Old 02-04-2006, 01:26 AM   #1
mars636
Member#: 74547
2005 WRX
WR Blue
Default ECU addressfor ECUExplorer
Does anyone on here know the Engine Load and Ignition advance multiplier address for a 2005 WRX for the Tari ecuExplorer software.
Thanks.
mars636 is offline   Reply With Quote
Old 02-05-2006, 08:49 AM   #2
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
keep trying, you're looking for ~.20-.30 at idle for load which will go up when you tap the gas and a positive number from 1 to 16 for IAM (hopefully 16) on wrx or .5 to 1 on STI
overdose is offline   Reply With Quote
Old 02-05-2006, 09:33 PM   #3
JRSCCivic98
Member#: 67080
020120 or 020124 for the IAM on the 05.
JRSCCivic98 is offline   Reply With Quote
Old 02-06-2006, 01:14 AM   #4
latesleeper
Member#: 84898
2005 Forester XT
JRSC,
What about engine load for the 05 STI?
latesleeper is offline   Reply With Quote
Old 02-06-2006, 12:29 PM   #5
JRSCCivic98
Member#: 67080
Don't know that one off the top of my head. Just find it... it's one of the addresses starting with FF in the list.
Old 02-06-2006, 01:51 PM   #6
Zumble
Member#: 34860
2005 Forester CGM
I tried hard to find the IAM for my 05 FXT but wasn't able to find it. I found a address with a 0.5 and one with a 1.0.. Neither changed when I reset and did the vishnu trick. I drove around and did a few pulls and neither number changed either.
Zumble is offline   Reply With Quote
Old 02-06-2006, 11:14 PM   #7
JRSCCivic98
Member#: 67080
How did you do the reset? Sometimes the disconnect the battery thing doesn't always work... especially on the "drive by wire" ecus... which you have. Try using the reset in the software.
Old 02-07-2006, 12:14 AM   #8
pottymouth
Member#: 69099
2004 WRX Sedan
Java Black Pearl
Just FYI the way I found my IAM and the Engine Load Factor was to make about 10 of them at a time active and check them off on the real time data screen. Then I drove around for a bit and looked at the min and max. I then kept any that looked close and did another 10. Eventually it is obvious which one is correct. I eventually found both of them.
Hope that helps a little
pottymouth is offline   Reply With Quote
Old 02-07-2006, 04:14 AM   #9
latesleeper
Member#: 84898
2005 Forester XT
Thanks for the tips. I'll have to wait until the weather gets better before doing any datalogging. 3rd gear pulls in the snow would be interesting.
Old 02-07-2006, 09:03 AM   #10
Zumble
Member#: 34860
2005 Forester CGM
I used the reset in the software and turned the car off and on again like the software instructed. I'm sure it reset because the car felt crappy after the reset.
Old 02-07-2006, 10:46 AM   #11
JRSCCivic98
Member#: 67080
The IAM for the FXT is listed somewhere on the Tari forum. I saw it once... search for it. As for what the IAM should be on your car it'll be .5 after a reset and can range anywhere between 0.0-1.0. Also, keep in mind that the addresses will start the FF for your type of ecu. If it didn't, then you have the wrong ones or the addresses are not listed yet.
Old 02-07-2006, 11:39 AM   #12
Zumble
Member#: 34860
2005 Forester CGM
I found that post and tried it and it didn't work either. I have a Protuned ECU, does that matter?
Old 02-08-2006, 10:01 AM   #13
JRSCCivic98
Member#: 67080
Sometimes the idiots that tune ecus don't match up the ecu number with the appropriate map. It could be that you might have a more recent revision which might have changed the address for the readout. Anything is possible with Cobb's crap. You're not the first to have issues like this and have a protune.
BTW, what number did you get? Just wondering how you know it doesn't work.
ecuflash and ecuexplorer don't see the ecu ShellBullet Open Source Reflashes 8 07-11-2009 12:33 PM
EcuExplorer cannot connect with 06 STi ECU C J Engine Management & Tuning 7 09-24-2007 03:19 PM
Realtime display in Tari DL1/ecuexplorer?? michaelpatrick Engine Management & Tuning 5 02-03-2006 12:51 AM
ECUExplorer Datalogging on the 06 WRX? riggs Engine Management & Tuning 7 01-27-2006 08:43 PM
ecuExplorer Engine Load address for 2002 USDM WRX? IndyRacer Engine Management & Tuning 23 12-15-2005 11:54 PM
