Old 02-05-2006, 10:32 PM   #1
kinada423
Member#: 95134
2002 2.5 Hybrid WRX
Default PDX Tuning Protune OTS maps vs. Cobb Stage 2 93 Octane!
Well I have some datalogs comparing the cobb stage 2 93 octane map vs. the over the shelf map I have recieved from PDX tuning and wanted to know if some of the tuning gurus could take a look at these ecuexplorer datalogs and tell me a. which one is safer and b. which one is making more power.
The butt dyno seems to notice holding a lower boost level for longer periods of time with the pdx tune and achieving a shorter more powerful boost with the cobb map.
Any help is greatly appreciated.
Cobb stage 2 ECUexplorer datalog 3rd gear pull
PDX Tuning ECUexplorer datalog 3rd gear pull
Can someone that knows a lot about tuning please take a look at this and give me some feedback.
kinada423 is offline   Reply With Quote
Old 02-05-2006, 10:59 PM   #2
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Does one feel better than the other?
The ECU chooses to run the same timing with both maps, both maps run the same timing, both run the same air flow. You do not have wide band data so there is no way to say which is safer than the other. It looks like both are working well on your car, and you should run which ever one feels better to you.
Jarrad
PDXTuning is offline   Reply With Quote
Old 02-05-2006, 11:18 PM   #3
kinada423
Member#: 95134
2002 2.5 Hybrid WRX
Jarrad check my email. Huuuge difference with your maps it runs great. I didnt know the base map was the low boost map and that datalog is of your low boost map. After loading my realtime map it makes a world of difference. Very smooth and a tremendous amount of power and no negative knock values at high rpms. I can provide you guys with a realtime map datalog run in 3rd gear if you want to make a flowchart out of it or something.
I will eventually get a tactrix cable so I can do an eginuity readout showing target boost and wastegate duty cycles with your maps vs. the cobb stage 2 93 octane.
Old 02-05-2006, 11:49 PM   #4
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
I will get your e-mail when I get to the office tomorrow, glad to hear you like the maps.
Jarrad
Old 02-06-2006, 12:59 PM   #5
JRSCCivic98
Member#: 67080
From what I can see the PDX maps seem to be running higher positive KC values... which from my findings on my car indicates a more stable map. From the various logs I've seen people with very high positive KC values seem to like their maps better. Some tuners touch both the correction values and the base timing on the maps they build while others just touch the base timing. I believe Cobb only modifies the base timing values and leaves the KC maps alone. Cobb also has a different idea behind their tuning... (high timing with leaner A/F ratios... which don't always perform best for everyone.)
JRSCCivic98 is offline   Reply With Quote
Old 02-06-2006, 04:39 PM   #6
HorsepowerFreaks
Vendor
Member#: 57501
KC maps?
HorsepowerFreaks is offline   Reply With Quote
Old 02-06-2006, 06:09 PM   #7
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
I want to buy these maps but every time I call PDX i get a machine?.
STISTL is offline   Reply With Quote
Old 02-06-2006, 06:12 PM   #8
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Leave a message - they always have called me back. Sometimes it takes a few hours, but they do call back.
kingtut12 is offline   Reply With Quote
Old 02-06-2006, 07:38 PM   #9
kinada423
Member#: 95134
2002 2.5 Hybrid WRX
From what I understand they are swamped with work. This happens when you get an overnight community claim to fame and you got every accessport owner that doesn't live near a protuner calling them up. Just bear with them. I did and I am happy with the results.
I mean come on...if you order a part online it takes a few days to get there right
Old 02-06-2006, 08:13 PM   #10
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
I'm really sorry about that. If you go directly to VM during business hours both lines are currently busy. We need a full time office manager/secretary and some more phone lines..... perhaps by this summer.
To better handle and organize Accessport map upgrades we have just added an online map order form to our website front page.
http://www.pdxtuning.com/mapupgrade.htm
However, for those with specific questions we are happy to communicate by phone or email. If the phone does not work try our generic email address.
[email protected] Several persons monitor this email account over the course of the day so your chances of a timely response are quite good.
Best regards
Bailey - PDXT
Old 02-06-2006, 08:18 PM   #11
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
The PDXTuning map pull looks great. The knock correction values are maxed and the timing is spot on. Your car is very happy.
I've watched these data values stream by dozens of times on the dyno..... Looks good
What kind of fuel do you use?
Bailey - PDXT
Old 02-06-2006, 08:49 PM   #12
twentynine
Member#: 96176
'05 WRX
Nice! Thanks Bailey. Although I noticed that this doesn't provide a way to attach our own datalogs. Do you guys need our datalogs to make the PDX maps?
twentynine is offline   Reply With Quote
Old 02-06-2006, 09:11 PM   #13
06WRXTR
Member#: 96668
2006 WRX TR
sorry to hijack...but PDX do you have have OTS tunes for the 06 model wrx's yet?
06WRXTR is offline   Reply With Quote
Old 02-07-2006, 12:49 AM   #14
EnterTheDragon
Member#: 6511
curious as well. Jarrad and I had talked briefly about getting mine in there but as I understand you guys are busy as all heck. If you have something like this instead I could go stage 2 sooner
EnterTheDragon is offline   Reply With Quote
Old 02-07-2006, 12:08 PM   #15
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
:subscribed: I need 02 Stage 2 and a STX legal map. I'll check out the link above.
forced4 is offline   Reply With Quote
Old 02-07-2006, 12:21 PM   #16
Zumble
Member#: 34860
2005 Forester CGM
I'm still waiting on Jarrad to get back to me on my FXT.
Zumble is offline   Reply With Quote
Old 02-07-2006, 01:41 PM   #17
Suby4life
Member#: 92162
World Rally Blue
+1. I left am message and still waiting to hear back.
Suby4life is offline   Reply With Quote
Old 02-07-2006, 10:00 PM   #18
drfrink24
Member#: 36369
2004 WRX STi
Java Black
I just stumbled onto this thread... very interesting stuff.
Does anyone know to what extent they tune?
Fuel,timing,Boost,AVCS, etc...
drfrink24 is offline   Reply With Quote
Old 02-08-2006, 01:10 PM   #19
wrxracer55
Member#: 39435
2002 Impreza WRX
Sedona Red
I'm interested as well
wrxracer55 is offline   Reply With Quote
Old 02-08-2006, 01:27 PM   #20
Zumble
Member#: 34860
2005 Forester CGM
Jarrad says I need a wideband for them to properly do mine. =( It seems if you have a weird setup that isn't common, a live tuner would still be best. But for people with common setups I guess this is still good.
Old 02-08-2006, 01:57 PM   #21
bboy
Member#: 56468
04 Improved STI
Dirty White
Originally Posted by R/TErnie
KC maps?
Knock Correction
Old 02-08-2006, 03:25 PM   #22
legacy_etu
Member#: 35985
05 Legacy GT Wagon
G37xS
Best regards
Bailey - PDXT
What's a map upgrade cost?
legacy_etu is offline   Reply With Quote
Old 02-08-2006, 09:35 PM   #23
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
$150...
anthonyrb98 is offline   Reply With Quote
Old 02-09-2006, 07:20 PM   #24
gopsu
Member#: 96448
02 WRX VF34
I also have PDX on my stage 2 WRX equipped with Borla header. Lack of torque experienced with header is no longer a problem with the new map. I highly recommend them.
gopsu is offline   Reply With Quote
Old 02-10-2006, 07:58 AM   #25
legacy_etu
Member#: 35985
05 Legacy GT Wagon
G37xS
Originally Posted by anthonyrb98
$150...
Okay, thanks. I actually found it on their site after poking around a bit.
Cobb Stage 2 AZ/CA/NV 91 Octane vs Perrin Stage 2 91 Octane Jayknux Engine Management & Tuning 8 01-26-2013 06:58 PM
Cobb Stage 2 OTS map vs. Perrin Stage 2 OTS map liljon350 AccessPort 4 08-09-2009 09:01 AM
Why is cobb stage 2 93 octane is labled "used at your own risk?" smokey240sx AccessPort 0 04-04-2009 02:41 PM
cobb stage 2 93 octane in A/C/N question wrb2006sti AccessPort 11 12-26-2007 12:11 PM
Just flashed Cobb Stage 2-93 octane. Quick question! the2rz Engine Management & Tuning 7 03-11-2005 08:30 PM
