Old 02-04-2006, 01:35 PM   #1
STinger
Member#: 19410
'16 STI ISM
'95 LWRX Stage Rally Red
Default adding hood scoop to L
I'm probably going to USDM WRX turbo the '95 L. Anybody have any ideas what to do with adding a hood scoop to a non-scoop hood? This is a rally car, so it doesn't have to look stock, but I don't want it to look nasty either.
Aside from OEM options such as JDM or RS hoods, I'm thinking of just cutting a hole in the existing hood and finding a cheapo add-on hood scoop or an OEM one to fit into it. Then add on or fab the splitter parts underneath.
I'm particularly interested in some aftermarket scoops that would sit on top of the hood and not need me to create a recessed flange for it to sit in.
Has anyone had success with this approach and/or have particular aftermarket scoops or parts they might recommend?
Thanks
STinger is offline   Reply With Quote
Old 02-04-2006, 02:44 PM   #2
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
... if you don't want it to look nasty... then go for the Subaru scooped hood.
bl_easy is offline   Reply With Quote
Old 02-04-2006, 03:38 PM   #3
Billy
Member#: 1391
1997 GF - silent ed.
[email protected] untuned
What about item #1074 just past halfway on this page?
Billy is offline   Reply With Quote
Old 02-04-2006, 07:10 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
tried it
it will look nasty
Old 02-05-2006, 10:07 PM   #5
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I cut a hole in my hood compete with tabs for mounting an '02 scoop, took a little while and a lot of trimming but I think it turned out looking ok. I did a pretty shoddy job IMO, but without being up really close everyone thinks it's stock.
Good enough for my beat to hell car.
speedyHAM is offline   Reply With Quote
Old 02-06-2006, 12:18 AM   #6
andys
Member#: 53455
2004 Forester XTI-RR
dark
Default hood
I just did this to mine last weekend. You should come by and have a look.
andys is offline   Reply With Quote
Old 02-06-2006, 12:54 PM   #7
STinger
Member#: 19410
'16 STI ISM
Nice looking hood scoop! I assume you had to cut out some of the hood supporting frame underneath? How well did it seal and where did you put the scoop distance from the back edge?
Andy: yeah, I should. Did you put on a TMIC then? I thought you were running the Turbo Legacy FMIC?
Old 02-07-2006, 12:30 PM   #8
Elwood
Member#: 8335
96 Impreza L 2.2t
99 Impreza L Wagon
MRT used to list an aftermarket scoop that looked like 98-01 RS, but was made for adding to a flat hood... might check their site
my car's not a rally ride, so I bought a version 1 hood instead
Elwood is offline   Reply With Quote
Old 02-07-2006, 04:38 PM   #9
Lachlan
Member#: 19470
1981 Brat GL
what about a version 2 hood?
Lachlan is offline   Reply With Quote
Old 02-07-2006, 04:41 PM   #10
gc822
Member#: 81217
dear god that is hideous!
gc822 is offline   Reply With Quote
Old 02-07-2006, 06:02 PM   #11
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Just get a FMIC and go for the sleeper look
Kotir is offline   Reply With Quote
Old 02-08-2006, 02:08 AM   #12
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
What rulebook are you building this car to? Rallycross or Stage Rally? If you want to get into Stage Rally then Rally America won't let you run Open Class your first year out as a novice. Starting in 2005 all novices must start out in Production or G2 unless they have major previous racing experience. I had to get a special novice exemption just to run my 137 HP Impreza 2.2 L in Production GT.
NESIC Web Site | Trunkmonkey FAQ | Trunkmonkey Racing | Trunkmonkeys in Action
Sean is offline   Reply With Quote
Old 02-08-2006, 02:09 AM   #13
Sean
Member#: 518
762 PGT Impreza L,
Oh, I see you're from Canada. Nevermind.
Old 02-08-2006, 12:52 PM   #14
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Mine is an '02 hoodscoop over an '02 TMIC. I'll take measurements off the back of the hood tonight if I can remember. I had to make a fiberglass air splitter to get it to funnel the air down onto the IC. I cut out quite a bit of the underhood structure and a nice sized hole in the top of the hood. It took longer to do that and get it right than it took to bolt up the new crossmember and engine.
Old 02-08-2006, 04:44 PM   #15
Sean
Member#: 518
762 PGT Impreza L,
Uhm. Rally car? I wouldn't really trust an FMIC down low scooping up gravel, weeds, and debris.
04-05 sti hood scoop to 2002 wrx scoop wrxkid157 Interior & Exterior Modification 9 01-16-2012 10:58 PM
Adding a scoop to a RS hood. Can it be done clean? prokaw875 Interior & Exterior Modification 10 10-29-2009 08:19 PM
Adding a scoop to my 05 RS? Yay/Nay? Ashr Newbies & FAQs 8 08-20-2009 11:49 PM
04/05 wrx hood scoops to 06/07 wrx hood jonpark Interior & Exterior Modification 4 09-12-2008 04:23 PM
Needed: Stock intake scoop, Seal from hood scoop to IC colombo140 Private 'Wanted' Classifieds 0 10-17-2005 02:47 AM
