Old 02-05-2006, 08:12 PM   #1
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Default STi Defi Genome Gauge Install questions
Where do the STi Defi Genome Gauges install? There is the boost, oil temperature, and oil pressure. I assume the boost installs similar to the subaru omori gauge, the vacuum line going to the bypass valve. What about the oil press, and temp? Does the oil press use one of the galley plugs on top of the block? Does the temp use the sensor/drain plug that the subaru omori gauge pack uses?
THAWA is offline   Reply With Quote
Old 02-09-2006, 10:00 PM   #2
THAWA
Member#: 44581
3 Boxers 2 AWD
anyone?
Old 02-09-2006, 10:51 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
there are 2 oil galley plugs that are not used. So these locations are
good choices for those sensors you are questioning. why would you want wires
underneath the car?
Old 02-09-2006, 11:17 PM   #4
THAWA
Member#: 44581
3 Boxers 2 AWD
All the Subaru omori oil temp gauges install in the oil drain plug. You ziptie the wires to the crossmember up through to the firewall. It's the "oem way" to do it, it's pretty accurate this way aswell since the sensor is reading from oil that is semi-stationary. I was just wondering if the STi Defi gauges used the same plug. But can't find any info on where the two oil sensors are tapped.
Old 02-10-2006, 04:35 PM   #5
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
i have these gauges, and theres a sandwich adapter where both temp and pressure sensor go into.
SubasaurusWrex is offline   Reply With Quote
Old 02-10-2006, 10:04 PM   #6
THAWA
Member#: 44581
3 Boxers 2 AWD
Ah, okay, that comes with the kit I assume? Do you have any pics?
Old 05-16-2006, 02:58 PM   #7
ralliharri
Member#: 85035
2011 WRX 5-door
KTM 690 Duke
I would also like to know where to plug the power cord into. I have the Subaru oem gauges and thought it was the same plug behind the radio unit but it doesnt fit. Not sure if this plug is for the STi and I have to cut and splice the wires. Anybody here with answers?
ralliharri is offline   Reply With Quote
Old 05-16-2006, 04:42 PM   #8
SubasaurusWrex
Member#: 70285
2011 JCW Mini
I have these exact gauges, and theres a sandwich adapter for the oil gauges.
Old 05-17-2006, 12:07 AM   #9
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
http://forums.nasioc.com/forums/showthread.php?t=988917
Micky is offline   Reply With Quote
Old 05-17-2006, 12:43 AM   #10
ralliharri
Member#: 85035
2011 WRX 5-door
KTM 690 Duke
I have the sandwich adpater, no problem there, my question is where do I plug the power cord into? Or do I have to splice the wires?
JDM Subaru Impreza WRX STi Defi Genome Gauges b7g Interior/Dressup/Audio & Security 11 03-28-2008 05:19 PM
quick defi egt gauge install question Otaku64 Electrical & Lighting 4 05-20-2007 09:23 PM
FS:WA: JDM STI/Defi/GeNome Boost Gauge ( green lights) dscoobydoo Interior/Dressup/Audio & Security 7 05-02-2007 03:54 PM
Defi Gauge Install Question... STi300 Interior & Exterior Modification 0 05-01-2005 10:24 PM
STi/Defi Genome Triple Gauge Pod fatcatwrx Interior & Exterior Modification 14 06-30-2003 02:43 AM
