#1 |
Member#: 104268
NESIC
Mine seems to be at 0.06 mpa at idle when warm with everything off, slightly less if I have the lights and A/C on so forth. Sound about right?
#2 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
That sounds right on. My car likes to sit at 500mm/Hg at idle, which is approximately 0.066 Bar.
#3 |
Member#: 104268
NESIC
Good, thanks. I just put the gauge on yesterday and everything seems spot on. I also put on the SPT exhaust, which sounds fantastic. I love that boxer sound.
#4 |
Member#: 57608
NWIC
Vehicle:All your boost are belong to us! Mwahahahaaa |
Ditto on the Boxer sound! How does the SPT setup sound compared to stock? Like, way louder or more subtle?
#5 |
Member#: 104268
NESIC
It is considerably louder than stock. Has a real nice sound, deep and not ricey. I haven't gotten it out on the highway yet, hopefully it doesn't drone.
#6 |
Member#: 104268
NESIC
It was kind of a pita to put on because I was really wedged under the car trying to get at the front part of the mid-pipe. I had the back jacked up as high as my floor jack will go and onto jack stands (although I had to let it down a bit to get it on jackstands, unfortunately- I needed about 1/4 inch more to get to the next notch).
That meant that the front of the midpipe was hardly lifted. I was jammed under the thing, couldn't slide in from the side- had to slide down from the back to the front on the creeper until I was basically wedged under the floorpan. Other than access, however, it was a pretty easy job. Getting the old exhaust out of the hangers can be a struggle. Would have been easier if I had another set of jack stands to get all four wheels off the ground. |
#7 |
Member#: 92086
SCIC
Vehicle:2002 wrx stage 2 Subaru Blue |
do you mean -.o6 mpa? shouldnt it be in vaccum at idle? i have a boost gauge that reads in psi and at idle its at like -9.XX psi
#8 |
Member#: 104268
NESIC
Yes, I mean its -, as in vacuum.
Got to log some mixed driving including highway time with the SPT cat-back today on the way to work. Its pretty loud, has a deep sound. Not ricey. Its maybe a little louder than I'd prefer at idle or low RPM's. Sounds good when accelerating. It does seem to drone a little on the highway in the wagon, but its not real bad. |
| Thread Tools | |
| Display Modes | |
| What bulb size of the stock boost gauge?? | jumbosushi | Interior & Exterior Modification | 0 | 07-04-2007 09:50 PM |
| What is the correct STI stock boost gauge reading | hilfiger4you | Factory 2.5L Turbo Powertrain | 2 | 12-26-2005 05:59 AM |
| Boost gauge shows no vacuum/what gives? | jikhead | Factory 2.0L Turbo Powertrain | 2 | 05-23-2004 04:48 PM |
| Boost Gauge readings at idle? | wigglesxjr | Factory 2.0L Turbo Powertrain | 18 | 07-05-2001 11:33 PM |
| boost gauge readings at idle | N/A | Normally Aspirated Powertrain | 6 | 12-19-2000 02:34 PM |
