Old 02-05-2006, 10:53 PM   #1
sleestak6326
Member#: 100040
2016 WRX
Ice Silver Metallic
Default Stg 2 slower w/time. Reflashed,now good again
I have been at Cobb Stg 2 fow a couple of months now. Two weeks ago I ran my best time in the 1/8th, [email protected] with a 1.81 60 ft. This past week my car has felt slower. I wasnt sure if I was just getting use to the power or if my car was actually slower. Well today I went to the track and my car was alot slower. The temp was the same, I launched the same and everything. My car was running consistant 8.50's 2 weeks ago and my best today was a [email protected] with a 1.95 60ft. I came home and reflashed Stage 2 and now my car feels strong again. Anyone else had this problem?
sleestak6326 is offline   Reply With Quote
Old 02-06-2006, 12:51 AM   #2
Evo who
Member#: 91487
I actually dont have an answer for your question wish I could help....I am getting my Cobb Stage 2 later this month finally saved up for it and wanted to know how you liked it??? Any 0-60 times or quarter mile yet??? On Cobb's site its just all XXXX on those?? thanks and sry I cant help
Evo who is offline   Reply With Quote
Old 02-06-2006, 07:50 AM   #3
yobtah
Member#: 48939
It could be knocking occasionally. Do you have any way to datalog the car? If so, you could watch IAM and knock correction immediately after your reflash and a few days later. I'm betting you'd see a lower IAM and less healthy knock correction values after more time.
Which map are you running? You could consider a ProTune.
yobtah is offline   Reply With Quote
Old 02-06-2006, 01:08 PM   #4
Aerosim Research Ltd
Member#: 45648
GC8 CF 22B widebody
Lancia Stratos Replica
I say that your stage 2 is knocking and that your IAM is dropping from 12 to around 7-9ish. Just took a look at my friends stage 2 and his multiplier was 9. He also said it got slower over time. You dont need to reflash to get your IAM back to 12, just reset the ECU.
-Peter
Aerosim Research Ltd is offline   Reply With Quote
Old 02-06-2006, 01:11 PM   #5
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
I 2nd the theory that your car overtime achieved a lower IAM and thus reduced performance. When you reflash a cobb map the IAM is initially set at 12, over time if excessive knock is detected it will lower the IAM to protect the engine.
Try datalogging if possible to see what happens to your IAM and KC values over time.
boundy3 is offline   Reply With Quote
Old 02-06-2006, 01:40 PM   #6
mxboy15u
Member#: 105115
Dont run the stage 2 realtime map. I had this problem at the track too, and if you just run the base map, you will stay consistantly faster. I always reset the ECU before racing as well.
mxboy15u is offline   Reply With Quote
Old 02-06-2006, 01:51 PM   #7
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Stop!
Resetting the ECU and making more power is a sign that there is a problem with your car.
It is either retard ignition timing over time because it believes it is encountering det or your fuel trims may be shifting over time and causing the car to run richer. Either way, fix the problem. Resetting the ECU is a temporary solution that could possibly damage your car in the long run.
Mike
crazymikie is offline   Reply With Quote
For all Cobb AP Stg 2 1/4 times owners StealthfishWRX Proven Power Bragging 18 08-10-2006 08:01 PM
Best performing springs for wagon? Stg. 2, car squats, feels loose now. john_matrix Car Part Reviews 2 04-19-2006 05:17 PM
cobb stg 2.5 new time + question cheese tits Proven Power Bragging 2 08-18-2005 08:18 AM
2003 Stg 2 WRX Sedan Part-Out, Now Accepting Offers BudgetRex Bay Area Impreza Club Forum -- BAIC 6 09-26-2004 11:18 PM
Silver WRX w/ txs stg 2 w/ ti muffler and stoptech goodness... Capt Crunch Member's Car Gallery 28 07-05-2003 10:17 AM
