Old 02-06-2006, 02:31 PM   #1
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Default AP Stage 2 CA 91 map tuned down that significantly?
I was running the stage 2 regular 91 map without knocking and this past weekend I decided to flash to the CA to play safe since CA gas sucks a$$. Man the CA map felt quite a bit slower than the regular map and I was only hitting 14.5 PSI. I called Cobb this morning and asked them about that, and the guy said the CA map was tuned down a lot to cope with the additive in the CA gas. I told him that my peak boost was only 14.5 PSI and he said that's normal for the CA map.
Wow I didn't know that the CA map was tuned down so much. Do any of you who are in CA and run on the CA map experience this?
sandwi54 is offline   Reply With Quote
Old 02-06-2006, 03:10 PM   #2
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Actually your target boost stays the same.
If you were running ok on the normal map I'd switch back. (fast=fun)
Whats up with the 1.8 in your profile? Do you have mods other than the map notes reccomendations?
parker/slc/gc8fan is online now   Reply With Quote
Old 02-06-2006, 04:20 PM   #3
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
yeah i think i'll switch back to the normal map. i wasn't getting knocks with the normal map anyway. the CA stage 2 map felt like stage 1 on my car =(
haha i put down 1.8 because i don't have a catback. does that prevent me from getting the targeted boost of 15.8 PSI?
Old 02-06-2006, 06:51 PM   #4
yobtah
Member#: 48939
A while ago, Cobb's map notes said something about not hitting target boost without a full turboback. I'm not sure if they still say that or not. I've been using a Cobb downpipe with the stock intermediate pipe and an STi muffler for a while... it seems to work fine, and I hit whatever target boost should be for the map I'm running. I think things like weather, load, and the gear you're in will have a bigger effect on peak boost than a catback.
yobtah is offline   Reply With Quote
Old 02-06-2006, 07:11 PM   #5
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
yeah it seems like people are hitting target boost even without a 3" catback. does a warmer or colder weather help with the boost?
04 STi Stage 2 on Base Map Tune...12.63 and 109 MPH LTBlackBird Proven Power Bragging 8 04-22-2010 04:52 PM
v1 Cobb AP Stage 2 93 v130 Map Question tyc17afguy AccessPort 7 03-18-2007 11:14 PM
AP Stage 2 Det - STX Map? ctechnik Engine Management & Tuning 2 12-12-2005 03:52 PM
AP stage 2 w/ Injen map txl146 Engine Management & Tuning 2 01-26-2005 02:13 PM
utec stage 2 + uppipe 91 octane map needed! BlueBerryRex Engine Management & Tuning 0 04-21-2003 08:08 AM
