Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 02-04-2006, 12:35 PM   #1
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Default Something wrong with AP Live Boost Reading?
I installed Stage 2 AP three days ago, with stock gutted UP and helix catted DP. The car felt much much stronger than when it was stock. However, when I read the live boost in AP, the highest I saw was only 10.8 PSI in the third gear. I wasn't running at WOT at the time, only partial throttle so maybe that's to flame. The strange thing is, when I held and cruised at 4,000 RPM in the second gear, the AP still read a negative boost, or 1 to 2 PSI at the most. Does turbo only kick in when you are accelerating?
I am pretty sure there is not a leak in the system. I had my mechanic do the install on the UP and DP and we checked over and over to make sure there's not a leak. Why would I not even see the stock boost level of 13.5 PSI even though the car felt much stronger?
sandwi54 is offline   Reply With Quote
Old 02-04-2006, 01:43 PM   #2
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
You will only get max boost pressure when you are going WOT. That is your first problem. 10.8 is only what it's going to read at partial. Try going WOT and see what it reads... I guarantee it will be higher.
If you are just cruising at 4000rpms, it's going to be the same as if you were cruising at 1500rpms. The turbo only spools under acceleration. If you go WOT at 4000rpms the turbo will spool much quicker than at 1500rpms, but it's the same idea. When just cruising, boost will be under 0psi, it will be in vacuum. It's not until you put your foot into it that it builds boost.
You don't have any problems it sounds like. Go out and go WOT and see how the AP reads then.
turbo tecnica is offline   Reply With Quote
Old 02-04-2006, 01:56 PM   #3
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Aah I see. I will have my cousin read the the boost level for me while I go WOT then. Thanks for the response! Highly appreciated.
Old 02-04-2006, 02:28 PM   #4
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
I just reflashed my base map to Stage 2 CA 91 since I was using the regular Stage 2 91 before and I wanted to play safe and not get knocking (I am in CA). Went out for a run and saw a 14.8 peak boost. Yay now I am happy. I don't have a 3" catback so that's probably why I couldn't hit the 15.8 advertised. Nevertheless I am happy enough with 14.8. With a couple days of ECU learning I should be able to hit 15 PSI.
Old 02-04-2006, 03:12 PM   #5
tech
Member#: 73175
2004 wrx
java black
ijust reflashed myself with stage 1 91 oct and i'm hitting 14.7 psi
tech is offline   Reply With Quote
Old 02-04-2006, 04:00 PM   #6
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
No problem, good luck !
Old 02-04-2006, 06:21 PM   #7
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Maybe it's a combination of the crappy CA gas and the Stage 2 CA map. I'll give it a few days for the ECU to learn and see if I can get > 15 PSI.
Accuracy of AP live boost read d40winker AccessPort 9 03-02-2007 04:23 PM
HELP!! there is something wrong with my boost autvincereautmori Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-28-2007 10:19 PM
Boosting 17.1 on AP Live boost on Stage 2 06WRXTR AccessPort 14 02-15-2007 11:36 AM
live boost readings? -=EJ20T=- AccessPort 4 07-31-2006 04:52 PM
Something wrong with my AP? BlowDro AccessPort 29 07-29-2006 07:09 PM
