & Driveline 0 01-29-2010 12:35 AM
In and Out of Love patriot1136 General Community 64 04-27-2007 06:32 PM
How do tint laws work? Expecially going in and out of other states? (PA to VA) NewShockerGuy Mid Atlantic Impreza Club -- MAIC 36 08-25-2005 11:51 AM
I voted. i was in and out of there in 10 minutes. Long lines! PAH! Snoopy Political Playground 13 11-02-2004 09:26 PM
popping in and out of gear? ryanh Transmission (AT/MT) & Driveline 0 07-17-2003 04:05 PM
