Old 02-07-2006, 12:41 AM   #1
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
Default drive by wire issue
hey.. does anyone have done sti swap on and WRX or GC?? i'm about to do the swap on my 02 wrx.. and someone told me that the mounting bracket for the gas pedal is different.. and will mess up the trottle when not properly installed.. can someone tell me where to install this? on right spot? does anyone have done it?? let me know!
taeyax82 is offline   Reply With Quote
Old 02-07-2006, 05:03 PM   #2
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
that is correct. If you are installing the DBW pedal on a GC RS floor, then the pedal travel will exceed past 100% throttle (or 4.5v max reading), therefore, a longer screw used at the bottom of the bracket spaced out by washers will be needed to set the stop to max out at 4.4-4.5v reading that is sent to the ECU.
http://www.imagestation.com/album/pi...93&mode=invite
check that link to my sti swap album, pic 35 shows the new holes I had to drill to make the pedal fit.
latinskllz is offline   Reply With Quote
Old 02-07-2006, 08:11 PM   #3
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
hey thanks for the info. but its going into an 02 wrx.. i'll check yours out. but do i have to do the same as the gc for this to be working properly?
Old 02-08-2006, 03:21 PM   #4
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
the pedal travel should be the same on your wrx. best thing I can tell you is once you get power to the pedal, measure the voltage fully depressed and fully pressed to see if you are within the ECU's ranges.
I do not think you will have to mod the bracket and it should just be a direct swap.
Old 02-08-2006, 03:24 PM   #5
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
ok i'll do that when i install it.. thanks
Ver 8 non drive by wire AVCS ECU w wiring kit drftsub Engine/Power/Exhaust 15 12-28-2009 06:32 PM
How to wire drive by wire system? Cstmboxermotorsports Subaru Conversions 13 05-20-2007 08:59 AM
Drive by Wire Issue? Egan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 11-21-2004 10:57 PM
Electronic drive-by-wire throttle? WRXThis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 11-30-2001 04:50 PM
Thoughts on drive by wire.... Gambit Technical Forum Archive 34 10-12-2000 10:56 AM
