Old 02-06-2006, 04:44 PM   #1
HorsepowerFreaks
Vendor
Member#: 57501
Default Tumbler deletes with UTEC= 2k RPM idle....
A friend of mine had me take out his tumbler valves, weld up the outer holes, and port match them. He went to fire the car later and it would idle at 2k rpms... we checked for vacuum leaks...nothing. I believe its directly related to the fact we took out the shafts. What modifications/adjustments do we need to do to get the car to idle? Version 1.1 software on a 04 USDM STi. (I'm going to get him the 4.2 software here shortly)
Any suggestions? or UTEC revisions we should take note of? THank you.
(yes I searched)
-Eric
HorsepowerFreaks is offline   Reply With Quote
Old 02-06-2006, 04:51 PM   #2
x99percent
Member#: 27108
2004 STi
2004 A4
Why blame it on the UTEC?
Do any other mods on the car prevent the car from being started *without* the UTEC?
Also, the latest version of UTEC firmware for the STi is 1.1c, NOT 4.2.
http://www.turboxs.com/stiupdate.htm
x99percent is offline   Reply With Quote
Old 02-06-2006, 05:11 PM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Check your IAC functionality and throttle body plate.
cdvma is offline   Reply With Quote
Old 02-06-2006, 06:03 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
2K idle is indicative of electonic throttle problem.
Old 02-06-2006, 06:12 PM   #5
HorsepowerFreaks
Vendor
Member#: 57501
ok that narrows it down. Thanks for the hint on the 1.1c!
Thing I did notice...the "drive by wire" tb WHINES something fierce with the car on acc. when you disconnect it...the whine goes away. we didnt modify the stock tb, tb plate, or IAC. I understand it all points there, but what exactly are the possiblilities? I mean...if the tb and IAC are connected and are not plugged or restricted then there *should* be no problem.
yeah we have 816cc injectors...which I dont think the factory ecu would be able to idle.
What about this... he had me *also* weld his MAF into his charge pipe(post intercooler and bov) The change in diameter would throw that WAY off IMO...and "could" be the source of the problem. It was originally teh TurboXS IC piping (2.5" OD) and he had it tuned previously for the GPMoto Intake. If this is the problem..which, to me, seems that it is(quite evident) how do I "calibrate" the MAF sensor with the UTEC? is this a simple procedure listen in the UTEC manual?
here's a picture of the bay when i was finished working on it. Note where the MAF and bov are and their respective locations.
Old 02-06-2006, 08:07 PM   #6
chucky
Member#: 26972
2007 WRX STI
White Pearl / Gold wheels
what fuel rail are you using? They look like subydude +1 ?
chucky is offline   Reply With Quote
Old 02-07-2006, 01:23 AM   #7
HorsepowerFreaks
Vendor
Member#: 57501
yeah its teh suby dude rails
Old 02-07-2006, 10:19 AM   #8
x99percent
Member#: 27108
2004 STi
2004 A4
DBW cars don't have an IAC valve.
Old 02-07-2006, 04:39 PM   #9
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Interesting to know, thanks. I honestly didn't read much of the post. I saw 2k idle. A vacuum leak would be HUGE to do that and it would run like crap.
'03 wrx idles high at 2k rpm. guy_in_red_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-14-2009 12:29 AM
UTEC: MAF voltage at idle and @ 2k rpms HorsepowerFreaks Engine Management & Tuning 2 02-08-2006 06:16 PM
Need help with Tumbler deletes and CEL leadfoot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-24-2006 08:33 AM
tumbler deletes with injector plate onyxhunter Private 'For Sale' Classifieds 0 08-31-2004 04:43 PM
Rough idle, lack of power under 2k rpm... madsedan Forester Forum 2 05-19-2004 10:47 PM
