Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 02-06-2006, 12:39 AM   #1
rabbitnutz
Member#: 51940
Unhappy High idle help
okie dokie, here we go again.
background: my98 L coupe, EJ22, 4EAT...now with a MY02 EJ25 engine.
car runs now, i ad to replace the coil pack, so now it runs on all 4 cylinders (yay!) but unfortunately it idles at about 1600 RPMs, and i have no clue why.
i'm wondering if not having a TPS connected or a bad MAF would make it do this. i tried un-plugging the MAF sensor, and the car idled very roughly at 500 RPMs. is there a way to test if the MAF is good?
i've checked my vaccuum lines, and everything is in good order and not leaking. i'm not 100% positive they'r ein the right place, but pics will be up tomorrow to confirm that.
anyone have any suggestions?
rabbitnutz is offline   Reply With Quote
Old 02-06-2006, 03:22 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
wait you are running a 2002 EJ253 on a 98 L EJ22?
that's where i'd start for problems, it's running in open loop because it doesn't know why it's drawing so much air
Old 02-06-2006, 12:21 PM   #3
Harmonix
Member#: 102980
Um, isn't the my2002 engine map based while the my1998 engine maf?
What ecu you running?
Harmonix is offline   Reply With Quote
Old 02-06-2006, 04:03 PM   #4
rabbitnutz
Member#: 51940
woops, sorry for excluding that info, i'm running it off the sock 2.2 ECU, with the map sensor not connected and just plugging up the hole in the manifold, with the MAF sensor connected and functioning.
Old 02-06-2006, 09:47 PM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
look at the idle air control valve. myne is having issues and the car idles at about 1200-1800.
snowman4us is offline   Reply With Quote
Old 02-07-2006, 01:02 AM   #6
rabbitnutz
Member#: 51940
think the IAC might have gone bad? please LMK what you've done to fix it when and if you do.
would takign it apart and cleanign it with carb and choke cleaner be adviseable?
high idle!!!! now choppy idle help! Thran Newbies & FAQs 18 02-22-2007 10:12 PM
high idle, now low choppy idle?!?! help Thran Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-17-2007 12:44 PM
URGENT!....high idle around 2,500rpm need help! Woofy Normally Aspirated Powertrain 0 08-29-2006 01:55 PM
1989 Subaru GL HIGH IDLE HELP!!!!!!! eric_dorr 'Old School' Subaru Forum 3 12-03-2005 08:43 PM
High Idle (1500rpm) please help happyparrot Normally Aspirated with bolt-on Forced Induction Powertrain 10 02-16-2005 01:03 AM
