Old 02-05-2006, 01:37 PM   #1
drth_sti
Member#: 105616
05 STi
Question CEL lights up when I redline my STi..why? Fix?
Hey guys n girls,
n00b question here....my 05 STi has borla hush catback, K&N Typhoon, HKS DP, HKS UP...however, when I miss hiting a gear by taking it to redline and no shifting, it cuts my rev-band down to a lower RPM and the CEL comes on...
just wondering, I know that it's probably my HKS DP as I have had my typhoon on for quite some time before it and no issues....therefore...I heard it the CEL will go away with a tune....but is this kind of issue normal when taking it to/past a bit of redline???
To take the CEL off....I have to disconnect the negative battery terminal and reset it.....is doing this too many times bad? Does it decrease the life of my ecu ???Heard you can only reset it 100 times or so....is this true?
Last question, will the COBB AccessPort help? Will it fix that CEL problem if I tune the car with it to a Stage 2 STi map???
Thanks, any comments would be appreciated!
drth_sti is offline   Reply With Quote
Old 02-05-2006, 02:09 PM   #2
innova
Member#: 97472
2005 PDX STi
Aspen White [email protected] woot
Get the AP. It will most likelly get rid of that CEL and give you some great power gains. You are ready to go straight to STG 2.
You can reset the ECU as many times as you want. Infact it's good to do every once in a while. You're thinking of reprograming the ECU with a basemap, which you can only do 100 times or so.
innova is offline   Reply With Quote
Old 02-05-2006, 02:21 PM   #3
entropy138
Member#: 87446
2005 STI
3 second start club
You're probably getting the CEL because the HKS downpipe removed the cat... Go by pepboys or autozone or whatever you have when your check engine light comes on again and have them pull the code. If its P0420 (i think thats the code - search on here) its because of the dp. I fixed mine by getting the $50 Perrin o2 simulator fix that you splice in between the ecu and rear 02 sensor... its ratehr easy to install and then you have all options of EM open since some won't allow you to turn off certain warning lights (like the UTEC - its either all or none)...
entropy138 is offline   Reply With Quote
Old 02-05-2006, 02:41 PM   #4
boxered
Member#: 61884
Most likely you're creeping with no EM while running a dp. COBB's AP will help with creep and allow you to clear CELs.
boxered is offline   Reply With Quote
Old 02-05-2006, 04:16 PM   #5
drth_sti
Member#: 105616
05 STi
thx guys, gonna grab an accessport!
Old 02-06-2006, 02:04 AM   #6
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Have you tried getting the CEL read to see what it is?
crazymikie is offline   Reply With Quote
Old 02-06-2006, 07:20 AM   #7
Spiider
Member#: 13680
^^^The only sane post so far.
Spiider is offline   Reply With Quote
Old 02-06-2006, 10:58 AM   #8
x99percent
Member#: 27108
2004 STi
2004 A4
If you need to reset the ECU all the time, something isn't right.
Get the code read so you *know* what is really happening.
x99percent is offline   Reply With Quote
Old 02-06-2006, 11:34 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
there is no need to reset the ecu of a properly tuned and mechanically sound car. in fact, arguements can be made that it does more harm than good.
Old 02-06-2006, 01:53 PM   #10
crazymikie
Member#: 56321
Green
Sane post #2.
See also:
http://forums.nasioc.com/forums/showthread.php?t=935336
why are my tail lights on when I connect my battery? skate enjoi Electrical & Lighting 3 10-08-2008 10:09 PM
05 wrx cluster doesnt light up when i turn my car on slapaho_ca Interior & Exterior Modification 7 09-30-2008 04:12 PM
JDM intercooler spray switch doesn't light up when on...why? ioeth Electrical & Lighting 4 04-27-2008 11:45 PM
HIDs light up when they want to khizzle Newbies & FAQs 19 03-06-2008 05:48 AM
going to hong kong and trying to pick up some parts for my sti when there mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-08-2004 10:13 PM
