Old 12-15-1999, 09:29 PM   #1
Sube Doo
Member#: 261
Post Making my outback handle
I want to upgrade the suspension on my outback station wagon with some kyb agx shoks and some eibach springs. I've heard everything from "its no problem" to "you have to change everything thing from the half shalfs to the bushings". Whats the deal. I'm not even going to wast my time trying to soup-up my Sube if I can't get it to handle. I really need some help and i would appreciate your input. I'm thinking of just putting the legacy control arms one and hoping nother breaks or doesn't work. What do you think? What would you do if you were in my situation? And don't say sell the car and get a legacy GT!!!In my parents eyes(they own the car) that isn't happening.
Thanks
Matt
Sube Doo is offline   Reply With Quote
Old 12-16-1999, 04:07 AM   #2
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
If it were my car, probably the first thing I would do is get rid of the body spacers and then get a decent set of wheels and tires, then worry about the suspension. I could be wrong but I would think that the mounting points for the suspension would not differ between an Outback and a normal Legacy, they're basically the same car. I hear the rear strut tower bar on the wagons help quite a bit as well. Take the Outback emblems off and paint the bottom of the car the same as the top and you're good to go
Shik is offline   Reply With Quote
Old 12-16-1999, 06:24 AM   #3
miksmi
Member#: 411
2000 Legacy GT wagon
Timberline Green Pearl
Talking
LOL! Actually, I think the MY00 OB looks much better than the MY99, without the thin stripe of paint that follows the wheel wells on the MY99. But to each his/her own.
Mike Smith, 91 Legacy L wagon (FS), 60K mi, Silver Spring, MD, USA. "Ordered" 29oct1999: 2000 Legacy GT wagon, Timberline Green Pearl
miksmi is offline   Reply With Quote
Old 12-16-1999, 01:20 PM   #4
Sube Doo
Member#: 261
Post
Shik,
you said i should replace the body spacer. What are they? sorry i don't know a lot about cars. I've talked to ralli spec and they said there isn't any problem but i emailed mike shields and he said it wouldn't work because of all this stuff. Also Eric Gannon(really nice and helpful)said it would work either. I'm curious how i can upgrade the suspension with the least amount of negative recourse.
Thanks
Old 12-16-1999, 02:05 PM   #5
Shik
Member#: 132
2015 WRX 6spd CWP
Post
Sube,
The 96-99 Outbacks had 4 spacers(one at each corner I think) that raised the body an inch or so to lift it off the bigger tires and give it a more rugged look. You could check with your local Satan dealer to see exactly where they are and what is involved in removing them. If you remove them, you'd need a set of wheels and tires that better fit the now-lowered body( or just a lower profile tire at the very least). Keep in mind that I'm not even sure that the spacers are removable but if it was my car and I was serious about getting it to handle decent, it would be the first thing I'd check in to.
Maybe the best thing to do is go to a helpful Subaru dealer in your neck of the woods and have a look with the parts guy at the parts book and check part numbers on things like the control arms and such and maybe have a peek at some of the regular Legacy( pre-00) wagons and compare the suspension set-up to yours. Subaru has always had the reputation of not "reinventing the wheel" when it came to certain parts of different cars. Many things between models interchange. Hope this helps a bit.
Old 12-16-1999, 02:14 PM   #6
Sube Doo
Member#: 261
Post
Thanks for the advice
Matt
Old 12-17-1999, 08:06 AM   #7
John Davies
Guest
Member#:
Exclamation
I think it is important, especially with _someone else's_ car, that you not do anything really major like removing body spacers or installing non-OB suspension parts. Anything like this will most assuredly trash the resale value of the car, and it would be expensive in labor time to convert back to stock configuration. I can think of no situation where someone would want to buy a used OB that had been thusly "converted". I see weird vehicles all the time in the Auto Trader that have been so extremely modified that they cannot be sold for a fraction of their stock value.
I would suggest you limit your modifications to easily changed stuff like lower profile tires and adjustable shocks. Or talk your folks into trading it in on a new H6 GT.
As a parent I would not look favorably on my son modifying an OB in the manner being discussed. Don't get your folks mad at you!
I didn't intend this to sound like a parent berating a kid - it just leaked out that way.
Sigh.......
John Davies
Old 12-17-1999, 02:10 PM   #8
Shik
Member#: 132
2015 WRX 6spd CWP
Post
Very good point John, that's why I said "if I was serious about getting it to handle decent" key word being "serious". Sure if you just want something a bit better then stock, throw some shocks on and be done with it, although I don't know how much better it can actual handle seeing that it is still as high off the ground as some small SUVs. But if Sube was serious enough to think about going through all the hassle of swapping control arms and things to get it to handle better, I assumed he had or will have the green light from his parents to do some mods. If not, then yes, it is something to think about.
Old 12-18-1999, 12:02 AM   #9
Sube Doo
Member#: 261
Post
Thanks for the concern. Luckyly my parents are ok with me modifying the car. They are not really that concerned with resale value. Does anyone have a dealers manual on the board that would say the difference in parts? I'm leaving sunday so i don't think i'll be able to visit my local dealership until after the new year. thats why i ask about the manual.
Thanks
Matt
I want to make my 04 RS handle..... qtr_wrx Brakes, Steering & Suspension 1 09-14-2006 10:35 AM
Best route to make my 92x a handling monster? The Gig Brakes, Steering & Suspension 11 10-06-2005 01:22 PM
How can I make my wagon handle like if it were on rails? MikalsWRX Newbies & FAQs 10 04-27-2004 11:59 AM
Help me make my subaru handle better. (x-post from legacy forum) remarcable Brakes, Steering & Suspension 0 07-25-2001 06:57 AM
